はじめに
The user will need to remove the outer case. Then remove the motherboard. After, they will need remove the cover protecting the LCD.
必要な工具と部品
Remove the 5.00mm screw on the right of the LCD display towards the bottom of the device by using a Phillips #00 screwdriver.
Once inside the device, find the half that contains the motherboard of the device.
Remove the metal plate under the motherboard.
Use a Phillips head #00 screwdriver to remove the eleven 5.00mm screws.
