必要な工具と部品
Unlock the battery latch on the right.
Unlock the battery lock on the left.
Remove the battery pack from its slot.
Using the Philips # 0 screwdriver, unscrew the 2 screws of the top cover
Check the marks indicating the direction in which the cover must be removed.
Remove the bottom cover by removing it in the direction of the markers.
This is the SSD drive
Unscrew the fixing screw of the SSD using the Philips # 0 screwdriver.
Remove the SSD.
For reassembly, follow the instructions in reverse order.
以下の翻訳者の皆さんにお礼を申し上げます:
100%
irlandaさんは世界中で修理する私たちを助けてくれています! あなたも貢献してみませんか?
翻訳を始める ›
