はじめに
For the user to remove the camera lens of the Samsung HMX-W200, they will first need to remove the components protecting the lens.
必要な工具と部品
Remove the 5.00mm screw on the right of the LCD display towards the bottom of the device by using a Phillips #00 screwdriver.
Once inside the device, find the half that contains the motherboard of the device.
この手順で使用する道具:Tweezers$4.99
Use the precision tweezers, to gently pull and remove the connector connecting lens and motherboard.
