メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Samsung Gear 2 Neo Home Button Replacement
必要な工具と部品
    1. Samsung Gear 2 Neo Home Button Replacement, Battery: 手順 1、 1の画像 1
      • Remove the wristband by sliding the metal pins located on both sides of the wrist band, and pulling the wristband off.
      FixBotに聞いてみる
      コメントを追加
    2. Samsung Gear 2 Neo Home Button Replacement: 手順 2、 2の画像 1 Samsung Gear 2 Neo Home Button Replacement: 手順 2、 2の画像 2
      • Use a T5 Torx Screwdriver to remove the 4 (0.4 mm) screws located on the back of the watch.
      FixBotに聞いてみる
      コメントを追加
    3. Samsung Gear 2 Neo Home Button Replacement: 手順 3、 1の画像 1
      • Slide the opening tool in between the two halves of the case and slide along the edge of the watch while gently prying the back cover away from the face of the watch.
      FixBotに聞いてみる
      コメントを追加
    4. Samsung Gear 2 Neo Home Button Replacement: 手順 4、 2の画像 1 Samsung Gear 2 Neo Home Button Replacement: 手順 4、 2の画像 2
      この手順で使用する道具:
      • Use a pair of tweezers to peel the battery ribbon cable off of the back cover.
      • Avoid damaging the gold terminals on the ribbon cable.
      • When reassembling, make sure that the yellow strip snaps back on to the black pin.
      • The pin is located, and marked on the picture.
      • Pull up on the tab that says, “Pull”, the battery will lift straight out.
      FixBotに聞いてみる
      コメントを追加
    1. Samsung Gear 2 Neo Home Button Replacement, Motherboard: 手順 5、 1の画像 1
      • Using the plastic opening tool, pull up on the flex connector. It will come off the motherboard, but will stay attached to the cover like a hinge.
      FixBotに聞いてみる
      コメントを追加
    2. Samsung Gear 2 Neo Home Button Replacement: 手順 6、 1の画像 1
      • It is recommended to use antistatic wrist wrap whenever removing the motherboard.
      • Place the plastic opening tool underneath the motherboard at this location. Gently pry the motherboard away from the front cover. It should pop off and be free from the cover.
      • Attached to the motherboard is the infrared LED Light. To replace the IR LED, you may need to replace the entire motherboard.
      FixBotに聞いてみる
      コメントを追加
    1. Samsung Gear 2 Neo Home Button Replacement, Home Button: 手順 7、 1の画像 1
      この手順で使用する道具:
      • Using fine tweezers, pull the home button ribbon cable up and away from the front cover.
      • Like with the battery's ribbon cable, there is a pin that holds the pad in place. It is in the area marked. However, the models' pin had be broken.
      FixBotに聞いてみる
      コメントを追加
    2. Samsung Gear 2 Neo Home Button Replacement: 手順 8、 1の画像 1
      • Using the plastic opening tool, pry the home button away from the front cover.
      • The whole home button mechanism should lift right out.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
作成者
4人の作成者と共同で作成されました。
Victor Yore
メンバー登録日: 08/27/15
705 ポイント
5のガイドは作成済み
チーム
USF Tampa, Team 5-6, Blackwell Fall 2015 USF Tampa, Team 5-6, Blackwell Fall 2015人のメンバー
USFT-BLACKWELL-F15S5G6
3 メンバー
5のガイドは作成済み
1件のガイドコメント
do you know where i purchase the actual button?
Nolan M Charbonnet Sr. - 返信 共有
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 26
今までの合計 1,459
