メインコンテンツにスキップ
Retina MacBook 2015トラックパッドアセンブリの交換
必要な工具と部品
ビデオの概要
  1. Retina MacBook 2015トラックパッドアセンブリの交換, 下部ケース固定ネジの取り外し: 手順 1、 1の画像 1
    この手順で使用する道具:
    Magnetic Project Mat
    $19.95
    購入する
    • 先に進む前に、コンセントから抜いてMacBookの電源を切ります。ディスプレイを閉じて、裏返します
    • 下部ケースを固定している次の8本のネジを取り外します:
    • 2本の1.8 mm P5ペンタローブネジ
    • 4本の2.9 mm P5ペンタローブネジ
    • 2本の6.1 mm P5ペンタローブネジ
    • ネジを取り外すときは、ネジの向きに注意してください。ネジを少し傾けて再度取り付ける必要があります。
    • この修理全体を通して、各ネジを紛失しないようにし、デバイスの損傷を避けるために元の位置へ正確に戻すよう確認してください。
    If, like me, you didn’t have a P5 Pentalope screwdriver but did have one that fits an iPhone.
    You can sand down the tip until it’s the right size.
    Stuart - 返信
    Thank you Stuart! I would never have thought of this and it worked perfectly.
    R McP -
    Hello,
    where do I plug the USB-C to USB-A cable on MacBook MacBook Pro (Retina, 15-inch, Mid 2015)
    I can’t any port suitable for USB-c !??
    sissi - 返信
    My MacBook had P4 pentalobe screws, notP5
    Greg Lavardera - 返信
    Big thanks to Jeff for such thorough and detailed instructions. This is definitely a more advanced repair so if you're not comfortable with making such repairs, like having experience working on iPhones, computers, etc., you might think twice before attempting. It's very helpful to read all the instructions thoroughly before starting. Plan on 3 to 4 hours—the battery removal along with its adhesive is a real $@$*-show, but totally doable if you followed Jeff's recommendations.
    I'll post a few tips in the comments on each step that I think is worth noting but I will mention here one of the trickier steps. ZIF connectors on the flat cables can be a little tricky, especially if you have never done these. Before attempting to do the first one (step 8) review the others in steps 16, 20, and 25. You'll get a better sense of how these little retaining flaps flip up and what they actually look like when you study each photo in each step—they are very tiny and fragile.
    Steven Gibson - 返信
    Just finished replacing the battery. I followed the directions that came with the battery instead of this guide. In short, Steps 15 to 35 are not necessary. You don't have to completely disassemble the laptop to replace the battery.
    Andrew Mohan - 返信
    Thanks. I skipped it too and it worked.. It was a painstaking to remove the two side batteries as the cables were connected. But a little patience gets the job done. I did however remove the audio jack connector but from the audio board. Removed the display connector and the usb-c bracket to get the bottom case free.
    Paras Tolani -
    READ EVERY STEP, AND EVERY COMMENT FOR THAT STEP BEFORE ATTEMPTING! Go slow. Think first. Be organized. No probs.
    David Nagle - 返信
  2. Retina MacBook 2015トラックパッドアセンブリの交換: 手順 2、 3の画像 1 Retina MacBook 2015トラックパッドアセンブリの交換: 手順 2、 3の画像 2 Retina MacBook 2015トラックパッドアセンブリの交換: 手順 2、 3の画像 3
    • MacBookの背面からヒンジの間に向かって、上部ケースと下部ケースの間に指を差し込みます。
    • 下部ケースと上部ケースを接続するケーブルの損傷を防ぐため、下部ケースを少しだけ持ち上げます。
    • しっかりと握りながら、下部ケースが上部ケースからわずかに離れるまでしっかりと持ち上げます。
    • 下部ケースを持ち上げるときに、強い抵抗を感じる場合があります。2つの隠れた固定クリップを外すため、必要に応じてオープニングピック、または静電気ESD安全のこじ開けツールを下部ケースの側端に沿ってスライドさせます。
    • 再組み立て中、クリップを再装着するには、クリップが所定の位置にカチッと収まるのが聞こえるまで、下部ケースの両側の端の近く(3番目の画像でピックが挿入されている場所の近く)をしっかり押します。
  3. Retina MacBook 2015トラックパッドアセンブリの交換: 手順 3、 1の画像 1
    • 下部ケースを持ちながら、Appleロゴが上を向くようにMacBookを慎重に裏返します。
  4. Retina MacBook 2015トラックパッドアセンブリの交換: 手順 4、 2の画像 1 Retina MacBook 2015トラックパッドアセンブリの交換: 手順 4、 2の画像 2
    • 上部ケースとディスプレイを一緒に前端から持ち上げ、約45°の角度まで起こします。
    • 次の手順の準備として、この位置でMacBookを開いておくと便利です。
    This step at the suggested height tears the ribbon cable. do step 7 first. carefully
    Kiernan - 返信
    If you carefully open the display all the way and then lift the upper case, you can let the display rest on your flat working surface. The upper case will be held in place at an appropriate angle by the display hinge.
