はじめに
This guide demonstrates how to replace the two dust filters for the Shark RV754. The filters are responsible for catching fine dust particles that would otherwise float into the air as the vacuum operates. The filters may become clogged over time with regular use. Dirty or overused filters restrict airflow, reducing suction power and the capability to pick up debris. Filters can be cleaned manually to improve effectiveness; however, if they are damaged, they may need to be replaced with new filters.
The vacuum comes with only 1 set of filters, so extras will need to be purchased from Shark's website or third-party retailers like Amazon.
Before you begin, make sure that the device is powered off and disconnected from the charging dock.
必要な工具と部品
Flip the robot vacuum upside down so the wheels are facing up.
Press the dust bin removal latch and slide out the dust bin.
ある他の人がこのガイドを完成しました。
