はじめに
Follow this guide to replace the switches in your Roccat Vulcan II Mini Air mechanical keyboard.
必要な工具と部品
Flip your keyboard over so the bottom is facing up.
Use a Phillips #0 screwdriver to remove all of the screws from the back plate.
Gently lift the switch plate from the backplate, setting them next to each other with the ribbon cables facing upwards.
Use a spudger or a clean fingernail to flip up the locking flaps of the two ZIF connectors using the widest tool possible to avoid damaging the delicate hinge pins.
Use tweezers or your fingers to gently pull the cable out of its socket by the pull tab.
Use a keycap puller or your fingers to gently pull off the keycap.
Lift the keycap evenly and straight up from the keyboard.
Use a switch puller to grip the top and bottom tabs of the switch firmly and pull upward to remove it.
Repeat this process for every switch that requires replacement.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
