メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
ResMed AirSense 10 Heater Fuse Replacement
医療機器
この修理ガイドは医療機器メーカーからの是認を得ておらず、iFixitと医療機器メーカーは提携していません。
必要な工具と部品
    1. ResMed AirSense 10  Heater Fuse Replacement, Heater Plate Fuse: 手順 1、 2の画像 1 ResMed AirSense 10  Heater Fuse Replacement, Heater Plate Fuse: 手順 1、 2の画像 2
      • With medium pressure, place your thumb on the top of the tank and four fingers on the bottom.
      • Pull straight out on the tank until it releases from the device.
      FixBotに聞いてみる
      コメントを追加
    2. ResMed AirSense 10  Heater Fuse Replacement: 手順 2、 1の画像 1
      • Remove the four 10mm screws from the bottom of the device with a Torx T10 screwdriver.
      FixBotに聞いてみる
      コメントを追加
    3. ResMed AirSense 10  Heater Fuse Replacement: 手順 3、 3の画像 1 ResMed AirSense 10  Heater Fuse Replacement: 手順 3、 3の画像 2 ResMed AirSense 10  Heater Fuse Replacement: 手順 3、 3の画像 3
      • After the plastic cover has been removed you will be able to see the back of the heater plate. We will remove it from the device to making it easier to remove the fuse.
      • Pinching the three red cords, pull straight back on the heater plate power cord until it is removed from the connector.
      • After the cord has been removed from the connector, it will need to be pulled through the rubber grommet.
      • Gently pull the wires to the connector until the white connector is touching the rubber grommet.
      • Using light force, push the white connector on the end of the heater plate power cords through the rubber grommet.
      FixBotに聞いてみる
      コメントを追加
    4. ResMed AirSense 10  Heater Fuse Replacement: 手順 4、 3の画像 1 ResMed AirSense 10  Heater Fuse Replacement: 手順 4、 3の画像 2 ResMed AirSense 10  Heater Fuse Replacement: 手順 4、 3の画像 3
      • Using the straight tipped tweezers, push the fuse away from fuse housing until the main body of the fuse is visible.
      • Take the straight tipped tweezers, grip the body of the fuse, and pull it free from the housing.
      • Make sure to not bend the wire of the fuse. Using the holes of the housing as a guide will allow you to put the fuse back in the correct orientation.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
22 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Graham Michael Holland
メンバー登録日: 09/25/20
377 ポイント
1ガイドが承認済み
39件のガイドコメント
Where can I buy a new fuse? This one does not look like one I can get at a hardware store.
pnreinhard - 返信 共有
Yws, please, where can we buy a new fuse? Thanks.
mustdeliver - 返信 共有
and yes where do you buy a fuse can’t find no where PLEASE @ cityboi53@yahoo.com
citycountryboi53 - 返信 共有
Did you get a reply as to where you can buy the fuse?
Wally Petrey - 返信 共有
any idea how can i get the fuse what are the specs and where can i buy one or someone know where to get the whole heating plate
andres usma - 返信 共有
コメントを追加
統計データ:
過去 24時間: 16
過去 7 日: 89
過去 30 日: 425
今までの合計 47,364
