はじめに
The maximum battery life for any battery will always decrease as the battery is used. Learning to replace the battery will allow you to make sure your device works when you need it to.
From the back of the device, slide the back panel downwards to unlock the panel.
Lift the panel up, exposing the battery.
ある他の人がこのガイドを完成しました。
