メインコンテンツにスキップ
Samsung RF28T5001SR Refrigerator Icemaker Assembly Replacement
必要な工具と部品
  1. Samsung RF28T5001SR Refrigerator Icemaker Assembly Replacement, Unplug your refrigerator: 手順 1、 1の画像 1
    • Unplug your refrigerator before you begin your repair.
  2. Samsung RF28T5001SR Refrigerator Icemaker Assembly Replacement, Open the freezer drawer: 手順 2、 2の画像 1 Samsung RF28T5001SR Refrigerator Icemaker Assembly Replacement, Open the freezer drawer: 手順 2、 2の画像 2
    • Slide the freezer drawer fully open.
  3. Samsung RF28T5001SR Refrigerator Icemaker Assembly Replacement, Remove the freezer bins: 手順 3、 3の画像 1 Samsung RF28T5001SR Refrigerator Icemaker Assembly Replacement, Remove the freezer bins: 手順 3、 3の画像 2 Samsung RF28T5001SR Refrigerator Icemaker Assembly Replacement, Remove the freezer bins: 手順 3、 3の画像 3
    • Lift and remove all the freezer bins from the drawer.
    • You may need to open the refrigerator doors in order to remove the large bin.
  4. Samsung RF28T5001SR Refrigerator Icemaker Assembly Replacement, Remove the freezer door: 手順 4、 3の画像 1 Samsung RF28T5001SR Refrigerator Icemaker Assembly Replacement, Remove the freezer door: 手順 4、 3の画像 2 Samsung RF28T5001SR Refrigerator Icemaker Assembly Replacement, Remove the freezer door: 手順 4、 3の画像 3
    • A plastic tab locks each drawer rail in place.
    • Use a flathead screwdriver or your fingers to press in the plastic tab near the inner end of the drawer rail.
    • While pressing the plastic tab, grasp the rail with your free hand and slide it towards you slightly to unlock the rail.
  5. Samsung RF28T5001SR Refrigerator Icemaker Assembly Replacement: 手順 5、 1の画像 1
    • Repeat the rail unlock procedure on the other drawer rail.
  6. Samsung RF28T5001SR Refrigerator Icemaker Assembly Replacement: 手順 6、 1の画像 1
    • Once both rails are unlocked, firmly pull both rails to slide them out of the refrigerator wall guides.
    • Remove the freezer drawer.
    • To reinstall the freezer drawer:
    • Push the geared torsion bar until it rests at the very end of the rails.
    • Align the drawer rails to the refrigerator wall guides.
    • Close the freezer drawer until the rails lock back in place.
    • If you don't hear a click, visually check if the plastic tabs have locked in place. You may need to push the rails in a little further with your fingers to set the tabs.
  7. Samsung RF28T5001SR Refrigerator Icemaker Assembly Replacement, Unfasten the icemaker assembly: 手順 7、 2の画像 1 Samsung RF28T5001SR Refrigerator Icemaker Assembly Replacement, Unfasten the icemaker assembly: 手順 7、 2の画像 2
    • Use a Phillips screwdriver to remove the two 18.5 mm-long screws securing the icemaker assembly to the freezer ceiling.
  8. Samsung RF28T5001SR Refrigerator Icemaker Assembly Replacement, Disconnect the icemaker assembly: 手順 8、 2の画像 1 Samsung RF28T5001SR Refrigerator Icemaker Assembly Replacement, Disconnect the icemaker assembly: 手順 8、 2の画像 2
    • Grasp the front edge of the icemaker assembly and tilt it downwards.
    • Don't try to remove the icemaker yet, as it's still connected by a few wires.
  9. Samsung RF28T5001SR Refrigerator Icemaker Assembly Replacement: 手順 9、 2の画像 1 Samsung RF28T5001SR Refrigerator Icemaker Assembly Replacement: 手順 9、 2の画像 2
    • Use your fingers to guide the wire harness out of the icemaker assembly.
  10. Samsung RF28T5001SR Refrigerator Icemaker Assembly Replacement: 手順 10、 3の画像 1 Samsung RF28T5001SR Refrigerator Icemaker Assembly Replacement: 手順 10、 3の画像 2 Samsung RF28T5001SR Refrigerator Icemaker Assembly Replacement: 手順 10、 3の画像 3
    • Squeeze the icemaker cable connector and pull to disconnect it.
  11. Samsung RF28T5001SR Refrigerator Icemaker Assembly Replacement: 手順 11、 1の画像 1
    • Remove the icemaker assembly.
終わりに
Repair didn’t go as planned? Ask our Answers community for help.
作成者
2人の作成者と共同で作成されました。
Arthur Shi
メンバー登録日: 01/03/18
254,641 ポイント
529のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
136 メンバー
17,431のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 6
過去 7 日: 19
過去 30 日: 82
今までの合計 720
