メインコンテンツにスキップ
Samsung Galaxy S7 スクリーンの交換
必要な工具と部品
ビデオの概要
  1. Samsung Galaxy S7 スクリーンの交換, リアガラス: 手順 1、 1の画像 1
    • 電話本体を開口するということは防水用シールを破棄するということです。この作業を始める前に、交換用の接着剤を準備してください。
    • 温めたiOpenerをデバイス長辺側の端に沿って約2分間載せます。
    • デバイスを十分に温めるにはiOpenerを複数回に渡って温め、載せる作業を繰り返さなければなりません。iOpenerの使用方法に従って、オーバーヒートにご注意ください。
    • ヘアードライヤやヒートガンも使用もできますが、デバイスを温めすぎないでくださいーOLEDディスプレイと内蔵されたバッテリーはどちらも熱によるダメージを受けやすい性質があります。
    I used a heat gun and heated it a little too much. The color of the rear glass is just a sticker on a clear cover. Due to this I tore the sticker off. Now the back cover is see through, which isn’t a bad thing but the repair was for a customer.
    Kevin Bishop - 返信
    When using the iOpener, you may need more than 30 seconds, especially in compact or low wattage microwaves. Take this slowly, though, and be extremely careful, as it is easy to overheat your iOpener. Remember, you can always heat it up a tad more, but you cannot undo overheating it.
    Jacob Pratt - 返信
    I used an adjustable heat gun and set it to 400 degrees (F). That was enough to seperate the glass without having to worry about exposure times of the heat. The front of the phone was just fine. Just be ready to use a bunch of picks to slide in between because they will be needed this way.
    Ryan Schumerth - 返信
    I went from the bottom center up, using one ifixit tools, one suction cup and one pick.
    Pick just popped in with some minor pressure.
    Laid heat pack along base of phone 2 mins first and worked up slowly, rotating picks as I went. Had to heat iopener over several 30 second bursts
    Lauren Burt - 返信
    This is useless because the phone does not recognize the new battery and will behave like on the old one
    Search for “battery count xda"
    Albert Einstein - 返信
    That is an interesting discovery! Thanks for pointing it out—I’ll have to look into it.
    Even if this is true, replacing the battery should still give restore a significant amount of life, since the max voltage affects a minor amount of the battery’s capacity. If you charge a worn battery and a new battery to the same lower max voltage, the worn battery’s voltage will dip more under use and will be depleted faster.
    Arthur Shi -
    Thanks for the guide! It helped me replace a friend's battery with no problems!
    Darren Crook - 返信
    I will never replace a screen again, and don’t recommend it. Not for phones nowadays. Once upon a time everything was screwed together, and you might even get the same quality or better screen when buying from eBay. And having the phone repaired was nearly the cost of the phone. Now, it’s the reverse. Removing the glued back and screen and cleaning off all the glue for a clean re-seal is an ordeal that takes multiple hours, AND, often the screen you buy on eBay is NOT OLED, but an LCD, and a blurry one at that. And the local phone repair store will replace the screen with an OLED, reliably, same day turn around, for not much more than the cost of an actual OLED screen, because they have the parts in bulk, and the tools and experience to do it quickly. Never again!
    domarius - 返信
    have you ever had one that just wont open at all? i can not get mine to open to replace the battery i have heated with a heat gun and attached suction cup and it will not lift at all
    Carla James - 返信
    Hi Carla,
    I've definitely had that experience before. The adhesive is very strong, and the curved back makes getting the initial seam very difficult. I'd suggest focusing on one small area on the edge. Apply steady force when you pull, and repeat a few times to loosen the adhesive. Eventually it will give and present a small gap.
