メインコンテンツにスキップ
Samsung Galaxy S10e Wireless Charging Coil Replacement
必要な工具と部品
  1. Samsung Galaxy S10e Wireless Charging Coil Replacement, Heat the back cover: 手順 1、 1の画像 1
    • Opening your phone will compromise its waterproof seals. Have replacement adhesive ready before you proceed, or take care to avoid liquid exposure if you reassemble your phone without replacing the adhesive.
    • Turn your phone off completely before you begin this repair.
    • Prepare an iOpener and heat the back of the phone along the right edge for about two minutes. This will help soften the adhesive securing the back cover.
    • You may need to reheat and reapply the iOpener several times to get the phone warm enough. Follow the iOpener instructions to avoid overheating.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the OLED display and internal battery are both susceptible to heat damage.
  2. Samsung Galaxy S10e Wireless Charging Coil Replacement, Prepare to slice the adhesive: 手順 2、 2の画像 1 Samsung Galaxy S10e Wireless Charging Coil Replacement, Prepare to slice the adhesive: 手順 2、 2の画像 2
    • In the following steps, you'll be cutting through the adhesive securing the back cover.
    • The adhesive is laid out as seen in the first image, which shows the inside of the cover after it has been removed.
    • As seen from the outside of the phone, you'll be slicing through the adhesive in the highlighted areas.
    • The adhesive is the thinnest on the right side of the phone, just below the Bixby button.
  3. Samsung Galaxy S10e Wireless Charging Coil Replacement, Secure a suction cup: 手順 3、 2の画像 1 Samsung Galaxy S10e Wireless Charging Coil Replacement, Secure a suction cup: 手順 3、 2の画像 2
    • Secure a suction cup to the back cover, as close to the heated edge as possible, just under the Bixby button where the adhesive is thinnest.
    • The suction cup will not make a good seal on the curved portion of the glass, so avoid putting it on the very edge.
    • If the phone's back cover is cracked, the suction cup may not stick. Try lifting it with strong tape, or superglue the suction cup in place and allow it to cure so you can proceed.
  4. Samsung Galaxy S10e Wireless Charging Coil Replacement, Create an opening gap: 手順 4、 3の画像 1 Samsung Galaxy S10e Wireless Charging Coil Replacement, Create an opening gap: 手順 4、 3の画像 2 Samsung Galaxy S10e Wireless Charging Coil Replacement, Create an opening gap: 手順 4、 3の画像 3
    • Prop up the heated edge of the phone on something that is about 0.5 inches (13 mm) thick. This will angle the phone so that the opening tool is easier to insert.
    • Lift the back cover's right edge with your suction cup, opening a slight gap between the back cover and the frame.
    • This may require a significant amount of force. If you have trouble, apply more heat to further soften the adhesive, and try again. The adhesive cools very fast, so you may need to heat it repeatedly.
    • If you're using an iOpener, follow the heating instructions to avoid overheating it, or the gel pack may burst.
    • Press the edge of an opening tool into the gap.
    • The rear glass can break if you use too much force or attempt to pry with metal tools.
  5. Samsung Galaxy S10e Wireless Charging Coil Replacement: 手順 5、 3の画像 1 Samsung Galaxy S10e Wireless Charging Coil Replacement: 手順 5、 3の画像 2 Samsung Galaxy S10e Wireless Charging Coil Replacement: 手順 5、 3の画像 3
    • Slide the opening tool along the right edge of the phone to slice through the adhesive securing the back cover.
  6. Samsung Galaxy S10e Wireless Charging Coil Replacement: 手順 6、 2の画像 1 Samsung Galaxy S10e Wireless Charging Coil Replacement: 手順 6、 2の画像 2
    • Insert an opening pick into the edge next to the opening tool. Leave the pick here to prevent the separated glue from re-adhering.
  7. Samsung Galaxy S10e Wireless Charging Coil Replacement: 手順 7、 1の画像 1
    • Apply a heated iOpener to the top edge of the phone for two minutes.
  8. Samsung Galaxy S10e Wireless Charging Coil Replacement: 手順 8、 3の画像 1 Samsung Galaxy S10e Wireless Charging Coil Replacement: 手順 8、 3の画像 2 Samsung Galaxy S10e Wireless Charging Coil Replacement: 手順 8、 3の画像 3
    • Insert an opening pick near the top right corner of the phone and slide it around the corner and across the top edge of the phone.
    • The glued area is larger here, so you'll need to insert your pick farther into the phone to separate it.
    • Leave the opening pick in place to prevent the adhesive from re-adhering.
  9. Samsung Galaxy S10e Wireless Charging Coil Replacement: 手順 9、 1の画像 1
    • Apply a heated iOpener to the left edge of the phone for two minutes.
  10. Samsung Galaxy S10e Wireless Charging Coil Replacement: 手順 10、 3の画像 1 Samsung Galaxy S10e Wireless Charging Coil Replacement: 手順 10、 3の画像 2 Samsung Galaxy S10e Wireless Charging Coil Replacement: 手順 10、 3の画像 3
    • Insert a new opening pick near the top left corner and slide it along the left edge of the phone.
