はじめに
Shoe insoles often develop holes or thin worn spots from regular use, which can make walking uncomfortable and allow debris to get inside your shoe. This easy repair lets you patch the damaged area using scrap foam or fabric you likely already have at home, saving you from buying new insoles or shoes.
No special skills or tools are required beyond basic household items. The repair takes about 10–15 minutes of active work plus drying time (total around 30–60 minutes depending on your glue).
Note: Work in a well-ventilated area when using glue. If your insole is extremely thin, crumbling, or the damage is very extensive, replacing the entire insole (or the shoes) may be a better long-term solution.
必要な工具と部品
This step is optional. For a longer-lasting and more comfortable repair, cut a thin piece of fabric (from an old sock or t-shirt) slightly larger than the patch. Apply glue to the back of the fabric and press it smoothly over the repaired area. This creates a softer surface for your foot and helps the patch hold up better over time.