    Arthur Shi -
  2. Samsung Galaxy S7 スクリーンの交換: 手順 2、 3の画像 1 Samsung Galaxy S7 スクリーンの交換: 手順 2、 3の画像 2 Samsung Galaxy S7 スクリーンの交換: 手順 2、 3の画像 3
    • バックパネルを触って十分に温まっていたら、吸盤カップをデバイスの端付近に取り付けます。カーブの入った端の上には装着しないでください。
    • 吸盤カップはガラスパネルのカーブが入った部分には適しません。
    • デバイスのバックカバーにひび割れが入っている場合は、吸盤カップが装着できません。強力なテープやスーパーボンドで吸盤カップを固定してからカップを持ち上げます。これで上手くいけば、次の手順に進んでください。
    • 吸盤カップが持ち上がったら、リアガラスの下に開口ピックを差し込みます。
    • 強い力を加えたり、メタル製の開口ピックを使用するとリアガラスが割れてしまいます。
    • カーブしたガラスのため、デバイスの隙間に平行に挿入するよりも上むきに押し上げながら挿入します。
    • うまくいかない場合は、さらに熱を当てて接着剤を柔らかくします。接着剤はすぐに冷たくなるため、作業は繰り返し、素早く行います。
    • 次の手順のオプションとして、開口ピックが挿入できたら粘着力を弱めるため、隙間にイソプロピルアルコールを数滴注入します。
    Because of the metal lip around the phone the picks were to thick to get under the glass. Couldn’t get the glue loose enough with the iOpener or the glass lifted high enough with the suction cup despite using a lot of heat and stength on the suction. Ended up having to use a thin piece of metal to get the first separaration. After that the picks are ok to use.
    loadinglevelone - 返信
    This step is certainly giving me trouble. I don’t have enough hands to be able to both form the space and to insert the pick. In order to even form the space, I need to use the double-sided plastic scraper-thing.
    Damian Amerman-Smith - 返信
    Turns out that three hands was the answer. I had my dad insert the pick while I pried open a gap, and it was smooth sailing from there.
    How do you pull on the suction cup? I.e. what's the right technique to pull up the suction cup? Just pulling up is going to lift the entire phone, unless I had some kind of double sided suction cup up keep the phone stuck to the table.
    Thank you
    A X - 返信
    I'm going to try it Jerry rig everythings technique. https://m.youtube.com/watch?v=kHzmFPoZbC... unfortunately every iFixit video seems to use the clamp which seems like an oversight for a tutorial. But it is not fair for me to be too annoyed since they have really good repair kits and the repair guides are nice.
    A X -
  3. Samsung Galaxy S7 スクリーンの交換: 手順 3、 1の画像 1
    • ガラスの間に開口ピックがしっかりと挿入できたら、さらに接着剤を柔らかくするためiOpenerを再度温めてデバイスの上に載せます。
    Use a heat gun or hair dryer to soften the adhesive to remove the back cover. The Iopener that you heat up with the microwave takes a very long to accomplish the same task.
    michael kotarba - 返信
    Keep the heat gun in motion at all times and check the surface temperature of the phone with your hand every few seconds to ensure it does not overheat the plastic and glass and electronics. Use several blue guitar picks to brake the seal of the cover once you have softened the adhesive and popped the seal initially with the suction cups.
  4. Samsung Galaxy S7 スクリーンの交換: 手順 4、 2の画像 1 Samsung Galaxy S7 スクリーンの交換: 手順 4、 2の画像 2
    • 開口ピックをデバイス横に沿って下に向けてスライドし、接着剤を切断します。
    • ピックの先端が隙間からスリップして飛び出さないようにゆっくりとスライドします。スライド作業が困難になったら、iOpenerを再び温めて、接着剤を柔らかくしてください。
    • 次の手順に進むため、開口ピックを下側の位置に残したまま、2枚目のピックを準備してください。最初のピックを隙間に残しておくことで、切断した接着剤が再装着するのを防ぎます。
  5. Samsung Galaxy S7 スクリーンの交換: 手順 5、 3の画像 1 Samsung Galaxy S7 スクリーンの交換: 手順 5、 3の画像 2 Samsung Galaxy S7 スクリーンの交換: 手順 5、 3の画像 3
    • デバイス残りの3辺においても同じ手順を繰り返して、接着剤を温めて切断します。
    • 各サイドに開口ピックを残してください。接着剤が再装着するのを防いでくれます。
    At about this stage, as I was working on the fourth side, the layer of black paint on the inside of the glass started to separate from the glass, near the edge. I may have overheated the phone (I used a heat gun). Most of the paint layer ended up left behind, attached to the body of the phone, as the glass came away - along with the lens covers of the camera and flash. I removed and discarded as much of the paint as I could using tweezers, a spudger, and cautious heating with the heat gun. I hope the back glass will work OK without it; a clear back cover will be a distinctive design feature! If not I’ll have to get a new one. (Note, some battery repair kits from other suppliers such as Amazon include a replacement back glass, which would help with this issue).