    • Again, leave the opening pick in place in the left edge of the phone to prevent the adhesive from resealing.
  11. Samsung Galaxy S10e Wireless Charging Coil Replacement: 手順 11、 1の画像 1
    • Apply a heated iOpener to the bottom edge of the phone for two minutes.
  12. Samsung Galaxy S10e Wireless Charging Coil Replacement: 手順 12、 3の画像 1 Samsung Galaxy S10e Wireless Charging Coil Replacement: 手順 12、 3の画像 2 Samsung Galaxy S10e Wireless Charging Coil Replacement: 手順 12、 3の画像 3
    • Insert an opening pick near a bottom corner of the phone, and slide it along the bottom edge of the phone to separate the adhesive there.
    • The glued area is larger here, so you'll need to insert your pick farther into the phone to fully separate it.
  13. Samsung Galaxy S10e Wireless Charging Coil Replacement: 手順 13、 3の画像 1 Samsung Galaxy S10e Wireless Charging Coil Replacement: 手順 13、 3の画像 2 Samsung Galaxy S10e Wireless Charging Coil Replacement: 手順 13、 3の画像 3
    • Use the opening picks to very carefully pry up the back cover.
    • If you encounter any resistance, stop prying and use an opening pick to cut any remaining adhesive.
    • Remove the back cover.
  14. Samsung Galaxy S10e Wireless Charging Coil Replacement: 手順 14、 1の画像 1
    • Follow this guide to reinstall the back cover and replace the adhesive.
    • Be sure to turn on your phone and test your repair before installing new adhesive and resealing the phone.
    • If desired, you may reinstall the back cover without replacing the adhesive. Remove any large chunks of adhesive that might prevent the back cover from sitting down flush. After installation, heat the back cover and apply pressure to secure it. It won't be waterproof, but the leftover adhesive is usually more than strong enough to hold.
  15. Samsung Galaxy S10e Wireless Charging Coil Replacement, Remove the midframe: 手順 15、 1の画像 1
    • Remove the eight 3.9 mm Phillips screws securing the upper midframe to the phone.
  16. Samsung Galaxy S10e Wireless Charging Coil Replacement: 手順 16、 2の画像 1 Samsung Galaxy S10e Wireless Charging Coil Replacement: 手順 16、 2の画像 2
    • Slide an opening pick under the bottom right corner of the upper midframe to separate the adhesive holding it to the lower midframe.
  17. Samsung Galaxy S10e Wireless Charging Coil Replacement: 手順 17、 2の画像 1 Samsung Galaxy S10e Wireless Charging Coil Replacement: 手順 17、 2の画像 2
    • Insert the point of a spudger in the small cutout on the right edge of the plastic part of the upper midframe, near the Bixby button.
    • Use the point of the spudger to pry the midframe up from the phone chassis.
  18. Samsung Galaxy S10e Wireless Charging Coil Replacement: 手順 18、 1の画像 1
    • Lift the midframe by the plastic section and remove it from the phone.
    • To reinstall, first insert the top edge of the assembly into the phone's frame, and then gently press down on the rest of the assembly to snap it into place.
  19. Samsung Galaxy S10e Wireless Charging Coil Replacement, Loosen the wireless charging coil: 手順 19、 1の画像 1
    • Apply a heated iOpener to the top half of the midframe for one minute.
  20. Samsung Galaxy S10e Wireless Charging Coil Replacement: 手順 20、 2の画像 1 Samsung Galaxy S10e Wireless Charging Coil Replacement: 手順 20、 2の画像 2
    • Use an opening tool to gently pry up the wireless charging coil's contact pad from the midframe.
    • The pad is heavily adhered to the midframe. If you need to, you can apply some high concentration (>90%) isopropyl alcohol to help loosen it.
  21. Samsung Galaxy S10e Wireless Charging Coil Replacement: 手順 21、 3の画像 1 Samsung Galaxy S10e Wireless Charging Coil Replacement: 手順 21、 3の画像 2 Samsung Galaxy S10e Wireless Charging Coil Replacement: 手順 21、 3の画像 3
    • Slowly peel the wireless charging coil away from the midframe.
  22. Samsung Galaxy S10e Wireless Charging Coil Replacement, Remove the wireless charging coil: 手順 22、 3の画像 1 Samsung Galaxy S10e Wireless Charging Coil Replacement, Remove the wireless charging coil: 手順 22、 3の画像 2 Samsung Galaxy S10e Wireless Charging Coil Replacement, Remove the wireless charging coil: 手順 22、 3の画像 3
    • Thread the wireless charging coil's contact pad out of its midframe cutout.
    • Remove the wireless charging coil.
    • During reassembly, use some double-sided Tesa tape to affix the contact pad onto the midframe.
    • Compare your new replacement part to the original part. You may need to transfer remaining components or remove adhesive backings from the new part before installing it.
終わりに
After you've completed the repair, follow this guide to test your repair.
作成者
1人の作成者と共同作成されました。
Arthur Shi
メンバー登録日: 01/03/18
257,458 ポイント
529のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
141 メンバー
17,893のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 16
過去 30 日: 60
今までの合計 2,060