    Mike C - 返信
    It's a two-spooger-job.
    LMAOOOOOOOO
    Elixir2 - 返信
  5. Retina MacBook 2015トラックパッドアセンブリの交換: 手順 5、 3の画像 1 Retina MacBook 2015トラックパッドアセンブリの交換: 手順 5、 3の画像 2 Retina MacBook 2015トラックパッドアセンブリの交換: 手順 5、 3の画像 3
    • スパッジャーの平面側先端を使って、小さなゴールドの”バッテリーの切断”ボタンを長押しします。
    • 電源LEDが点灯している場合、LEDが消えるまでボタンを長押しして離します。 これには最大10秒かかります。
    • LEDが点灯していない場合、5〜10秒後にボタンを離します。 再度、5〜10秒間押し続けてから離します。 最後の3回目も5〜10秒間押し続けてから離します。
    • この手順により、MacBookの電源が完全に切れて、安全に作業ができるようになります
    Wow okay could someone explain why this is necessary? What happens if you skip this step and simply undo the screw to disconnect the power?
    EB Computers - 返信
    Removing the screw does not disconnect the power—power comes from the battery terminals contacting the underside of the logic board, and they’re tricky to separate reliably at this stage of disassembly. This step is the safest and easiest way to kill power; don’t skip it.
    Jeff Suovanen -
    What if I can’t get my LED to power on when reassembling the machine?
    greg2b - 返信
    Update: Realized my USB-C connector (Step 14) wasn’t properly seated.
    greg2b -
    Hi what will happen if i skip this step, coz i did tried to power down the battery by pressing small gold button, but no avail. the LED light still there even after more than 5 times press (5-10secs or more) each press.
    Dimitri Zaborski - 返信
    Did you learn the answer to your question? I'm having the same issue -- I keep pressing the gold button but the battery light stays on.
    R McP -
    Mi laptop doesn’t turn it on doing that ):
    alexisaguinagam26 - 返信
  6. Retina MacBook 2015トラックパッドアセンブリの交換: 手順 6、 1の画像 1
    • MacBookを閉じて、慎重に本体を裏返します。
  7. Retina MacBook 2015トラックパッドアセンブリの交換: 手順 7、 1の画像 1
    • 前端から持ち上げて、下部ケースを約45°の角度で開きます。
    • MacBookにと下部ケースを繋いでいるリボンケーブルにダメージを与えないよう注意してください。
    Before the IPD flex cable can be removed the battery disconnect button has be held down for up to 10 seconds. If the LED near the battery connector is switched on it shows that there is power going through the logic board from the battery, once the button is pressed and this light goes off the machine is safe to be worked on.
    Aaron Dalziel - 返信
  8. Retina MacBook 2015トラックパッドアセンブリの交換: 手順 8、 2の画像 1 Retina MacBook 2015トラックパッドアセンブリの交換: 手順 8、 2の画像 2
    • ピンセットを使用して、トラックパッドケーブルのZIFコネクタを覆っているテープをはがします。
    Only peel back the first half of the tape covering the trackpad cable ZIF connector—do not completely remove.
    Steven Gibson - 返信
    Gently - lift tape while wiggling cable side to side. Be sure tape is released, but do not remove completely
    David Nagle - 返信
  9. Retina MacBook 2015トラックパッドアセンブリの交換: 手順 9、 2の画像 1 Retina MacBook 2015トラックパッドアセンブリの交換: 手順 9、 2の画像 2
    • スパッジャーを使用して、トラックパッドケーブルのZIFコネクタ上の固定フラップを慎重に持ち上げます。
    This is very tricky indeed - at least on my computer. I failed at this point - having skipped to it as sugested above so as not to stress the ribbons on the other side. The ZIF was not as I expected. They had opened when I pulled up the stick cover and I found I was working on the socket itself. The top edge came adrift after almost no pressure being put on it. The ribon did not come free with gentle pulling though. At that point I put the back on again… waited until the battery recharged a bit and found I had not nroken it after all. I doubt I shall try again. It is much harder to replace than the 15 inch - much…
    Simon Anthony - 返信
    I’ve just found that I have broken it after all. No keyboard. Bluetooth still works so I can use the machine.
