はじめに
手順 1 に進む ↓Use this guide to replace the front camera of your Samsung Galaxy A50.
You’ll need replacement adhesive to reattach components when reassembling the device.
必要な工具と部品
ツール
Spudger4.9
Insert a SIM card eject tool, a SIM eject bit or a straightened paper clip into the hole on the SIM tray located at the left side of the phone.
Press firmly to eject the tray.
Remove the SIM card tray.
Start by switching off your phone.
Heat an iOpener and apply it to the back cover to soften the adhesive.
Use a spudger to disconnect the battery by prying the connector straight up from its socket.
Use a spudger to disconnect the front camera by prying the connector straight up from its socket.
If possible, turn on your device and test your repair before installing new adhesive and resealing.
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
11 の人々がこのガイドを完成させました。
