メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Samsung Gear VR Focus Wheel Replacement
必要な工具と部品
    1. Samsung Gear VR Focus Wheel Replacement, Front Phone Mount: 手順 1、 3の画像 1 Samsung Gear VR Focus Wheel Replacement, Front Phone Mount: 手順 1、 3の画像 2 Samsung Gear VR Focus Wheel Replacement, Front Phone Mount: 手順 1、 3の画像 3
      • Remove the front cover to access a plate that holds the phone in place during use.
      • Remove the four corner screw covers with a metal spudger to reveal four screws.
      • Remove the sticker located at the top center to reveal two additional screws.
      FixBotに聞いてみる
      コメントを追加
    2. Samsung Gear VR Focus Wheel Replacement: 手順 2、 2の画像 1 Samsung Gear VR Focus Wheel Replacement: 手順 2、 2の画像 2
      • Using the PH000 tip remove the six 0.5 cm screws that secure the front phone mount.
      • After the six 0.5 cm screws are completely removed lift the front phone mount up and to the left.
      • When handling your equipment be careful not to strain the wire harness located on the left side of the headset.
      FixBotに聞いてみる
      コメントを追加
    1. Samsung Gear VR Focus Wheel Replacement, Motherboard: 手順 3、 1の画像 1
      • Use the blue plastic opening tool to remove the rest of the the pop connectors from the motherboard.
      • The larger gold connector is lightly glued down so it may take more effort to remove than the others.
      FixBotに聞いてみる
      コメントを追加
    2. Samsung Gear VR Focus Wheel Replacement: 手順 4、 1の画像 1
      • You can now remove the motherboard from the mask.
      • Make sure that nothing is connected to the motherboard before you try to remove it as pulling it with something connect might brake the connections.
      FixBotに聞いてみる
      コメントを追加
    1. Samsung Gear VR Focus Wheel Replacement, Inner Mask: 手順 5、 3の画像 1 Samsung Gear VR Focus Wheel Replacement, Inner Mask: 手順 5、 3の画像 2 Samsung Gear VR Focus Wheel Replacement, Inner Mask: 手順 5、 3の画像 3
      • Using the PH000 tip remove the eight 0.5 cm screws from the Inner Mask
      • Carefully remove the Inner Mask by pulling it from the inner side of the lenses socket.
      FixBotに聞いてみる
      コメントを追加
    1. Samsung Gear VR Focus Wheel Replacement, Focus Wheel: 手順 6、 2の画像 1 Samsung Gear VR Focus Wheel Replacement, Focus Wheel: 手順 6、 2の画像 2
      • Use your fingers to gently remove focus wheel.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
作成者
5人の作成者と共同で作成されました。
Alfredo Aparicio
メンバー登録日: 09/25/17
325 ポイント
3のガイドは作成済み
チーム
USF Tampa, Team S4-G6, Eyestone Fall 2017 USF Tampa, Team S4-G6, Eyestone Fall 2017人のメンバー
USFT-EYESTONE-F17S4G6
4 メンバー
14のガイドは作成済み
1件のガイドコメント
hi Alfredo, so my VR Oculus is blurry, I was wondering if u probably new what the problem was and if u could help me. I see u contributed to fixing some issues on the product.
August Tello - 返信 共有
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 8
過去 30 日: 29
今までの合計 2,152