    Michael Field - 返信
    Hi Michael,
    The glass back would definitely work without the black paint. In fact, there are tutorials online that instruct exactly how to do that in order to have a cool transparent glass back look!
    Arthur Shi -
  6. Samsung Galaxy S7 スクリーンの交換: 手順 6、 2の画像 1 Samsung Galaxy S7 スクリーンの交換: 手順 6、 2の画像 2
    • デバイスからガラスを持ち上げて外します。
  7. Samsung Galaxy S7 スクリーンの交換: 手順 7、 2の画像 1 Samsung Galaxy S7 スクリーンの交換: 手順 7、 2の画像 2
    • カスタムカットした接着ストリップを使ってバックカバーを再装着する場合は、このガイドを参照してください。
    • イソプロピルアルコールでミッドフレームの表面をクリーニングする場合、ワイヤレス充電コイルにアルコールが飛ばないようにご注意ください。コイルのコーティングはアルコールに接触してしまうと剥がれてしまいます。
    • デバイスの電源を入れて、修理の成果をテストしてください。それから新しい接着剤を装着して、デバイスの本体を組み立てます。
    • 希望に応じて、バックカバーに接着剤を装着しなくても組み立てることができます。大きな接着剤の塊を取り除くとバックカバーがぴったりと閉じます。装着が終わったらバックカバーを温めて圧力でシールをします。防水性はありませんが、この接着剤の役割は防水機能を目的に固定する以上の力があります。
    Apply heat with iOpener/blower or the isopropyl alcohol on the adhesive you want to remove.
    I did not and noticed I peeled off pieces of the paint coating from the cover glass together with the adhesive.
    Eduard - 返信
    Do not hold the glass as shown. I did that, and the glass cracked when I tried to pull the adhesive because the adhesive was on tight. Always keep the glass down on a flat surface so that you don’t apply any bending forces to it.
    blicher - 返信
    I'm sorry to hear that! That's a good suggestion—I'll modify the photo slightly to deter people from holding the glass in the air.
    Arthur Shi -
  8. Samsung Galaxy S7 スクリーンの交換, NFC アンテナと充電コイルアセンブリ: 手順 8、 1の画像 1
    • NFCアンテナと充電コイルアセンブリに留められた3.5mmプラスネジを8本外します。
    They made a typo I think its supposed to say 1.5 millimeter instead of 3.5 millimeter.
    KaydenFisher - 返信
    QA sticker over screw on my model (2018). I advise you delicately remove these with something sharp, from the center of the screw outwards. If you stick the screwdriver straight in, the sticker will jam up in the head of the screw and make it much less likely to get a good grip on the screw as it turns, causing it to slip and strip the screw head.
