はじめに
This guide will show you how to replace the wheel assembly for the Shark Matrix RV2310. This replacement may be used to address mobility issues in the vacuum. It is a fairly easy replacement, though it is important to ensure the battery is removed first so that the vacuum is off during this process.
必要な工具と部品
Remove the two 11 mm Phillips screws holding the battery plate in place.
Remove the battery plate.
2 の人々がこのガイドを完成させました。