    All in all, an expensive mistake. BTW - I did NOT get the kit from IFIXIT - not sold here.
    Simon Anthony - 返信
    I found “Recognizing & Disconnecting Cable Connectors”
    ケーブルコネクタの識別と接続の外し方
    useful, esp. for someone who has not used ZIF connectors and retaining flaps before. There are several retaining flaps that need to be opened. The first time is tricky as you need a sense of how much force to apply. I used the flat end of the provided spudger. Apply progressively firmer upward pressure until the retaining flap pops open. The first time is tricky, but straightforward thereafter.
    Ki Park - 返信
    Mouse back and forth between the two right-side thumbnail photos and you will get a little animation feel showing how these ZIF connectors operate—it's very helpful. Apply light but consistent pressure to pop them up. Helps to go side to side if they're a little stubborn.
    Steven Gibson - 返信
    this is a great tip Steve!
    Eric - 返信
  10. Retina MacBook 2015トラックパッドアセンブリの交換: 手順 10、 2の画像 1 Retina MacBook 2015トラックパッドアセンブリの交換: 手順 10、 2の画像 2
    • フレームのスロットから慎重に引き抜いて、トラックパッドからトラックパッドリボンケーブルの接続を外します。
    it would be nice to have a specific picture of the cable and contacts and how it is oriented in the ZIF connector. This isn't clear in any of these photos or text.
    My trackpad cable snapped so had to replace it and none of the replacement cables have the tape which is on the smaller end to the trackpad. The other end is fairly easy to figure out but the trackpad end isn't as the cable makes a 180 degree turn inside the case (poor design).
    Marc - 返信
  11. Retina MacBook 2015トラックパッドアセンブリの交換: 手順 11、 2の画像 1 Retina MacBook 2015トラックパッドアセンブリの交換: 手順 11、 2の画像 2
    • 下部ケースを水平状態に置くために、MacBookを慎重に裏返します。
    • 上部ケース/ディスプレイアセンブリを約90度の角度まで持ち上げ、 手で固定する必要がないように、安定した頑丈な衝立に立てかけます。
    • 上部ケースを固定するためトラックパッドの近くにテープを貼り、不用意な動きを防ぎます。
    • MacBookを完全に開き、両側を水平に配置することもできます。しかし、この状態の場合、フレックスケーブルが損傷する可能性があるため、お勧めしません。
    You can open the laptop screen all the way open with it flat in the table (screen facing up) and the keyboard should stay up.
    xavierviveros - 返信
  12. Retina MacBook 2015トラックパッドアセンブリの交換: 手順 12、 2の画像 1 Retina MacBook 2015トラックパッドアセンブリの交換: 手順 12、 2の画像 2
    • バッテリーコネクタをロジックボードに固定している2.9 mmのT5トルクスネジを1本取り外します。
    • 2015年モデルには、このネジの真下に2つの発泡体パッドが付いたシルバーのアースクリップがあり、緩むことがあります。再組み立て中に必ず再組み込みしてください。
    the moment you opening macbook case and before any tinkering with connections, you MUST press little yellow button on logicboard, located on the right from battery connector - this will disable all power to the board. You can check by looking at the small led on left side of the battery connector - if there is very faint light, it means that power is still there. After pressing button light should go off. Removing screw is not necessary at all, and like I said - you MUST disable power before any touching to connections etc.
    DigiHead - 返信
    Where it says
    “2015 models have a silver grounding clip with two foam pads directly under this screw“
    I have a 2015 MacBook & the grounding clip is not there!
    I’m using this guide to investigate why there are lines on screen or darker screen at certain angles of opening it. Also a background ghosting effect on screen too.
    No obvious damage or loose connectors so wondered if the lack of grounding clip can cause these symptoms?
    Anybody out there know?
    nijafe - 返信
    Either buy the clip and check, or replace the screen (or LB), but the macbook would more likely not start if there is a missing grounded connection, depending on what is being grounded.
