はじめに
Replace your LCD display only as a last option. Since the LCD display uses a flexible flat cable(FFC), improperly inserting the cable may cause damage to your device.
必要な工具と部品
From the back of the device, slide the back panel downwards to unlock the panel.
Lift the panel up, exposing the battery.
Gently lift the latch on the the ribbon cable connector inward (towards the motherboard).
ある他の人がこのガイドを完成しました。
