はじめに
Over time, the bottom shell of the Roborock Q5 Max+ may need to be removed for cleaning, part replacement, or internal repairs. Whether you're replacing a damaged shell or accessing internal components like the battery, sensors, or wheels, this guide will walk you through the safe and effective removal and reinstallation process. This step-by-step guide ensures that even users with minimal repair experience can perform this procedure confidently.
必要な工具と部品
Carefully flip the Roborock upside down on a soft surface (e.g., towel) to avoid scratches.
Turn off the vacuum using the main switch underneath.
Use a Phillips #1 screwdriver to remove the eight 14 mm screws that secure the bottom shell.
ある他の人がこのガイドを完成しました。
