はじめに
Follow this guide to replace the battery in your Roccat Vulcan II Mini Air keyboard.
必要な工具と部品
Flip your keyboard over so the bottom is facing up.
Use a Phillips #0 screwdriver to remove all of the screws from the back plate.
Gently lift the switch plate from the backplate, setting them next to each other with the ribbon cables facing upwards.
Use a spudger or a clean fingernail to flip up the locking flaps of the two ZIF connectors using the widest tool possible to avoid damaging the delicate hinge pins.
Use tweezers or your fingers to gently pull the cable out of its socket by the pull tab.
Push on alternating sides of the connector, like small sliding connectors to unplug the battery cable from the PCB.
If that doesn't work, use a pair of tweezers to firmly grip the sides of the connector and pull straight away from the socket. Hold the tweezers closer to the connector to get a better grip.
Remove the battery from the laptop.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
