はじめに
This guide will require you to disassemble the back and side panel of the printer. You will need to refer to the Removing Samsung ML2510 Back Panel guide in order to complete the task.
必要な工具と部品
Remove the top hinged panel by taking out the pins at the bottom of this panel.
Locate the holes on the panel that are attached to the main body.
Remove the front panel by gently moving the holes from the pegs one by one.
2 の人々がこのガイドを完成させました。