    domarius - 返信
  9. Samsung Galaxy S7 スクリーンの交換: 手順 9、 3の画像 1 Samsung Galaxy S7 スクリーンの交換: 手順 9、 3の画像 2 Samsung Galaxy S7 スクリーンの交換: 手順 9、 3の画像 3
    • スパッジャーの先端を左側アンテナアセンブリの小さなノッチの中に差し込み、フレームからアセンブリを取り出すようにこじ開けます。
    • アンテナアセンブリを取り出します。
  10. Samsung Galaxy S7 スクリーンの交換: 手順 10、 2の画像 1 Samsung Galaxy S7 スクリーンの交換: 手順 10、 2の画像 2
    • スパッジャーの平面側先端を使って、電話本体から充電コイルアセンブリを持ち上げます。
  11. Samsung Galaxy S7 スクリーンの交換, バッテリーコネクタ: 手順 11、 2の画像 1 Samsung Galaxy S7 スクリーンの交換, バッテリーコネクタ: 手順 11、 2の画像 2
    • スパッジャーの平面側先端を使って、バッテリーコネクタの接続を外します。
  12. Samsung Galaxy S7 スクリーンの交換, スクリーン: 手順 12、 2の画像 1 Samsung Galaxy S7 スクリーンの交換, スクリーン: 手順 12、 2の画像 2
    • スパッジャーの平面側先端を使って、ディスプレイとデジタイザーコネクタの接続を外します。
  13. Samsung Galaxy S7 スクリーンの交換: 手順 13、 1の画像 1
    • iOpenerを準備してデバイスの長辺側に約2分間載せます。
    • デバイスを十分に温めるにはiOpenerを数回に渡って温めて載せる作業を繰り返さなければなりません。オーバーヒートを防ぐため、iOpenerの使用方法に従ってください。
    • ディスプレイに留められた接着剤はバックカバーに留められている接着剤に比べて強力です。必要に応じて、接着剤を弱めるためにヘアドライヤやヒートガンに切り替えて十分な熱を当ててください。
    To me, it seems hard not to damage the screen in the process of the consequtive steps. Tiny shiny shards to vacuum.
    I notice in video instructions, removal of battery and motherboard, opening pick inserted from inside out, less or no screen debris caused, but commented is, not to remove the screen unless it is already broken.
    Eduard - 返信
    STOP. As noted above…Use the Video Method. When I was finally able to begin detaching the screen, the glass separated off, while the screen remained attached. This action sheered of the connection to a front-facing sensor which remained firmly embedded by adhesive to the front glass.
    In retrospect, removing the main board, heating and using picks from the back worked with somewhat less effort and better control.
    Jeffry Long - 返信
  14. Samsung Galaxy S7 スクリーンの交換: 手順 14、 3の画像 1 Samsung Galaxy S7 スクリーンの交換: 手順 14、 3の画像 2 Samsung Galaxy S7 スクリーンの交換: 手順 14、 3の画像 3
    • スクリーンを触って十分に温まったら、吸盤カップをデバイス本体の温めた側の端付近に取り付けてください。
    • ディスプレイ全体にひび割れが広がっている場合は吸盤カップが装着できないことがあります。ディスプレイを強力テープで持ち上げたり、吸盤カップにスーパーボンドを付けると上手くいきます。
    • 吸盤カップを持ち上げて、ディスプレイアセンブリの下にできた隙間に開口ピックを差し込みます。
    insert opening pick down ~30 degrees to go between screen and frame. Parallel to glass went between glass and screen.
    Eduard - 返信
  15. Samsung Galaxy S7 スクリーンの交換: 手順 15、 1の画像 1
    • ディスプレイの下に開口ピックを挿入したら、ディスプレイの接着剤を柔らかくするため、iOpenerを再度温めてください。
  16. Samsung Galaxy S7 スクリーンの交換: 手順 16、 2の画像 1 Samsung Galaxy S7 スクリーンの交換: 手順 16、 2の画像 2
    • 開口ピックをデバイス横から下側に向けて、接着剤を切り込みながらスライドします。
    • 右側の中間地点少し上にディスプレイケーブルが搭載されています。ピックを深くまで差し込んでスライドすると引っかかることがあります。
    • 開口ピックの先端が隙間からスリップして飛び出さないように、ゆっくりと丁寧にスライドします。作業が困難な場合はiOpener を再度温めて該当箇所に当ててください。
    • ピックを下部に残したまま、2枚目の開口ピックを準備して次の手順に進みます。挿入したまま残しておくことで、接着剤が再装着するのを防ぐことができます。
  17. Samsung Galaxy S7 スクリーンの交換: 手順 17、 3の画像 1 Samsung Galaxy S7 スクリーンの交換: 手順 17、 3の画像 2 Samsung Galaxy S7 スクリーンの交換: 手順 17、 3の画像 3
    • 残り3辺についても、iOpenerで温めて開口ピックで切断する前の手順を繰り返します。
    • 開口ピックを各サイドに残したまま、接着剤の再装着を防ぎます。
    • デバイスの上部もしくは下部では深くまでピックを挿入しないでください。フロント向きセンサーや上部のスピーカーアセンブリ、下部の容量ボタンにダメージを与えてしまいます。
  18. Samsung Galaxy S7 スクリーンの交換: 手順 18、 2の画像 1 Samsung Galaxy S7 スクリーンの交換: 手順 18、 2の画像 2
    • ディスプレイケーブルと反対側のディスプレイ側を持ち上げます。繋がったケーブルを蝶番のようにしてデバイスが開きます。
    Screen was adhered to underlying frame, around the battery gap. Pry into and heat that adhesive to loosen the screen there. To me, it seems hard not to damage the screen in the process. Tiny shiny shards to vacuum.
