メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Sanyo VPC-T850 Shutter Button Replacement
必要な工具と部品
    1. Sanyo VPC-T850 Shutter Button Replacement, Battery: 手順 1、 1の画像 1
      • Make sure the camera is powered off by pressing and holding the small, square button embedded in the top rim of the camera.
      FixBotに聞いてみる
      コメントを追加
    2. Sanyo VPC-T850 Shutter Button Replacement: 手順 2、 1の画像 1
      • Locate the hatch found on the bottom of the camera.
      • Open the hatch by gripping the small notch and sliding it outwards.
      FixBotに聞いてみる
      コメントを追加
    3. Sanyo VPC-T850 Shutter Button Replacement: 手順 3、 1の画像 1
      • Push the small, plastic arm out of the way to free the battery.
      • The battery is spring loaded and will pop out slightly when the arm is moved.
      FixBotに聞いてみる
      コメントを追加
    4. Sanyo VPC-T850 Shutter Button Replacement: 手順 4、 1の画像 1
      • Pull the battery out of the camera and close the hatch.
      • To reinsert, there is a triangle on the battery indicating which direction to slide it in.
      FixBotに聞いてみる
      コメントを追加
    1. Sanyo VPC-T850 Shutter Button Replacement, Outer Casing: 手順 5、 3の画像 1 Sanyo VPC-T850 Shutter Button Replacement, Outer Casing: 手順 5、 3の画像 2 Sanyo VPC-T850 Shutter Button Replacement, Outer Casing: 手順 5、 3の画像 3
      • Using your Phillips #000 Screwdriver, remove the eight screws located around the sides and bottom of the camera.
      • Be sure to keep track of the side each screw comes from, as they come in different lengths.
      FixBotに聞いてみる
      コメントを追加
    2. Sanyo VPC-T850 Shutter Button Replacement: 手順 6、 2の画像 1 Sanyo VPC-T850 Shutter Button Replacement: 手順 6、 2の画像 2
      • Orient the camera so the display is facing up.
      • Gently pull off the rear panel surrounding the display.
      • There are still three green wires connecting the panel to the rest of the camera.
      • Use your prying tool if you have difficulties removing the panel by hand.
      FixBotに聞いてみる
      コメントを追加
    3. Sanyo VPC-T850 Shutter Button Replacement: 手順 7、 1の画像 1
      • Remove the eight black screws connecting the keypad circuit board to the rear panel.
      FixBotに聞いてみる
      コメントを追加
    4. Sanyo VPC-T850 Shutter Button Replacement: 手順 8、 2の画像 1 Sanyo VPC-T850 Shutter Button Replacement: 手順 8、 2の画像 2
      • With a plastic opening tool, gently remove the chrome framing on the left and right sides of the camera.
      FixBotに聞いてみる
      コメントを追加
    5. Sanyo VPC-T850 Shutter Button Replacement: 手順 9、 1の画像 1
      • Flip the camera over so the lens is facing up.
      • Gently lift up the front panel to remove it from the rest of the camera.
      • Use your plastic opening tool if you have difficulties removing the panel by hand.
      FixBotに聞いてみる
      コメントを追加
    1. Sanyo VPC-T850 Shutter Button Replacement, Shutter Button: 手順 10、 1の画像 1
      • Find the chrome framing located on the top of the camera.
      • The physical shutter button apparatus is directly attached to this frame.
      FixBotに聞いてみる
      コメントを追加
    2. Sanyo VPC-T850 Shutter Button Replacement: 手順 11、 2の画像 1 Sanyo VPC-T850 Shutter Button Replacement: 手順 11、 2の画像 2
      • Remove the three black screws connecting the chrome frame to the camera.
      • Three screws are located toward the front, with the remaining one above the display.
      FixBotに聞いてみる
      コメントを追加
    3. Sanyo VPC-T850 Shutter Button Replacement: 手順 12、 1の画像 1
      • Gently remove the loosened chrome frame and connected shutter button from the camera.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
作成者
2人の作成者と共同で作成されました。
James Robinson
メンバー登録日: 10/27/15
459 ポイント
4のガイドは作成済み
チーム
UMass Dartmouth, Team 5-5, Gulbrandsen Fall 2015 UMass Dartmouth, Team 5-5, Gulbrandsen Fall 2015人のメンバー
UMASSD-GULBRANDSEN-F15S5G5
3 メンバー
10のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 10
過去 30 日: 45
今までの合計 709
