メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Rocketfish RF-WHTIB-A Receiver LED Light Chip Replacement
必要な工具と部品
  1. Rocketfish RF-WHTIB-A Receiver LED Light Chip Replacement, How to Open the Rocketfish RF-WHTIB-A Receiver: 手順 1、 1の画像 1
    • Remove the 4 rubber tabs on the bottom side of the receiver.
    FixBotに聞いてみる
    コメントを追加
  2. Rocketfish RF-WHTIB-A Receiver LED Light Chip Replacement: 手順 2、 1の画像 1
    • Unscrew the four 12 mm screws on the bottom side of the receiver.
    • Use a Phillips #1 screwdriver for this step.
    FixBotに聞いてみる
    コメントを追加
  3. Rocketfish RF-WHTIB-A Receiver LED Light Chip Replacement: 手順 3、 2の画像 1 Rocketfish RF-WHTIB-A Receiver LED Light Chip Replacement: 手順 3、 2の画像 2
    • Remove top casing from the receiver.
    • The receiver top casing is difficult to remove. Internal clasps may have to be broken in order to remove the top casing (this will not effect the device's function)
    FixBotに聞いてみる
    コメントを追加
  4. Rocketfish RF-WHTIB-A Receiver LED Light Chip Replacement, Receiver LED Light Chip: 手順 4、 2の画像 1 Rocketfish RF-WHTIB-A Receiver LED Light Chip Replacement, Receiver LED Light Chip: 手順 4、 2の画像 2
    • One 10 mm screw is securing the LED 14.14 chip.
    • Unscrew the chip.
    • Use a Phillips #1 Screwdriver for this step.
    FixBotに聞いてみる
    コメントを追加
  5. Rocketfish RF-WHTIB-A Receiver LED Light Chip Replacement: 手順 5、 1の画像 1
    • Using your fingers, gently pull the LED plug out of the mother board.
    FixBotに聞いてみる
    コメントを追加
  6. Rocketfish RF-WHTIB-A Receiver LED Light Chip Replacement: 手順 6、 1の画像 1
    この手順で使用する道具:
    • Gently feed the LED wire under the power supply to completely remove it from the sender.
    • Remove the faulty LED 14.14 chip from the receiver.
    • You may want to use the tweezers to help pull the LED wire out from beneath the power supply.
    FixBotに聞いてみる
    コメントを追加
終わりに
To reassemble your device with the new LED light chip, follow these instructions in reverse order.
Once the receiver has been put back together, plug in the device and initiate the connection mode between the sender and receiver to ensure the new LED light chip has been properly assembled.
キャンセル: このガイドを終了できませんでした。
作成者
2人の作成者と共同で作成されました。
Caitlin Charlton
メンバー登録日: 03/22/15
756 ポイント
6のガイドは作成済み
チーム
Baylor, Team 4-2, Williams Spring 2015 Baylor, Team 4-2, Williams Spring 2015人のメンバー
BU-WILLIAMS-S15S4G2
3 メンバー
12のガイドは作成済み
2件のガイドコメント
Where do I get the chip???
sean moore - 返信 共有
where do I get chip?
bugsyc26 - 返信 共有
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 35
今までの合計 2,491
