メインコンテンツにスキップ
Samsung Galaxy Note5 Display Replacement
必要な工具と部品
  1. Samsung Galaxy Note5 Display Replacement, SIM Card Tray: 手順 1、 1の画像 1
    • Insert a SIM Ejector Tool into the small hole on the left side of the top edge of the device.
    • Press down until the SIM Card Tray begins to protrude out of the device.
  2. Samsung Galaxy Note5 Display Replacement: 手順 2、 1の画像 1
    • Remove the SIM Card Tray from the slot.
  3. Samsung Galaxy Note5 Display Replacement, Display: 手順 3、 1の画像 1
    • Heat the back of the device with a heat gun for two minutes.
  4. Samsung Galaxy Note5 Display Replacement: 手順 4、 1の画像 1
    • Once the device is very warm to the touch, place a suction cup near the bottom of the back of the device.
    • Make sure to place the suction cup on the flat part of the glass.
    • Gently pull upwards on the suction cup to separate the rear glass from the body of the phone.
    • While pulling upwards, insert a pick under the rear glass
    Ouch Didn't get it hot enough? Hopefully you ordered the back plate too, luckily they ain't too expensive
    Tuan Bui - 返信
  5. Samsung Galaxy Note5 Display Replacement: 手順 5、 1の画像 1
    • Keeping the pick under the rear glass, move the pick along the bottom edge of the device to cut the adhesive.
  6. Samsung Galaxy Note5 Display Replacement: 手順 6、 1の画像 1
    • Repeat the previous heating and cutting procedure for the remaining three sides of the phone.
    • Leave a pick on each side as you continue to the next to prevent the adhesive from resealing.
  7. Samsung Galaxy Note5 Display Replacement: 手順 7、 1の画像 1
    • Once all adhesive has been cut, gently lift up the rear glass to remove it.
  8. Samsung Galaxy Note5 Display Replacement: 手順 8、 1の画像 1
    • Remove the S-Pen from the bottom of the device.
  9. Samsung Galaxy Note5 Display Replacement: 手順 9、 2の画像 1 Samsung Galaxy Note5 Display Replacement: 手順 9、 2の画像 2
    • Remove 20 5mm screws with a Phillips #1 Screwdriver.
    Phillips #0 in my particular case?
    Emmanuel Garcia - 返信
  10. Samsung Galaxy Note5 Display Replacement: 手順 10、 3の画像 1 Samsung Galaxy Note5 Display Replacement: 手順 10、 3の画像 2 Samsung Galaxy Note5 Display Replacement: 手順 10、 3の画像 3
    • Grip the back of the device and press down on the white square to remove the middle housing.
  11. Samsung Galaxy Note5 Display Replacement: 手順 11、 1の画像 1
    • Loosen the two signal cable connectors.
    Not the ones at the bottom but the ones connected to the mainboard
  12. Samsung Galaxy Note5 Display Replacement: 手順 12、 3の画像 1 Samsung Galaxy Note5 Display Replacement: 手順 12、 3の画像 2 Samsung Galaxy Note5 Display Replacement: 手順 12、 3の画像 3
    この手順で使用する道具:
    • To disconnect flexes, carefully pull up on the exposed tab with tweezers.
    • Disconnect the battery flex.
    • Disconnect the earpiece flex.
    There‘s a bunch more flex cables to disconnect that are not shown here. Refer to Mainboard Replacement Guide for further details.
  13. Samsung Galaxy Note5 Display Replacement: 手順 13、 1の画像 1
    • Remove the teal navigation button flex.
  14. Samsung Galaxy Note5 Display Replacement: 手順 14、 1の画像 1
    • Gently lift up the motherboard from the top end to remove.
    • Make sure all flexes are disconnected before removing the motherboard. If the motherboard does not easily detach, remove any connected flexes.
  15. Samsung Galaxy Note5 Display Replacement: 手順 15、 3の画像 1 Samsung Galaxy Note5 Display Replacement: 手順 15、 3の画像 2 Samsung Galaxy Note5 Display Replacement: 手順 15、 3の画像 3
    • With the motherboard removed, slowly pry off the battery with tweezers, starting at the bottom.
    • Be careful not to puncture the battery as this could cause permanent damage.
    I use a curled plastic guitar pick to get underneath the battery. It’s a really bad idea to use metal tools for this.
    Bryan Rought - 返信
    +1 here, I used the plastic spudger, still a bit sketchy without heating. i guess a little bit of heat from the screen side would help soften the adhesive
    Jimmy Beaudoin -
  16. Samsung Galaxy Note5 Display Replacement: 手順 16、 1の画像 1
    • Heat the display for two minutes with a heat gun.
  17. Samsung Galaxy Note5 Display Replacement: 手順 17、 1の画像 1
    • Once the display is very warm to the touch, slide a pick between the LCD and the LCD shield on the bottom edge of the device.
    • Slide the pick across the bottom to cut through the adhesive.
  18. Samsung Galaxy Note5 Display Replacement: 手順 18、 1の画像 1
    • The display is now removed.
終わりに
39 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Alexander Laucius
メンバー登録日: 04/19/18
1,590 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team S25-G17, Maness Spring 2018 Cal Poly, Team S25-G17, Maness Spring 2018人のメンバー
CPSU-MANESS-S18S25G17
4 メンバー
5のガイドは作成済み
6 Guide Comments
Worked like a charm
Ronald Sapp - 返信
How does one bond everything back together?
lcplthomasc - 返信
I am working in fixing my own Note 5. I have heard that double-sided tape made specifically for this task are best. You can find different options here: https://www.magazingsm.ro/adeziv-geam-si...
Cristina -
I have now replaced the display on my Note 5 and actually I didn’t even use the glue I bought. The original glue is quite a lot and the new display comes with glue on the back of it. Thanks again, Alexander, for your helpful instructions!
Cristina -
This was very helpful. Many thanks to the author. may God add many years to his life.
Peterson - 返信
You say no u hing about being careful about the switches ribbon cables or thr push button. I guess you assume that it come as part of the screen assembly. Will it doesn't. Complete moron to leave a step out of the instructions.
Dick foru - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 19
過去 30 日: 122
今までの合計 25,396
