メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Samsung Galaxy Note 4 Display Assembly Replacement
必要な工具と部品
ビデオの概要
  1. Samsung Galaxy Note 4 Display Assembly Replacement, Display Assembly: 手順 1、 1の画像 1
    • NOTE: It is suggested to remove the battery, S Pen, SD Card, and SIM card (if your phone uses a SIM card).
    • Begin by heating the edges of the screen. The adhesive on the Galaxy Note 4 is weaker than on newer generations and will release easier, requiring less heat and prying.
    FixBotに聞いてみる
    コメントを追加
  2. Samsung Galaxy Note 4 Display Assembly Replacement: 手順 2、 1の画像 1
    • Slowly work your way around the edges of the screen with a pry tool or pick.
    • Work your way around the top and sides of the device, and very carefully approach the adhesive on the bottom of the phone. The Galaxy Note 4's touch-sensitive pads lay in the way of your opening picks and it is very easy to sever them.
    FixBotに聞いてみる
    コメントを追加
  3. Samsung Galaxy Note 4 Display Assembly Replacement: 手順 3、 1の画像 1
    • Insert the Jimmy underneath the LCD to cut the adhesive in the middle part. The adhesive is strong so make sure you are underneath the copper insulation before separating.
    FixBotに聞いてみる
    コメントを追加
  4. Samsung Galaxy Note 4 Display Assembly Replacement: 手順 4、 3の画像 1 Samsung Galaxy Note 4 Display Assembly Replacement: 手順 4、 3の画像 2 Samsung Galaxy Note 4 Display Assembly Replacement: 手順 4、 3の画像 3
    • Notice 1: The adhesive is in the red line.
    • Notice 2: If you insert the spudger from right side, keep the length of the tool in less than 2.2cm, which is for avoiding damaging the home button flex.
    • Notice 3: If you insert the spudger from left side, keep the length of the tool in less than 4.4cm for the same reason.
    FixBotに聞いてみる
    コメントを追加
  5. Samsung Galaxy Note 4 Display Assembly Replacement: 手順 5、 2の画像 1 Samsung Galaxy Note 4 Display Assembly Replacement: 手順 5、 2の画像 2
    • Notice 4: Pay attention to the part with LCD screen flex. When you cut the adhesive, leave the top part alone to avoid damage the flex. But if it's the broken screen, you don't need to worry so much.
    • Be careful with the bottom side because there are the soft keys.
    • If the adhesive in the red line don't function any more when you place the new LCD screen, you can choose to use the 3M double side tape. It can help to fasten the new screen together with the LCD screen sticker.
    FixBotに聞いてみる
    コメントを追加
  6. Samsung Galaxy Note 4 Display Assembly Replacement: 手順 6、 1の画像 1
    • Release S Pen touch sensor film connector and LCD screen connector.
    FixBotに聞いてみる
    コメントを追加
  7. Samsung Galaxy Note 4 Display Assembly Replacement: 手順 7、 1の画像 1
    • Separate the LCD screen from the frame of the device.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
161 の人々がこのガイドを完成させました。
作成者
11人の作成者と共同で作成されました。
Sophia
メンバー登録日: 03/25/14
43,911 ポイント
62のガイドは作成済み
42件のガイドコメント
Can I use a hair dryer instead of a heat gun
charlie - 返信 共有
Yes, a hair dryer on the hot setting will work in place of a heat gun for this repair. You may have to heat it a bit longer but you will be able to tell when the adhesive is warm enough, as it will begin to separate a lot easier.
Brad - 返信 共有
Here in our tech community we have been discussing the foil under the LCD. We are doing more testing but there might be a connection with the foil functioning in conjunction with S-Pen and AirView. Can anyone confirm this?
Kevin Henson - 返信 共有
Yes, the foil permits the s pen to function. If you have the part of the foil that was riped off you can tape it back.
Gianrene Padilla - 返信 共有
the foil itself has nothing to do with the functioning of the spen. It is for heat dissipation
Mentat Solutions - 返信 共有
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 11
過去 30 日: 70
今までの合計 320,682
