メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Samsung Gusto 2 Keypad Replacement
必要な工具と部品
  1. Samsung Gusto 2 Keypad Replacement, Battery: 手順 1、 1の画像 1
    • Place the phone screen down like this.
    FixBotに聞いてみる
    コメントを追加
  2. Samsung Gusto 2 Keypad Replacement: 手順 2、 2の画像 1 Samsung Gusto 2 Keypad Replacement: 手順 2、 2の画像 2
    • Find the little slit on the side of the phone and stick your fingernail in between the slit and push your thumb upwards towards your hand.
    • Look at the next picture for the slit.
    FixBotに聞いてみる
    コメントを追加
  3. Samsung Gusto 2 Keypad Replacement: 手順 3、 3の画像 1 Samsung Gusto 2 Keypad Replacement: 手順 3、 3の画像 2 Samsung Gusto 2 Keypad Replacement: 手順 3、 3の画像 3
    • Pop out the battery by placing your finger in between the open slit.
    FixBotに聞いてみる
    コメントを追加
  4. Samsung Gusto 2 Keypad Replacement, Keypad: 手順 4、 2の画像 1 Samsung Gusto 2 Keypad Replacement, Keypad: 手順 4、 2の画像 2
    • Identify the screws as follows and take your screwdriver and unscrew these screws.
    • The screws highlighted in the picture do not need to come out, in fact it is really hard to remove them. Simply unscrewing them will loosen the back of the phone.
    FixBotに聞いてみる
    コメントを追加
  5. Samsung Gusto 2 Keypad Replacement: 手順 5、 1の画像 1
    • Once you have unscrewed the four screws, take your spudger/plastic opening tool and wedge it in the back of the phone as shown in the picture.
    • Find a very thin crevice which seems to run around the phone itself and assertively wedge the spudger into the crevice.
    • Once you have successfully inserted the spudger follow through by sliding the spudger assertively around the phone frame.
    • Apply moderate force while trying to wedge the tool in.
    FixBotに聞いてみる
    コメントを追加
  6. Samsung Gusto 2 Keypad Replacement: 手順 6、 3の画像 1 Samsung Gusto 2 Keypad Replacement: 手順 6、 3の画像 2 Samsung Gusto 2 Keypad Replacement: 手順 6、 3の画像 3
    • The back should now be exposed like the first picture after the case was removed.
    • Flip open the phone, main screen facing up.
    • Push the keypad and slide it out.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Michael Huang
メンバー登録日: 03/30/15
403 ポイント
3のガイドは作成済み
チーム
UMass Dartmouth, Team 2-5, Shastany Spring 2015 UMass Dartmouth, Team 2-5, Shastany Spring 2015人のメンバー
UMASSD-SHASTANY-S15S2G5
3 メンバー
20のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 6
過去 30 日: 18
今までの合計 794