    Eduard - 返信
  19. Samsung Galaxy S7 スクリーンの交換: 手順 19、 2の画像 1 Samsung Galaxy S7 スクリーンの交換: 手順 19、 2の画像 2
    • ディスプレイをミッドフレームからゆっくりと持ち上げて、ディスプレイコネクタをミッドフレームの穴を通して引き上げます。
    • ディスプレイを取り出します。
    Much of the back part of the display was also glued to the chassis on my phone. Be very careful when removing the bottom adhesive around the capacitive buttons - I thought what I was peeling off was glue and adhesive, but in fact they were the buttons themselves. I inadvertently damaged both and rendered them useless.
    cness846 - 返信
    Hmmm ok… this isn’t what I see. I seem to have peeled off the glass layer from the display itself. I have a silver looking display to yet remove before I see any of the frame or ribbon cable shown in the picture above. And yet there was indeed black adhesive strip that I was peeling away during this process, so I thought I was doing the right thing.
    domarius - 返信
    Solved it. I nearly gave up; I had heated it till the frame was almost too hot to touch, not happy with that, as components could be damaged. Also I couldn’t find anywhere to get a spuger or guitar pick into around the edge, it was all too narrow. But eventually I found I could get a guitar pick under the cables at the top of the screen and start peeling from that direction. Also the screen would crack and splinter at this point, so it was important to move slowly and keep the pick flush and not curl it up too much, to crack as little as possible. And of course, minding the part where the cable is connected on the top right. And I covered it in sticky tape because it was splintering everywhere during this process.
    They’re not kidding - the screen does not survive removal during this process, so it better already be destroyed when you do. In fact I even had little pieces of “display” still stuck to the adhesive when I was done. A foldable display this ‘aint.
    domarius - 返信
    Also I found the best way to clean off the adhesive, every last bit, was to scrape as much as I could off with the guitar pick, then alternate with a cotton swab with rubbing alcohol, a pin to scrape off tiny bits, and a tissue to wipe off loose bits, over and over, to get every last little bit out so the new adhesive will stick cleanly.
    domarius - 返信
  20. Samsung Galaxy S7 スクリーンの交換: 手順 20、 1の画像 1
    • 詳細なスクリーン用接着剤の装着方法について、このリンクを参照してください。
    • 新しいディスプレイを装着する前に、必ずフレームから残りの接着剤を綺麗に取り除いてください。特にひび割れの場合は小さなガラスの破片を完全に取り除いてください。
    • フレームから接着剤とガラスを綺麗に取り除いた後、装着エリアに90%以上のイソプロピルアルコールとリントフリーの布またはコーヒーフィルターで拭き取ってください。前後に拭くのではなく、同じ方向に向けて動かします。
    • この作業をすることで、残りの接着剤を取り除き、新しいディスプレイを装着する表面の準備ができます。
    • フレームが曲がっていたり接着剤やガラスが残っている場合、新しい交換用ディスプレイが正しく装着できず、ダメージを与えてしまいます。
終わりに
デバイスを再組み立てする際は、リアカバーに接着剤を装着し、これらのインストラクションを逆の順番に従って作業を進めてください。
185 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
en jp
100%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 あなたも貢献してみませんか?