    Sean -
  13. Retina MacBook 2015トラックパッドアセンブリの交換: 手順 13、 2の画像 1 Retina MacBook 2015トラックパッドアセンブリの交換: 手順 13、 2の画像 2
    この手順で使用する道具:
    Battery Blocker
    $3.99
    購入する
    • 追加の予防策として、ロジックボードとバッテリーコネクタの間にバッテリー絶縁ピックを挿入して、バッテリーを物理的に外すことができます。
    I HAD TO DO THIS TWICE. After replacing the battery while following this guide to a 'T', the battery was not being recognized by the logic board. Strangely, with the power unplugged it would still light up the screen and tell me the battery was at a critical level, but it would not boot. Resetting the SMC had no effect. I thought I killed my computer or got a bad battery, so as a last ditch effort I re-opened the case, pressed the battery disconnect button, removed the screw and inserted the battery separation tool again to Physically Disconnect the battery from the mainboard. After about 5 minutes I then removed the tool and reassembled everything, plugged in via 5v iphone charger and USBA-C cable again and LO, the battery is now reporting correctly, charging correctly and allowing me to boot on its power .
    Neil Schultz - 返信
  14. Retina MacBook 2015トラックパッドアセンブリの交換: 手順 14、 1の画像 1
    • USB-Cポートケーブルブラケットを固定している2本のネジを取り外します:
    • 1.1 mmトライポイントY00ネジ
    • このモデルのあるタイプでは、#00のプラスネジを使用しているものもあります。
    • 3.5 mm T5トルクスネジ
    This was oddly the hardest part. That Tri-Point screw just wouldn’t budge! I had to sand the end of the only Tri-point screwdriver I had in the end to get it to fit.
    Stuart - 返信
    Be sure to get the metal plate under the chip near where the PT5 screw is before tightening
    abscate - 返信
    I should have read the comments before using the provided 1.1 mm Tri-point Y00 bit. I almost stripped the screw but was able to use a small flat head bit to open the screw.
    Ifixit: you may want to update this part in the instructions. Not everyone reads the comment section, esp. when it comes to specification of bits which is basic and must be accurate. This is one of the more critical ones in the procedure that can easily go south. The rest of the instructions are excellent.
    Ki Park - 返信
    early 2015 model here. I’ve used a Y1.5 with cautiously applied down force.
    beaudry.ian - 返信
    My 2015 had a 2.5mm Y screw not a Y000.
    Michael Bonney - 返信
    Adding to the helpful comments above, on replacing the 1.1mm tripoint screw, I found the the magnetism of the nearby speaker coil overcame that of the driver and would draw the screw away or the combo of forces would fling it out of the work area! After fiddling with it for too long, I used some of the battery adhesive removed earlier to attached the screw to the driver. Wax would probably work better if I’d had some.
    jefflyons - 返信
    I used the PH00 head to unscrew what they call the “1.1 mm Tri-point Y00 screw”, NOT the Y00 head, and it unscrewed perfectly fine.
    Grace Escamilla - 返信
    Agreed, my screw was a PH00.
    stephen delaney - 返信
    I have an early 2015 MacBook and it was a PH00 head I needed to use.
    Sean Stein - 返信
  15. Retina MacBook 2015トラックパッドアセンブリの交換: 手順 15、 2の画像 1 Retina MacBook 2015トラックパッドアセンブリの交換: 手順 15、 2の画像 2
    • スパッジャーの平らな端を使って、USB-Cポートケーブルブラケットをロジックボードからまっすぐ持ち上げて外します。
    • このケーブルを再接続するには、最初に金属製ブラケットをネジ穴に合わせてから、ブラケットの中央を押し下げます。 正しく位置合わせされていることを確認してください。さもなくば、コネクタが損傷する場合があります。
    Emphasis on aligning the bracket correctly. What the pictures do not show is that underneath the flat part of the metal bracket (the area between the two screw holes) is a connector that needs to be accurately aligned. Aligning the two screw holes does not imply that the connector is seated correctly.
    After I re-assembled my 2015 MacBook power would not come on. I thought I had damaged the logic board despite being careful and following instructions. Diagnosing the problem took a while. Retracing the steps and focusing on power supply I was able to determine that the metal flap which hides the connector underneath had not made proper contact.
    What I did was to use a finger to get a tactile feel for the connector underneath the metal bracket aligning properly and then press down vertically when it seemed to be aligned. It’s a subtle tactile feel. After re-doing this step, I got power back. Be careful not to damage the connector as noted in the instructions.
