メインコンテンツにスキップ
Samsung Galaxy Watch Active2 Motherboard Replacement
必要な工具と部品
  1. Samsung Galaxy Watch Active2 Motherboard Replacement, Turn off the watch: 手順 1、 2の画像 1 Samsung Galaxy Watch Active2 Motherboard Replacement, Turn off the watch: 手順 1、 2の画像 2
    • Turn off the Galaxy Watch Active2 by pushing and holding the bottom button for approximately 3 seconds. You should feel a short vibration.
    • When the "Power off" symbol appears, tap the center of the screen to make it shut down. You should feel a longer vibration for confirmation.
  2. Samsung Galaxy Watch Active2 Motherboard Replacement, Remove the rear screws: 手順 2、 1の画像 1
    • Use a Tri-point Y00 screwdriver to remove the four 4 mm-long screws on the back of the watch.
  3. Samsung Galaxy Watch Active2 Motherboard Replacement, Separate the back cover from the housing: 手順 3、 3の画像 1 Samsung Galaxy Watch Active2 Motherboard Replacement, Separate the back cover from the housing: 手順 3、 3の画像 2 Samsung Galaxy Watch Active2 Motherboard Replacement, Separate the back cover from the housing: 手順 3、 3の画像 3
    • Use an opening pick and place it between the plastic back cover and the metal housing near the buttons.
    • Push the opening pick into the gap to separate the back cover from the housing.
    • Don’t remove the back cover all the way yet. There is a cable connecting it to the motherboard.
  4. Samsung Galaxy Watch Active2 Motherboard Replacement, Disconnect the sensor array: 手順 4、 2の画像 1 Samsung Galaxy Watch Active2 Motherboard Replacement, Disconnect the sensor array: 手順 4、 2の画像 2
    • Carefully lift the back cover to access the sensor array connector.
    • Use a spudger to disconnect the sensor array from the motherboard.
  5. Samsung Galaxy Watch Active2 Motherboard Replacement, Remove the back cover: 手順 5、 1の画像 1
    • Remove the back cover.
  6. Samsung Galaxy Watch Active2 Motherboard Replacement, Disconnect the display and speaker: 手順 6、 3の画像 1 Samsung Galaxy Watch Active2 Motherboard Replacement, Disconnect the display and speaker: 手順 6、 3の画像 2 Samsung Galaxy Watch Active2 Motherboard Replacement, Disconnect the display and speaker: 手順 6、 3の画像 3
    • Use a spudger to disconnect the display assembly and the speaker.
  7. Samsung Galaxy Watch Active2 Motherboard Replacement, Disconnect the barometric sensor, buttons, and mic: 手順 7、 3の画像 1 Samsung Galaxy Watch Active2 Motherboard Replacement, Disconnect the barometric sensor, buttons, and mic: 手順 7、 3の画像 2 Samsung Galaxy Watch Active2 Motherboard Replacement, Disconnect the barometric sensor, buttons, and mic: 手順 7、 3の画像 3
    • Use a spudger to disconnect the barometric sensor, the buttons, and the microphone.
  8. Samsung Galaxy Watch Active2 Motherboard Replacement, Lift the core assembly: 手順 8、 2の画像 1 Samsung Galaxy Watch Active2 Motherboard Replacement, Lift the core assembly: 手順 8、 2の画像 2
    • Place a spudger underneath the motherboard at the top right next to the display connector.
    • Slightly twist and lever the spudger to loosen the core assembly.
    • It might help to also check the comments below this and the next step if you’re having difficulties.
  9. Samsung Galaxy Watch Active2 Motherboard Replacement, Remove the core assembly: 手順 9、 3の画像 1 Samsung Galaxy Watch Active2 Motherboard Replacement, Remove the core assembly: 手順 9、 3の画像 2 Samsung Galaxy Watch Active2 Motherboard Replacement, Remove the core assembly: 手順 9、 3の画像 3
    • Grab the core assembly and carefully slide it out from under the cables.
    • Remove the core assembly.
  10. Samsung Galaxy Watch Active2 Motherboard Replacement, Flip the Core Assembly: 手順 10、 1の画像 1
    • Flip the core assembly over so the motherboard faces down.
  11. Samsung Galaxy Watch Active2 Motherboard Replacement, Undo the top button: 手順 11、 2の画像 1 Samsung Galaxy Watch Active2 Motherboard Replacement, Undo the top button: 手順 11、 2の画像 2
    • Use the tip of an opening pick to peel the top button off the plastic frame.
  12. Samsung Galaxy Watch Active2 Motherboard Replacement, Remove the motherboard screw: 手順 12、 1の画像 1
    • Use a Phillips screwdriver to remove the 4.4 mm-long screw holding the motherboard in place.
  13. Samsung Galaxy Watch Active2 Motherboard Replacement, Free the motherboard: 手順 13、 2の画像 1 Samsung Galaxy Watch Active2 Motherboard Replacement, Free the motherboard: 手順 13、 2の画像 2
    • Place the flat end of a spudger between the motherboard and the plastic frame near the copper coil at the bottom right.
    • Twist the spudger to free the motherboard from the plastic tabs.
  14. Samsung Galaxy Watch Active2 Motherboard Replacement, Remove the motherboard: 手順 14、 1の画像 1
    • Slide the motherboard out from under the remaining plastic tabs to remove it.
終わりに
4 の人々がこのガイドを完成させました。
Tobias Isakeit
メンバー登録日: 03/31/14
124,137 ポイント
189のガイドは作成済み
チーム
Tobias Isakeit - Repairability Engineer Tobias Isakeit - Repairability Engineer人のメンバー
Business
1 メンバー
1,131のガイドは作成済み
13 件のコメント
Hi, I am having issues with bluetooth, is it a replacement or do I need to swap the MB? Thank you
Bruno Albin - 返信
When you have ruled out any software issues (tried restart, factory reset, software update, etc) then this is most likely a MB replacement since all the modules are integrated on that tiny thing.
Tobias Isakeit -
does the watch active have the same motherboard as the watch active 2
aqoullam6 - 返信
Nope, the Watch Active has a different motherboard.
Tobias Isakeit -
My watch stopped vibrating all together, which part do I need to replace?
Melissa McEleney - 返信
コメントを追加
統計データ:
過去 24時間: 5
過去 7 日: 24
過去 30 日: 84
今までの合計 10,105
