メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Samsung TL220 Battery Spring Replacement
必要な工具と部品
    1. Samsung TL220 Battery Spring Replacement, Battery Spring Replacement: 手順 1、 2の画像 1 Samsung TL220 Battery Spring Replacement, Battery Spring Replacement: 手順 1、 2の画像 2
      • Begin by unscrewing all seven 4 mm phillip's screws located on the outside of the camera.
      • Using the plastic opening tool carefully pry open the camera, lifting the back casing off.
      FixBotに聞いてみる
      コメントを追加
    2. Samsung TL220 Battery Spring Replacement: 手順 2、 2の画像 1 Samsung TL220 Battery Spring Replacement: 手順 2、 2の画像 2
      • Now that you have the back casing off, gently move the LCD screen from the camera to the right and lay it facing down on the table.
      • Next unscrew the three 4 mm Philips screws on the back panel with the same screw driver.
      FixBotに聞いてみる
      コメントを追加
    3. Samsung TL220 Battery Spring Replacement: 手順 3、 2の画像 1 Samsung TL220 Battery Spring Replacement: 手順 3、 2の画像 2
      この手順で使用する道具:
      • Unclip the four connectors with the plastic opening tool which holds down the orange film strips.
      • Gently with the tweezers remove the four orange film strips from the connectors.
      FixBotに聞いてみる
      コメントを追加
    4. Samsung TL220 Battery Spring Replacement: 手順 4、 2の画像 1 Samsung TL220 Battery Spring Replacement: 手順 4、 2の画像 2
      • Once the orange film strips have been released from the connectors, unscrew the Phillips 4 mm silver screw which holds down the top of the camera's frame.
      • With your fingers gently push up the camera's top frame. Once the camera's top frame is off you can than gently remove the camera's front casing off, as well.
      FixBotに聞いてみる
      コメントを追加
    5. Samsung TL220 Battery Spring Replacement: 手順 5、 2の画像 1 Samsung TL220 Battery Spring Replacement: 手順 5、 2の画像 2
      • Flip the entire camera over so that the lenses are facing upward with the LCD screen showing to the side.
      • Now remove the silver case, seen demonstrated in the picture.
      FixBotに聞いてみる
      コメントを追加
    6. Samsung TL220 Battery Spring Replacement: 手順 6、 1の画像 1
      • After all the parts are disassembled, you will reach the spring part of the camera.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
2 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
chelsa
メンバー登録日: 03/03/15
358 ポイント
3のガイドは作成済み
チーム
3 Tech Girls 3 Tech Girls人のメンバー
Community
2 メンバー
4のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 28
今までの合計 1,011
