メインコンテンツにスキップ
Samsung Galaxy S7 NFCアンテナと充電コイルアセンブリ
必要な工具と部品
  1. Samsung Galaxy S7 NFCアンテナと充電コイルアセンブリ, リアガラス: 手順 1、 1の画像 1
    • 電話本体を開口するということは防水用シールを破棄するということです。この作業を始める前に、交換用の接着剤を準備してください。
    • 温めたiOpenerをデバイス長辺側の端に沿って約2分間載せます。
    • デバイスを十分に温めるにはiOpenerを複数回に渡って温め、載せる作業を繰り返さなければなりません。iOpenerの使用方法に従って、オーバーヒートにご注意ください。
    • ヘアードライヤやヒートガンも使用もできますが、デバイスを温めすぎないでくださいーOLEDディスプレイと内蔵されたバッテリーはどちらも熱によるダメージを受けやすい性質があります。
    I used a heat gun and heated it a little too much. The color of the rear glass is just a sticker on a clear cover. Due to this I tore the sticker off. Now the back cover is see through, which isn’t a bad thing but the repair was for a customer.
    Kevin Bishop - 返信
    When using the iOpener, you may need more than 30 seconds, especially in compact or low wattage microwaves. Take this slowly, though, and be extremely careful, as it is easy to overheat your iOpener. Remember, you can always heat it up a tad more, but you cannot undo overheating it.
    Jacob Pratt - 返信
    I used an adjustable heat gun and set it to 400 degrees (F). That was enough to seperate the glass without having to worry about exposure times of the heat. The front of the phone was just fine. Just be ready to use a bunch of picks to slide in between because they will be needed this way.
    Ryan Schumerth - 返信
    I went from the bottom center up, using one ifixit tools, one suction cup and one pick.
    Pick just popped in with some minor pressure.
    Laid heat pack along base of phone 2 mins first and worked up slowly, rotating picks as I went. Had to heat iopener over several 30 second bursts
    Lauren Burt - 返信
    This is useless because the phone does not recognize the new battery and will behave like on the old one
    Search for “battery count xda"
    Albert Einstein - 返信
    That is an interesting discovery! Thanks for pointing it out—I’ll have to look into it.
    Even if this is true, replacing the battery should still give restore a significant amount of life, since the max voltage affects a minor amount of the battery’s capacity. If you charge a worn battery and a new battery to the same lower max voltage, the worn battery’s voltage will dip more under use and will be depleted faster.
    Arthur Shi -
    Thanks for the guide! It helped me replace a friend's battery with no problems!
    Darren Crook - 返信
    I will never replace a screen again, and don’t recommend it. Not for phones nowadays. Once upon a time everything was screwed together, and you might even get the same quality or better screen when buying from eBay. And having the phone repaired was nearly the cost of the phone. Now, it’s the reverse. Removing the glued back and screen and cleaning off all the glue for a clean re-seal is an ordeal that takes multiple hours, AND, often the screen you buy on eBay is NOT OLED, but an LCD, and a blurry one at that. And the local phone repair store will replace the screen with an OLED, reliably, same day turn around, for not much more than the cost of an actual OLED screen, because they have the parts in bulk, and the tools and experience to do it quickly. Never again!
    domarius - 返信
    have you ever had one that just wont open at all? i can not get mine to open to replace the battery i have heated with a heat gun and attached suction cup and it will not lift at all
    Carla James - 返信
    Hi Carla,
    I've definitely had that experience before. The adhesive is very strong, and the curved back makes getting the initial seam very difficult. I'd suggest focusing on one small area on the edge. Apply steady force when you pull, and repeat a few times to loosen the adhesive. Eventually it will give and present a small gap.
    Arthur Shi -
  2. Samsung Galaxy S7 NFCアンテナと充電コイルアセンブリ: 手順 2、 3の画像 1 Samsung Galaxy S7 NFCアンテナと充電コイルアセンブリ: 手順 2、 3の画像 2 Samsung Galaxy S7 NFCアンテナと充電コイルアセンブリ: 手順 2、 3の画像 3
    • バックパネルを触って十分に温まっていたら、吸盤カップをデバイスの端付近に取り付けます。カーブの入った端の上には装着しないでください。
    • 吸盤カップはガラスパネルのカーブが入った部分には適しません。
    • デバイスのバックカバーにひび割れが入っている場合は、吸盤カップが装着できません。強力なテープやスーパーボンドで吸盤カップを固定してからカップを持ち上げます。これで上手くいけば、次の手順に進んでください。
    • 吸盤カップが持ち上がったら、リアガラスの下に開口ピックを差し込みます。
    • 強い力を加えたり、メタル製の開口ピックを使用するとリアガラスが割れてしまいます。
    • カーブしたガラスのため、デバイスの隙間に平行に挿入するよりも上むきに押し上げながら挿入します。
    • うまくいかない場合は、さらに熱を当てて接着剤を柔らかくします。接着剤はすぐに冷たくなるため、作業は繰り返し、素早く行います。
    • 次の手順のオプションとして、開口ピックが挿入できたら粘着力を弱めるため、隙間にイソプロピルアルコールを数滴注入します。
    Because of the metal lip around the phone the picks were to thick to get under the glass. Couldn’t get the glue loose enough with the iOpener or the glass lifted high enough with the suction cup despite using a lot of heat and stength on the suction. Ended up having to use a thin piece of metal to get the first separaration. After that the picks are ok to use.
