メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Samsung Epix Motherboard Replacement
必要な工具と部品
  1. Samsung Epix Motherboard Replacement, Battery: 手順 1、 1の画像 1
    • Just below the phone's camera, press the button and hold it
    • While the button is held down, slide the back panel off to remove it completely.
    FixBotに聞いてみる
    コメントを追加
  2. Samsung Epix Motherboard Replacement: 手順 2、 1の画像 1
    • Grasp the bottom corners of the battery with two fingers and gently lift.
    • Gently lift the battery and remove it from the phone.
    FixBotに聞いてみる
    コメントを追加
  3. Samsung Epix Motherboard Replacement, Speakers: 手順 3、 1の画像 1
    • Using an iPod opening tool, remove the screw cover in the top left corner by lifting it up.
    FixBotに聞いてみる
    コメントを追加
  4. Samsung Epix Motherboard Replacement: 手順 4、 1の画像 1
    • Use a Phillips #00 screwdriver to remove the six screws on the back of the phone. Three are evenly spaced on each side.
    • The upper right screw is 4.5mm while the rest are 6.5mm.
    FixBotに聞いてみる
    コメントを追加
  5. Samsung Epix Motherboard Replacement: 手順 5、 2の画像 1 Samsung Epix Motherboard Replacement: 手順 5、 2の画像 2
    • Slide the iPod opening tool into the seam on the side of the phone and turn it slightly to unhook the eight clips.
    • There are three clips on each side and two at the bottom of the phone.
    FixBotに聞いてみる
    コメントを追加
  6. Samsung Epix Motherboard Replacement: 手順 6、 1の画像 1
    • Once all eight of the clips have been unhooked, lift the back panel off of the phone.
    • Be careful not to remove the front panel. It is still connected to the phone chassis by a ribbon cable in the bottom right corner of the motherboard.
    FixBotに聞いてみる
    コメントを追加
  7. Samsung Epix Motherboard Replacement: 手順 7、 1の画像 1
    • Remove the circular battery from the plastic holder by inserting a 1 mm flat head screwdriver under the battery where the red and blue wires connect and lifting gently.
    • Make sure the battery is still connected to the motherboard via the red and blue wires. This part does not have to be completely removed.
    FixBotに聞いてみる
    コメントを追加
  8. Samsung Epix Motherboard Replacement: 手順 8、 1の画像 1
    • Using a Phillips #00 screwdriver, unscrew the two 3.5mm screws that connect the speaker to the motherboard.
    FixBotに聞いてみる
    コメントを追加
  9. Samsung Epix Motherboard Replacement: 手順 9、 1の画像 1
    • With the iPod opening tool, unclip the red and black wires connecting the speaker to the motherboard.
    • Lift the speaker off of the motherboard.
    • The camera will remain attached to the phone when removing the speaker.
    FixBotに聞いてみる
    コメントを追加
  10. Samsung Epix Motherboard Replacement, Motherboard: 手順 10、 1の画像 1
    • Using an iFixit opening tool, unlatch and disconnect the camera ribbon cable.
    FixBotに聞いてみる
    コメントを追加
  11. Samsung Epix Motherboard Replacement: 手順 11、 1の画像 1
    • Unlatch the LCD ribbon cable on the left side of the motherboard using the opening tool.
    FixBotに聞いてみる
    コメントを追加
  12. Samsung Epix Motherboard Replacement: 手順 12、 2の画像 1 Samsung Epix Motherboard Replacement: 手順 12、 2の画像 2
    • Unlatch and disconnect the two ribbon cables at the bottom center of the motherboard.
    • The two disconnected ribbon cables connect to the keypad and center button.
    FixBotに聞いてみる
    コメントを追加
  13. Samsung Epix Motherboard Replacement: 手順 13、 1の画像 1
    • Unlatch and remove the front panel ribbon cable located at the bottom right of the motherboard.
    FixBotに聞いてみる
    コメントを追加
  14. Samsung Epix Motherboard Replacement: 手順 14、 1の画像 1
    • Use the opening tool to gently disconnect the microphone cable, also located at the bottom right of the motherboard.
    FixBotに聞いてみる
    コメントを追加
  15. Samsung Epix Motherboard Replacement: 手順 15、 1の画像 1
    • Using a Phillips #00 screwdriver, remove the 3.5 mm screw at the bottom center of the motherboard.
    FixBotに聞いてみる
    コメントを追加
  16. Samsung Epix Motherboard Replacement: 手順 16、 1の画像 1
    • Carefully lift the motherboard from the left side to begin removing it from the phone chassis.
    • A ribbon cable is still connected underneath on the right side.
    FixBotに聞いてみる
    コメントを追加
  17. Samsung Epix Motherboard Replacement: 手順 17、 1の画像 1
    • Flip the motherboard slightly to access the back, then use the opening tool to unlatch and disconnect the remaining ribbon cable.
    • Remove the motherboard.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
2 の人々がこのガイドを完成させました。
作成者
8人の作成者と共同で作成されました。
Mark Wyse
メンバー登録日: 04/19/11
62 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 15-15, Regan Spring 2011 Cal Poly, Team 15-15, Regan Spring 2011人のメンバー
CPSU-REGAN-S11S15G15
5 メンバー
10のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 51
今までの合計 1,964
