はじめに
This guide details the process of removing the motor assembly from the drill. The process requires removing all of the internal electronics from the drill case. Due to the tight constraints of the wiring within the drill, reassembling the drill may require use of a spudger to push the wires out of the way of the case.
必要な工具と部品
Detach the battery unit from the drill body by pressing the battery release buttons on both sides of the unit and pulling outwards.
Use a Torx T10 screw driver to unscrew all ten 13.5 mm screws from the drill casing to gain access to the interior.
Rotate the Drill 180 degrees so that the top is facing you.
Lift the level gauge out from the top corner of the drill.
Grip the battery clip and pull straight up to remove the metal battery contacts.
You can now clean the metal battery contacts with isopropyl alcohol.
Holding the direction select switch in place, grip both sides of the trigger assembly and lift it up and towards the base of the drill.
4 の人々がこのガイドを完成させました。