    loadinglevelone - 返信
    This step is certainly giving me trouble. I don’t have enough hands to be able to both form the space and to insert the pick. In order to even form the space, I need to use the double-sided plastic scraper-thing.
    Damian Amerman-Smith - 返信
    Turns out that three hands was the answer. I had my dad insert the pick while I pried open a gap, and it was smooth sailing from there.
    How do you pull on the suction cup? I.e. what's the right technique to pull up the suction cup? Just pulling up is going to lift the entire phone, unless I had some kind of double sided suction cup up keep the phone stuck to the table.
    Thank you
    A X - 返信
    I'm going to try it Jerry rig everythings technique. https://m.youtube.com/watch?v=kHzmFPoZbC... unfortunately every iFixit video seems to use the clamp which seems like an oversight for a tutorial. But it is not fair for me to be too annoyed since they have really good repair kits and the repair guides are nice.
    A X -
  3. Samsung Galaxy S7 NFCアンテナと充電コイルアセンブリ: 手順 3、 1の画像 1
    • ガラスの間に開口ピックがしっかりと挿入できたら、さらに接着剤を柔らかくするためiOpenerを再度温めてデバイスの上に載せます。
    Use a heat gun or hair dryer to soften the adhesive to remove the back cover. The Iopener that you heat up with the microwave takes a very long to accomplish the same task.
    michael kotarba - 返信
    Keep the heat gun in motion at all times and check the surface temperature of the phone with your hand every few seconds to ensure it does not overheat the plastic and glass and electronics. Use several blue guitar picks to brake the seal of the cover once you have softened the adhesive and popped the seal initially with the suction cups.
  4. Samsung Galaxy S7 NFCアンテナと充電コイルアセンブリ: 手順 4、 2の画像 1 Samsung Galaxy S7 NFCアンテナと充電コイルアセンブリ: 手順 4、 2の画像 2
    • 開口ピックをデバイス横に沿って下に向けてスライドし、接着剤を切断します。
    • ピックの先端が隙間からスリップして飛び出さないようにゆっくりとスライドします。スライド作業が困難になったら、iOpenerを再び温めて、接着剤を柔らかくしてください。
    • 次の手順に進むため、開口ピックを下側の位置に残したまま、2枚目のピックを準備してください。最初のピックを隙間に残しておくことで、切断した接着剤が再装着するのを防ぎます。
  5. Samsung Galaxy S7 NFCアンテナと充電コイルアセンブリ: 手順 5、 3の画像 1 Samsung Galaxy S7 NFCアンテナと充電コイルアセンブリ: 手順 5、 3の画像 2 Samsung Galaxy S7 NFCアンテナと充電コイルアセンブリ: 手順 5、 3の画像 3
    • デバイス残りの3辺においても同じ手順を繰り返して、接着剤を温めて切断します。
    • 各サイドに開口ピックを残してください。接着剤が再装着するのを防いでくれます。
    At about this stage, as I was working on the fourth side, the layer of black paint on the inside of the glass started to separate from the glass, near the edge. I may have overheated the phone (I used a heat gun). Most of the paint layer ended up left behind, attached to the body of the phone, as the glass came away - along with the lens covers of the camera and flash. I removed and discarded as much of the paint as I could using tweezers, a spudger, and cautious heating with the heat gun. I hope the back glass will work OK without it; a clear back cover will be a distinctive design feature! If not I’ll have to get a new one. (Note, some battery repair kits from other suppliers such as Amazon include a replacement back glass, which would help with this issue).
    Michael Field - 返信
    Hi Michael,
    The glass back would definitely work without the black paint. In fact, there are tutorials online that instruct exactly how to do that in order to have a cool transparent glass back look!