    Ki Park - 返信
    Good tip. It’s so easy to damage these fragile connectors by forcing the plug in and reattaching the mounting plate screws
    Peter Newman -
  16. Retina MacBook 2015トラックパッドアセンブリの交換: 手順 16、 2の画像 1 Retina MacBook 2015トラックパッドアセンブリの交換: 手順 16、 2の画像 2
    • スパッジャーを使って、オーディオジャックボードケーブルのZIFコネクタ上の固定フラップを跳ね上げます。
  17. Retina MacBook 2015トラックパッドアセンブリの交換: 手順 17、 1の画像 1
    • オーディオジャックボードのリボンケーブルを、ZIFコネクタからまっすぐ引き抜いて取り外します。
    • 再組み立て中に、図のように、白いストライプのある側が手前になるようにリボンケーブルを向けます。
    hey my macbook do not have sound after replacing the topcase, i did connect everything like here you did, also I did the reset of PR and NVRAM. What Can I check more? simply when I open the OS, there is no audio device at all
    dkflu - 返信
    The audio jack cable is a bit of a pain to reinsert. I found if I turned the screen and the bottom on its side, like an open book, I had much better orientation and it was much easier to insert.
    Steven Gibson - 返信
    Excellent guide and all works like a sharm, but was one issue. After full assemble there wasn't sound. Then I open Macbook again and disconnect and connect audio cable. You must insert cable so, that white stripe will not visible. And sound reveal!
    Pzs Serv - 返信
    This helped me, thanks!
    Egbert Kappert -
  18. Retina MacBook 2015トラックパッドアセンブリの交換, トラックパッドアセンブリ: 手順 18、 2の画像 1 Retina MacBook 2015トラックパッドアセンブリの交換, トラックパッドアセンブリ: 手順 18、 2の画像 2
    • ピンセットを使って、トラックパッド上のキーボードリボンケーブルコネクタを覆っているテープを剥がします。
  19. Retina MacBook 2015トラックパッドアセンブリの交換: 手順 19、 2の画像 1 Retina MacBook 2015トラックパッドアセンブリの交換: 手順 19、 2の画像 2
    • スパッジャーを使って、キーボードリボンケーブルのZIFコネクタ上の固定フラップを跳ね上げます。
  20. Retina MacBook 2015トラックパッドアセンブリの交換: 手順 20、 2の画像 1 Retina MacBook 2015トラックパッドアセンブリの交換: 手順 20、 2の画像 2
    • フレームのスロットからキーボードリボンケーブルをゆっくりと引き出します。
  21. Retina MacBook 2015トラックパッドアセンブリの交換: 手順 21、 1の画像 1
    • トラックパッドをケースに固定している2.5mm T3トルクスネジを5本外します。
    This may require a T4 for the MacBook Retina early 2015. A T3 was too small, but this machine already had a replacement keyboard and body due to Apple recall. Just be aware.
    Neal Abrams - 返信
    I should read this comment. I think my Mac Book have T4 screws. Thanks a lot.
    GOCHI MOTOHIRO - 返信
    2015 here also had t4
    Greg Lavardera - 返信
  22. Retina MacBook 2015トラックパッドアセンブリの交換: 手順 22、 1の画像 1
    • トラックパッドアセンブリを上部ケースから解放するため、ディスプレイをわずかにヒンジで開き、トラックパッドアセンブリを取り外します。
    • トラックパッドの両側にある金属製ブラケットは、取り外しの際に脱落する可能性があります。組み立ての際は、画像のように配置してください。
終わりに
デバイスを再組み立てする際は、これらの手順を逆の順番に従って作業を進めてください。ロジックボードの損傷を避けるため、MacBookの修理が完了した後、電源を入れる前に、5ワットのiPhone充電器とUSB-C to USB-Aケーブルを使用して低電圧電源に接続します
12 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
en jp
100%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 あなたも貢献してみませんか?
翻訳を始める ›
作成者
5人の作成者と共同で作成されました。
Jeff Suovanen
メンバー登録日: 08/06/13
428,107 ポイント
259のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
135 メンバー
16,817のガイドは作成済み
2 件のコメント
Excellent instructions, a big thanks to the author. After completing them the MACBOOK worked OK and then I started to get intermittent problems with the power button and the system bringing the shutdown dialogue without pressing the power button. On closer examination and second removal of the trackpad IPD flex ribbon cable (which also routes keyboard signals to the logic board) the cable came apart at the fold half way along the cable. This cable is very fragile and as mentioned in step 7 you need to be very careful on handling them. In my case I think the cable was fatigued or mechanically damaged where the fold was during manufacture . A replacement cable has been installed and the laptop now works ok.
Mark Timms - 返信
Hi. I've replaced the trackpad after the old one got damaged and started heating up. Macbook turns on perfectly without any trackpad connected, but doesn't even boot when the new trackpad is connected. The motherboard's LED near the battery connector is blinking. Is there something im missing?
Anton - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 41
過去 30 日: 154
今までの合計 25,489