翻訳を始める ›
作成者
3人の作成者と共同で作成されました。
Sam Goldheart
メンバー登録日: 10/18/12
465,777 ポイント
538のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
135 メンバー
16,817のガイドは作成済み
29 件のコメント
The screen replacement went smooth. I just wish it included the adhesive. I didn't see the note where the adhesive needed to be ordered in addition to the screen. Otherwise everything went well.
Thanks
march11934 - 返信
Samsung s7 ekran değişimi orjinal parça satın aldığınız zaman bu kadar uğraşmanıza gerek yok.
Yapıştırıcı da sadece arka kapağı yapıştırmak için gerekli oluyor
CitrusMobil -
For the price of the screen, I can replace it in a Samsung repair center...
I just need to replace the glass, not all of the AMOLED touch screen... :-( Sorry but this didn't help me.
Darky - 返信
How much cost u paid to service centre for original display for samsung s7
Durgaprasad -
You can not replace just the glass without special equipment (hot plate, laminator etc.)
Dinan Blueje -
I'm wanting to help my friend do this but I don't have a heat gun. Would a blow dryer work to loosen the glue or does it need to be hotter? He got a quote for 200 from a shop to fix it but they said it takes a month…lame! I've replaced screens in many tables and phones and I have all the necessary tools other than the heat gun and the replacement screen components obviously.
Adam Bacon - 返信
@Adam Bacon Heat guns are quite inexpensive. The model she uses in this video runs about $20 or less in most shops. A blow dryer may work, but it’s difficult to say for certain. The adhesive Samsung uses is pretty robust. If you find yourself fixing a lot of devices you should really consider investing in a heat gun.
E West -
I did this repair. A heat gun isn’t really hot enough to remove the screen without destroying it. A hair drying isn’t going to touch the glue.
armand -
Use a hair dryer and a spudger and a iSesamo to pop that bad boy off. No sense in buying a heat gun for one use.
Chris Pavlik -
It works great I got my Galaxy S7 apart within a hour using a hair dryer
Mikee Sanchez -
I just want to add that if you only need to replace the glass, this is not the guide for you, and the difficulty rating is a 10 of 10. What I would do to replace just the front glass, is to avoid all these steps, and remove the glass from the front. Do not attempt to remove the AMOLED screen, it will shatter in the process of removing it. You will notice in this video, the screen shatters in the bottom left of the phone, behind the glass.
The other issue is that the glass is laminated to a filter, which is backwards from many screens, where the LCD panels are laminated to the filter, and the screen floats. When you buy a replacement glass, you will need one that has the laminated filter attached, or you will need to figure out a way to separate the two pieces. (I could not).
armand - 返信
armand what did you use to remove the back, i’ve tried the hair dryer with no luck. Thanks;
Maria
nena_boricua52 -
I would also like to point out that both the front and back glass are extremely brittle. If you broke your glass, because the phone landed on its side, then check for spurs. The smallest protrusion will shatter the glass while applying pressure to seal the adhesive application. I had the tiniest of a protrusion, and the back glass exploded. Thankfully, those are cheap.
armand - 返信
Thank you very much for good instruction
Vedrasco Victor Vasili - 返信
Guide help, the included heat pack did not. I ended up buying a heat gun instead. Took my time instead of rush it like some places do or they would just replace your phone all together, which is not what you paid for really. Def was tedious.
Quang Pham - 返信
Really a good guide!
Maybe it could be cool if with the display assembly comes also the rear glass.. because there is a very high probability that it will damage quickly (during the opening)
So, for those who are going to repair their Samsung Galaxy S7.. just be careful with the back glass!
Thank you all ;)
Tishanth Sinnathamby - 返信
where we can find lcd replacement in good price ?
morpheous22138 - 返信
Running into bit of an issue, my screen is broken. At the moment I’m finding ways to turn it back on, restart, hard reset and etc. Nothing that will actually turn it all the way off so I can begin taking off the back panel.
