メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Samsung Stratosphere Front Camera Replacement
必要な工具と部品
  1. Samsung Stratosphere Front Camera Replacement, Battery: 手順 1、 1の画像 1
    • Using your fingers, pry along the groove at the top of the phone.
    • Pull back on the rear casing until it comes free from the device.
    • The casing will make a cracking sound as it is removed.
    FixBotに聞いてみる
    コメントを追加
  2. Samsung Stratosphere Front Camera Replacement: 手順 2、 1の画像 1
    • With your fingers, pry from the bottom of the battery to loosen it.
    • Lift away to remove the battery from the phone.
    FixBotに聞いてみる
    コメントを追加
  3. Samsung Stratosphere Front Camera Replacement, Motherboard: 手順 3、 1の画像 1
    • Locate the red and white sim card located above the battery housing.
    • Remove the sim card by sliding it downwards from its slot with your fingers.
    FixBotに聞いてみる
    コメントを追加
  4. Samsung Stratosphere Front Camera Replacement: 手順 4、 1の画像 1
    この手順で使用する道具:
    • Remove the seven silver 3mm screws securing the rear panel using the Phillips #000 screwdriver.
    • Once loosened, some screws may get stuck in the casing. Use tweezers to remove them.
    FixBotに聞いてみる
    コメントを追加
  5. Samsung Stratosphere Front Camera Replacement: 手順 5、 1の画像 1
    • Pry around the rear panel with a plastic opening tool to loosen it.
    • Prying too deeply may damage delicate components inside the phone.
    • Remove the rear panel from the phone with your fingers.
    FixBotに聞いてみる
    コメントを追加
  6. Samsung Stratosphere Front Camera Replacement: 手順 6、 1の画像 1
    • Remove the four black 3mm screws securing the motherboard with the Phillips #000 screwdriver.
    FixBotに聞いてみる
    コメントを追加
  7. Samsung Stratosphere Front Camera Replacement: 手順 7、 2の画像 1 Samsung Stratosphere Front Camera Replacement: 手順 7、 2の画像 2
    • Locate the flex cable attachment at the tab with a green arrow printed on top.
    • Pry from the side the arrow is pointing with your fingers.
    • The cable will audibly snap as it is removed from its attachment.
    • Let the cable hang loosely to the side of the phone.
    FixBotに聞いてみる
    コメントを追加
  8. Samsung Stratosphere Front Camera Replacement: 手順 8、 1の画像 1
    • Pull the motherboard up from the side opposite the loose flex cable.
    • If necessary, use a plastic opening tool to separate the motherboard from the key pad underneath.
    • Lift to remove the motherboard from the device.
    FixBotに聞いてみる
    コメントを追加
  9. Samsung Stratosphere Front Camera Replacement, Front Camera: 手順 9、 1の画像 1
    • Insert a plastic opening tool into any side of the phone case to separate the keyboard from the rear panel.
    • Pry the keyboard away from the casing with the plastic opening tool.
    • The keyboard should come off with almost no force at all.
    FixBotに聞いてみる
    コメントを追加
  10. Samsung Stratosphere Front Camera Replacement: 手順 10、 1の画像 1
    • Remove the 7 silver 2mm screws attaching the silver metal plate to the rear panel with the Phillips #000 Screwdriver.
    FixBotに聞いてみる
    コメントを追加
  11. Samsung Stratosphere Front Camera Replacement: 手順 11、 1の画像 1
    • Use the plastic opening tool to carefully loosen the golden metal plate.
    • The golden metal plate is stuck to the rear panel with a strong adhesive, so a moderate amount of force may be needed.
    FixBotに聞いてみる
    コメントを追加
  12. Samsung Stratosphere Front Camera Replacement: 手順 12、 1の画像 1
    • Lift the gold plate with your fingers, repositioning it to slide through the keyboard casing underneath.
    • Carefully take off the keyboard casing with your fingers.
    • The golden metal plate should fit through the wide slot of the casing.
    FixBotに聞いてみる
    コメントを追加
  13. Samsung Stratosphere Front Camera Replacement: 手順 13、 1の画像 1
    • Slide the silver metal plate down and away from the to the flex cable and gold metal plate.
    • The metal plate is attached to springs that offer a small amount of resistance, so it will snap into place.
    FixBotに聞いてみる
    コメントを追加
  14. Samsung Stratosphere Front Camera Replacement: 手順 14、 1の画像 1
    • Unscrew the 4 black 3mm screws from the rear panel with the Phillips #000 Screwdriver.
    FixBotに聞いてみる
    コメントを追加
  15. Samsung Stratosphere Front Camera Replacement: 手順 15、 2の画像 1 Samsung Stratosphere Front Camera Replacement: 手順 15、 2の画像 2
    • Insert the plastic opening tool into the groove at the top of the rear panel.
    • Firmly slide the plastic opening tool all around the rear panel. The panel will audibly snap as it comes apart.
    • These 2 pieces are attached well, so a significant amount of force is needed to separate them.
    FixBotに聞いてみる
    コメントを追加
  16. Samsung Stratosphere Front Camera Replacement: 手順 16、 1の画像 1
    • Lift the flex cable and position it so the part containing the metal plate can come free.
    • Pull the part containing the metal plate away from the rest of the rear panel.
    FixBotに聞いてみる
    コメントを追加
  17. Samsung Stratosphere Front Camera Replacement: 手順 17、 2の画像 1 Samsung Stratosphere Front Camera Replacement: 手順 17、 2の画像 2
    この手順で使用する道具:
    • Use tweezers to loosen the front-facing camera from the plastic casing.
    • Pull the black rectangular piece, attached to the front facing camera, away from the rear panel.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
2 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Ryan
メンバー登録日: 10/20/13
375 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 11-32, Amido Fall 2013 Cal Poly, Team 11-32, Amido Fall 2013人のメンバー
CPSU-AMIDO-F13S11G32
4 メンバー
18のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 30
今までの合計 818