    Arthur Shi -
  6. Samsung Galaxy S7 NFCアンテナと充電コイルアセンブリ: 手順 6、 2の画像 1 Samsung Galaxy S7 NFCアンテナと充電コイルアセンブリ: 手順 6、 2の画像 2
    • デバイスからガラスを持ち上げて外します。
  7. Samsung Galaxy S7 NFCアンテナと充電コイルアセンブリ: 手順 7、 2の画像 1 Samsung Galaxy S7 NFCアンテナと充電コイルアセンブリ: 手順 7、 2の画像 2
    • カスタムカットした接着ストリップを使ってバックカバーを再装着する場合は、このガイドを参照してください。
    • イソプロピルアルコールでミッドフレームの表面をクリーニングする場合、ワイヤレス充電コイルにアルコールが飛ばないようにご注意ください。コイルのコーティングはアルコールに接触してしまうと剥がれてしまいます。
    • デバイスの電源を入れて、修理の成果をテストしてください。それから新しい接着剤を装着して、デバイスの本体を組み立てます。
    • 希望に応じて、バックカバーに接着剤を装着しなくても組み立てることができます。大きな接着剤の塊を取り除くとバックカバーがぴったりと閉じます。装着が終わったらバックカバーを温めて圧力でシールをします。防水性はありませんが、この接着剤の役割は防水機能を目的に固定する以上の力があります。
    Apply heat with iOpener/blower or the isopropyl alcohol on the adhesive you want to remove.
    I did not and noticed I peeled off pieces of the paint coating from the cover glass together with the adhesive.
    Eduard - 返信
    Do not hold the glass as shown. I did that, and the glass cracked when I tried to pull the adhesive because the adhesive was on tight. Always keep the glass down on a flat surface so that you don’t apply any bending forces to it.
    blicher - 返信
    I'm sorry to hear that! That's a good suggestion—I'll modify the photo slightly to deter people from holding the glass in the air.
    Arthur Shi -
  8. Samsung Galaxy S7 NFCアンテナと充電コイルアセンブリ, NFC アンテナと充電コイルアセンブリ: 手順 8、 1の画像 1
    • NFCアンテナと充電コイルアセンブリに留められた3.5mmプラスネジを8本外します。
    They made a typo I think its supposed to say 1.5 millimeter instead of 3.5 millimeter.
    KaydenFisher - 返信
    QA sticker over screw on my model (2018). I advise you delicately remove these with something sharp, from the center of the screw outwards. If you stick the screwdriver straight in, the sticker will jam up in the head of the screw and make it much less likely to get a good grip on the screw as it turns, causing it to slip and strip the screw head.
    domarius - 返信
  9. Samsung Galaxy S7 NFCアンテナと充電コイルアセンブリ: 手順 9、 3の画像 1 Samsung Galaxy S7 NFCアンテナと充電コイルアセンブリ: 手順 9、 3の画像 2 Samsung Galaxy S7 NFCアンテナと充電コイルアセンブリ: 手順 9、 3の画像 3
    • スパッジャーの先端を左側アンテナアセンブリの小さなノッチの中に差し込み、フレームからアセンブリを取り出すようにこじ開けます。
    • アンテナアセンブリを取り出します。
  10. Samsung Galaxy S7 NFCアンテナと充電コイルアセンブリ: 手順 10、 2の画像 1 Samsung Galaxy S7 NFCアンテナと充電コイルアセンブリ: 手順 10、 2の画像 2
    • スパッジャーの平面側先端を使って、電話本体から充電コイルアセンブリを持ち上げます。
終わりに
デバイスを再組み立てする際は、これらのインストラクションを逆の順番に従って作業を進めてください。
4 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
en jp
100%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 あなたも貢献してみませんか?
翻訳を始める ›
作成者
1人の作成者と共同作成されました。
Adam O'Camb
メンバー登録日: 04/11/15
196,940 ポイント
416のガイドは作成済み
9 件のコメント
Can you help me with videos ?
amine.thrassers.35 - 返信
Does this also replace the charging port itself?
Adam Cornwell - 返信
Hi Adam, this guide is not for replacing the charging port—the charging port is part of a separate assembly that requires further disassembly to remove.
Adam O'Camb -
Wireless charging stopped working today on my S7 which is out of warranty. Do you know if this wil solve the problem or do I need to tackle it another way?
Jakob - 返信
Without seeing the phone it’s hard to say what the problem is. Replacing this assembly will likely fix any hardware issues related to wireless charging, but won’t help if you have a software issue. It’s probably worth trying a factory reset and looking in to other troubleshooting methods before you open the phone.
Adam O'Camb -
If I remove this and not replace it will my phone still function and charge via standard charge port? Only NFC and wireless charge would be disabled correct?
M CC - 返信
If I were to replace my battery from one from iFIXit, will that battery support wireless charging or no? How would be able to go about making it be a wireless charging one?
_Danny Rojas - 返信
It would have helped immensely if you would have removed the assembly out of the phone to show us what it looks like.
Les Bussing - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 24
過去 30 日: 76
今までの合計 9,397
