メインコンテンツにスキップ
Samsung Refrigerator Icemaker Assembly Replacement (Refrigerator Icemaker)
必要な工具と部品
  1. Samsung Refrigerator Icemaker Assembly Replacement (Refrigerator Icemaker), Unplug your refrigerator: 手順 1、 1の画像 1
    • Unplug your refrigerator before you begin your repair.
  2. Samsung Refrigerator Icemaker Assembly Replacement (Refrigerator Icemaker), Open the refrigerator doors: 手順 2、 2の画像 1 Samsung Refrigerator Icemaker Assembly Replacement (Refrigerator Icemaker), Open the refrigerator doors: 手順 2、 2の画像 2
    • Open both French doors for the refrigerator compartment.
  3. Samsung Refrigerator Icemaker Assembly Replacement (Refrigerator Icemaker), Remove the ice bucket: 手順 3、 1の画像 1
    • The ice bucket should be located in the upper left side of your refrigerator. It may have "Ice Master" or "Ice Max" on the outside.
  4. Samsung Refrigerator Icemaker Assembly Replacement (Refrigerator Icemaker), Remove the ice bucket: 手順 4、 3の画像 1 Samsung Refrigerator Icemaker Assembly Replacement (Refrigerator Icemaker), Remove the ice bucket: 手順 4、 3の画像 2 Samsung Refrigerator Icemaker Assembly Replacement (Refrigerator Icemaker), Remove the ice bucket: 手順 4、 3の画像 3
  5. Samsung Refrigerator Icemaker Assembly Replacement (Refrigerator Icemaker), Check the ice bucket condition: 手順 5、 1の画像 1
    • Check for cracks or fractures in the ice bucket and auger assembly. Replace the bucket as needed.
    • Check the gasket around the edge of the bucket. If the gasket's ripped, cracked, rolled or has become too rigid, the bucket won't seal properly and cause condensation to seep in and freeze.
  6. Samsung Refrigerator Icemaker Assembly Replacement (Refrigerator Icemaker), Unfasten the cable cover panel: 手順 6、 2の画像 1 Samsung Refrigerator Icemaker Assembly Replacement (Refrigerator Icemaker), Unfasten the cable cover panel: 手順 6、 2の画像 2
    • Remove the wire harness screw securing the cable cover panel.
  7. Samsung Refrigerator Icemaker Assembly Replacement (Refrigerator Icemaker), Remove the cable cover panel: 手順 7、 3の画像 1 Samsung Refrigerator Icemaker Assembly Replacement (Refrigerator Icemaker), Remove the cable cover panel: 手順 7、 3の画像 2 Samsung Refrigerator Icemaker Assembly Replacement (Refrigerator Icemaker), Remove the cable cover panel: 手順 7、 3の画像 3
    • Use your fingers to slide the cable cover panel towards the front of the refrigerator to unlatch it.
    • Remove the cable cover panel.
    • During reassembly, make sure this panel clips fully in place, or the ice tray won't slide in properly.
  8. Samsung Refrigerator Icemaker Assembly Replacement (Refrigerator Icemaker), Disconnect the icemaker harness: 手順 8、 2の画像 1 Samsung Refrigerator Icemaker Assembly Replacement (Refrigerator Icemaker), Disconnect the icemaker harness: 手順 8、 2の画像 2
    • The exact configuration of the connectors may vary on your refrigerator.
    • Disconnect the left-most yellow connector:
    • Squeeze the locking tab with your fingers.
    • Rock the connector gently side to side to disconnect it.
    • Use your fingers or a screwdriver to guide the wire harness out of the wall clips.
  9. Samsung Refrigerator Icemaker Assembly Replacement (Refrigerator Icemaker), Unfasten the air tunnel: 手順 9、 1の画像 1
    • Remove the ice maker screw securing the air tunnel flap.
  10. Samsung Refrigerator Icemaker Assembly Replacement (Refrigerator Icemaker), Remove the icemaker assembly: 手順 10、 3の画像 1 Samsung Refrigerator Icemaker Assembly Replacement (Refrigerator Icemaker), Remove the icemaker assembly: 手順 10、 3の画像 2 Samsung Refrigerator Icemaker Assembly Replacement (Refrigerator Icemaker), Remove the icemaker assembly: 手順 10、 3の画像 3
    • A plastic clip holds the air tunnel flap in place.
    • Use a flathead screwdriver to pry and loosen the air tunnel flap from the plastic clip.
  11. Samsung Refrigerator Icemaker Assembly Replacement (Refrigerator Icemaker): 手順 11、 2の画像 1 Samsung Refrigerator Icemaker Assembly Replacement (Refrigerator Icemaker): 手順 11、 2の画像 2
    • Use your fingers to pull the air tunnel flap down enough to access the internals.
  12. Samsung Refrigerator Icemaker Assembly Replacement (Refrigerator Icemaker): 手順 12、 2の画像 1 Samsung Refrigerator Icemaker Assembly Replacement (Refrigerator Icemaker): 手順 12、 2の画像 2
    • Use a flathead screwdriver to gently pry the refrigerant loop down by 1–1.5 cm.
    • During reassembly, use your fingers to push the refrigerant loop back up.
  13. Samsung Refrigerator Icemaker Assembly Replacement (Refrigerator Icemaker): 手順 13、 3の画像 1 Samsung Refrigerator Icemaker Assembly Replacement (Refrigerator Icemaker): 手順 13、 3の画像 2 Samsung Refrigerator Icemaker Assembly Replacement (Refrigerator Icemaker): 手順 13、 3の画像 3
    • A plastic clip holds the icemaker in place.
    • Use your fingers to press and release the plastic clip.
    • This clip is stiff and may require substantial force.
  14. Samsung Refrigerator Icemaker Assembly Replacement (Refrigerator Icemaker): 手順 14、 2の画像 1 Samsung Refrigerator Icemaker Assembly Replacement (Refrigerator Icemaker): 手順 14、 2の画像 2
    • Pull the front edge of the icemaker assembly down slightly to loosen it.
    • Be careful not to bend the refrigerant loop too much as you pull the front edge, or you'll damage the loop.
    • Carefully slide the icemaker assembly out of its housing.
  15. Samsung Refrigerator Icemaker Assembly Replacement (Refrigerator Icemaker), Removing the Ice Maker: 手順 15、 2の画像 1 Samsung Refrigerator Icemaker Assembly Replacement (Refrigerator Icemaker), Removing the Ice Maker: 手順 15、 2の画像 2
終わりに
Be sure to dry any moisture that remains in the ice room before reassembly to prevent repair failure.
Repair didn’t go as planned? Ask our Answers Community for help.
作成者
3人の作成者と共同で作成されました。
nicO
メンバー登録日: 04/14/15
15,885 ポイント
88のガイドは作成済み
チーム
Global Fixers Global Fixers人のメンバー
Community
33 メンバー
546のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 25
過去 7 日: 131
過去 30 日: 677
今までの合計 3,096