Austin Pimentel - 返信
The safest method would probably be to let the battery run down, to ensure it doesn’t turn back on and short-circuit something. Good luck!
Sam Goldheart -
Étape 2: Quand la panneau arrière est chaud au toucher, posez une ventouse le plus près possible du bord chauffé de l'iPhone, tout en évitant le bord incurvé.
Cette fiche concerne un Samsung Galaxy S7 ? et vous mentionné un iPhone
Fr C - 返信
Bonjour Fr C !
Un grand merci pour les yeux de lynx et la remarque. J’ai adapté la traduction. N’hésitez pas à corriger directement la prochaine fois que vous remarquez une erreur.
Bonne journée et à bientôt !
Claire Miesch -
well done, easy to do the job.
i used a heat gun instead the iOpener
ultimo99
antonio esposito - 返信
I had really hard time finding a way to lift the front screen, so I put the flat end of a spudger through display cable opening from the side of the edge and calmly pressed on the screen from underneath.
Rafal Krawczyk - 返信
Can I use b7000 to glue the display?
Thanks
Alex P - 返信
Guten Tag
Nach dem Tauschen des Display zeigt es keine Bilder an… Der Touch hingegen funktioniert. Ich habe eine Original Samsung Display gekauft und verbaut. Was könnte da das problem sein?
Ps: Habe schon erfahrung mit mit Displaytauschen.
GitsEine? - 返信
I bought the complete repair kit since it had the adhesive strips. Didn’t need the tools. It would be good to offer the option of getting the repair kit with adhesive strips but no tools. Replacing the screen itself was pretty straightforward and not particularly difficult. As was stated elsewhere, the real difficulty was with the adhesives. Some more detailed instructions on this would be useful. Seems like there were locations where the adhesive strips overlapped and other places where they left a gap. Finally, I got to ask why Samsung ever did the phone back with the glass? These are so incredibly fragile. I have replaced these on S7s, S7Edges, and S8s. I am an engineer and consider this a real design flaw. Is there an after market back in just plain metal or plastic? Other than that, I love these phones.
dmorsenv - 返信
English Below
Hallo,
Een paar jaar geleden had ik het scherm laten vervangen van mijn galaxy s7. Nu heeft het scherm lichte waterschade aan de onderkant, (daar is het een beetje beslagen) en de selfiecamera is ook beslagen. Nu werkt alles helemaal prima, alleen soms is mijn scherm zwart, als ik druk op de bovenkant doet het het weer, of soms moet ik een paar keer met mijn telefoon tegen mijn been slaan en doet het het ook weer. Ik denk dat de aansluiting boven een beetje losjes zit. Het touchscreen werkt gewoon terwijl het scherm zwart is. Dus de lichtjes gaan dan soms niet aan. Kan ik dit denk je zelf fixen zonder een nieuw scherm te kopen?
Guido Sol - 返信
Hi,
A couple years ago I had my screen replaced of my samsung galaxy s7. Now there is some small water damage at the bottom of the screen and the selfiecamera. The screen and camera are still working probably (only the selfie-camera gives vague images). But sometimes the screen is black and when I put pressure on the top of the screen, it is working again. I think it has to do with the connection from the screen to the rest of the phone. The touch screen works when the screen is black. Do you think I can fix this, without buying a new screen?
Guido Sol - 返信
Suggestions concerning difficulties I encountered.
ad. step 14, insert opening pick down ~30 degrees to go between screen and frame. Parallel to glass went between glass and screen.
ad. step 18, screen was adhered to underlying frame, around the battery gap. Pry into and heat that adhesive to loosen the screen there. To me, it seems hard not to damage the screen in the process. Tiny shiny shards to vacuum.
I notice in video instructions, removal of battery and motherboard, opening pick inserted from inside out, less or no screen debris caused, but commented is, no to remove the screen unless it is already broken.
Eduard - 返信
コメントを追加
統計データ:
過去 24時間: 41
過去 7 日: 175
過去 30 日: 754
今までの合計 363,597
