メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Ring Stick Up Cam Battery Camera Replacement
必要な工具と部品
    1. Ring Stick Up Cam Battery Camera Replacement, Battery: 手順 1、 1の画像 1
      • Turn the camera so the lens is facing away from you, and the back is facing towards you.
      • Place one hand securely on the base and the other on the stand.
      • Carefully twist your bottom hand counterclockwise until the indicator line reaches the unlock icon.
      FixBotに聞いてみる
      コメントを追加
    2. Ring Stick Up Cam Battery Camera Replacement: 手順 2、 1の画像 1
      • Gently pull down to separate the stand from the camera body.
      FixBotに聞いてみる
      コメントを追加
    3. Ring Stick Up Cam Battery Camera Replacement: 手順 3、 2の画像 1 Ring Stick Up Cam Battery Camera Replacement: 手順 3、 2の画像 2
      • Hold the camera so the opening containing the battery is toward the ceiling.
      • Squeeze the silver lever labeled "push" and extract the battery from its slot.
      FixBotに聞いてみる
      コメントを追加
    1. Ring Stick Up Cam Battery Camera Replacement, Motherboard: 手順 4、 1の画像 1
      この手順で使用する道具:
      Halberd Spudger
      $2.99
      • Remove the upper and lower silicon covers on the rear panel with your fingers or the hook-end of the halberd spudger.
      FixBotに聞いてみる
      コメントを追加
    2. Ring Stick Up Cam Battery Camera Replacement: 手順 5、 1の画像 1
      • Remove the 6 mm white screw from the rear panel with the a T3 Torx screwdriver.
      FixBotに聞いてみる
      コメントを追加
    3. Ring Stick Up Cam Battery Camera Replacement: 手順 6、 1の画像 1
      • Rotate the device so the base is facing upward.
      • Remove the two 6 mm screws from the base (on either side of the QR code) using a Phillips #00 screwdriver.
      • Remove the two 4 mm screws that connect the silver latch on the outside rim using a Phillips #00 screwdriver.
      FixBotに聞いてみる
      コメントを追加
    4. Ring Stick Up Cam Battery Camera Replacement: 手順 7、 1の画像 1
      • Remove the silver latch from the base.
      • Remove the front cover.
      • Remove the eight 6 mm screws from the inside panel with a Philips #00 screwdriver.
      • Remove the two 4 mm screws from the inside panel with a Phillips #00 screwdriver.
      FixBotに聞いてみる
      コメントを追加
    5. Ring Stick Up Cam Battery Camera Replacement: 手順 8、 1の画像 1
      • Pry the inside panel open using your hands or a spudger if necessary.
      FixBotに聞いてみる
      コメントを追加
    6. Ring Stick Up Cam Battery Camera Replacement: 手順 9、 1の画像 1
      • Remove the seven 4 mm screws connecting the motherboard to the camera body with a Phillips #00 screwdriver.
      FixBotに聞いてみる
      コメントを追加
    7. Ring Stick Up Cam Battery Camera Replacement: 手順 10、 2の画像 1 Ring Stick Up Cam Battery Camera Replacement: 手順 10、 2の画像 2
      • Lift the motherboard from the camera body with the halberd spudger.
      FixBotに聞いてみる
      コメントを追加
    8. Ring Stick Up Cam Battery Camera Replacement: 手順 11、 2の画像 1 Ring Stick Up Cam Battery Camera Replacement: 手順 11、 2の画像 2
      • Rotate the device to its side.
      • With your fingers, carefully remove the white part of the cord clip from the beige base.
      • Repeat this for the remaining three cords connecting the motherboard to the camera body.
      FixBotに聞いてみる
      コメントを追加
    9. Ring Stick Up Cam Battery Camera Replacement: 手順 12、 1の画像 1
      • Fold the motherboard downward from the camera body, revealing a white connecting strip.
      • Using the flat end of a spudger, flick the black hinge upward.
      • Pull the white strip out of the slot.
      FixBotに聞いてみる
      コメントを追加
    10. Ring Stick Up Cam Battery Camera Replacement: 手順 13、 2の画像 1 Ring Stick Up Cam Battery Camera Replacement: 手順 13、 2の画像 2
      • Carefully insert the spudger underneath gold adhesive at the lower left-hand corner of the motherboard.
      • Gently remove the adhesive cover from the motherboard.
      FixBotに聞いてみる
      コメントを追加
    1. Ring Stick Up Cam Battery Camera Replacement, Camera: 手順 14、 1の画像 1
      • Orient your device so that the interior of the camera body is facing the ceiling.
      FixBotに聞いてみる
      コメントを追加
    2. Ring Stick Up Cam Battery Camera Replacement: 手順 15、 1の画像 1
      • Remove the two 6 mm screws that connect the camera to the camera body using a Phillips #00 screwdriver.
      FixBotに聞いてみる
      コメントを追加
    3. Ring Stick Up Cam Battery Camera Replacement: 手順 16、 1の画像 1
      • Grab and twist the camera counterclockwise with your thumb and index finger.
      FixBotに聞いてみる
      コメントを追加
    4. Ring Stick Up Cam Battery Camera Replacement: 手順 17、 2の画像 1 Ring Stick Up Cam Battery Camera Replacement: 手順 17、 2の画像 2
      • Using your fingers, lift out the camera component including the camera lens and the attached wire.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Nick Tomkins
メンバー登録日: 02/24/23
124 ポイント
1ガイドが承認済み
チーム
Marist, Team 1-1, Chaterdon Spring 2023 Marist, Team 1-1, Chaterdon Spring 2023人のメンバー
MARS-CHATERDON-S23S1G1
3 メンバー
48のガイドは作成済み
1件のガイドコメント
Seriously where do you get the part
Tonio Lopez (Tony) - 返信 共有
コメントを追加
統計データ:
過去 24時間: 6
過去 7 日: 23
過去 30 日: 88
今までの合計 7,672
