メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Samsung Galaxy View Camera Replacement
必要な工具と部品
    1. Samsung Galaxy View Camera Replacement, Kickstand: 手順 1、 1の画像 1
      • Place the device on a hard flat surface with its screen facing downwards.
      • Rotate the the kickstand so that the handle grip hole is up in the air and not touching the back of the tablet.
      FixBotに聞いてみる
      コメントを追加
    2. Samsung Galaxy View Camera Replacement: 手順 2、 3の画像 1 Samsung Galaxy View Camera Replacement: 手順 2、 3の画像 2 Samsung Galaxy View Camera Replacement: 手順 2、 3の画像 3
      • Stick the pointy end of the spudger into the circular opening of the leftmost metallic latch.
      • With the spudger still inserted, pry the spudger to the right pushing the latch opening along with it.
      • Once the latch is moved to the right, pull up on the left side of the kickstand, releasing it from the back of the tablet.
      • Repeat the previous steps for the rightmost latch, and then lift the kickstand off the back of the tablet.
      FixBotに聞いてみる
      コメントを追加
    1. Samsung Galaxy View Camera Replacement, Battery: 手順 3、 2の画像 1 Samsung Galaxy View Camera Replacement, Battery: 手順 3、 2の画像 2
      • Check the device is completely turned off.
      • Slide open the SD compartment tab, and remove the SD card to ensure all data is saved.
      FixBotに聞いてみる
      コメントを追加
    2. Samsung Galaxy View Camera Replacement: 手順 4、 3の画像 1 Samsung Galaxy View Camera Replacement: 手順 4、 3の画像 2 Samsung Galaxy View Camera Replacement: 手順 4、 3の画像 3
      • Remove the 4 screws (4 mm in length) using the Phillips #0 screwdriver.
      FixBotに聞いてみる
      コメントを追加
    3. Samsung Galaxy View Camera Replacement: 手順 5、 3の画像 1 Samsung Galaxy View Camera Replacement: 手順 5、 3の画像 2 Samsung Galaxy View Camera Replacement: 手順 5、 3の画像 3
      • Insert the plastic opening tool between the seam of the back panel and the front casing to create an initial opening.
      • Insert the metal spudger within the opening.
      • Move the metal spudger down the seam, prying the back panel open as you go.
      • Once a large enough opening is made, pry the entire back panel off with your hand.
      • You will hear loud popping from the magnetized latches. This is not causing damage to the device and will require some force to open.
      FixBotに聞いてみる
      コメントを追加
    4. Samsung Galaxy View Camera Replacement: 手順 6、 2の画像 1 Samsung Galaxy View Camera Replacement: 手順 6、 2の画像 2
      • Using the plastic opening tool, lift off the orange press-fit connector (marked with a white arrow-head) where it attaches to the motherboard.
      FixBotに聞いてみる
      コメントを追加
    5. Samsung Galaxy View Camera Replacement: 手順 7、 3の画像 1 Samsung Galaxy View Camera Replacement: 手順 7、 3の画像 2 Samsung Galaxy View Camera Replacement: 手順 7、 3の画像 3
      • Remove the 6 screws (4 mm in length) using the Phillips #0 screwdriver.
      • Remove the battery from the device.
      FixBotに聞いてみる
      コメントを追加
    1. Samsung Galaxy View Camera Replacement, Camera: 手順 8、 3の画像 1 Samsung Galaxy View Camera Replacement, Camera: 手順 8、 3の画像 2 Samsung Galaxy View Camera Replacement, Camera: 手順 8、 3の画像 3
      • Place the plastic opening tool underneath the blue press-fit connector which is touching the green circuit board at the bottom of the device.
      • Pry upwards with the plastic opening tool to disconnect the press-fit connector.
      • Remove the camera by carefully gripping the press-fit connector and pulling upwards.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Jordan Thayer
メンバー登録日: 10/06/16
535 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 4-5, Livingston Fall 2016 Cal Poly, Team 4-5, Livingston Fall 2016人のメンバー
CPSU-LIVINGSTON-F16S4G5
4 メンバー
24のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 23
今までの合計 1,402
