メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Replacing an LED Light Fixture
必要な工具と部品
  1. Replacing an LED Light Fixture, LED Light Fixture: 手順 1、 3の画像 1 Replacing an LED Light Fixture, LED Light Fixture: 手順 1、 3の画像 2 Replacing an LED Light Fixture, LED Light Fixture: 手順 1、 3の画像 3
    • Set up a ladder under the light fixture, and remove the three thumb screws holding up the fixture's cover.
    • Hold the light cover with your free hand while you unscrew the last two screws.
    FixBotに聞いてみる
    コメントを追加
  2. Replacing an LED Light Fixture: 手順 2、 2の画像 1 Replacing an LED Light Fixture: 手順 2、 2の画像 2
    • Do not remove the base of the light fixture.
    • Check that the light fixture is receiving power with a voltage detector pen.
    • If the light of the voltage detector turns from green to red and makes a loud noise, that means that voltage is still present. Do not proceed with repair until there is no current running.
    FixBotに聞いてみる
    コメントを追加
  3. Replacing an LED Light Fixture: 手順 3、 3の画像 1 Replacing an LED Light Fixture: 手順 3、 3の画像 2 Replacing an LED Light Fixture: 手順 3、 3の画像 3
    • Locate the breaker to your house/unit and identify the switch which provides power to the light fixture.
    • Flip the switch on the breaker to the right to turn off the power to the light fixture.
    • Go back to the light fixture, and check if it is still receiving power with the voltage detector.
    • The voltage detector should remain green when placed near the electrical line connected to the light fixture.
    FixBotに聞いてみる
    コメントを追加
  4. Replacing an LED Light Fixture: 手順 4、 3の画像 1 Replacing an LED Light Fixture: 手順 4、 3の画像 2 Replacing an LED Light Fixture: 手順 4、 3の画像 3
    • Begin unscrewing the base of the light fixture from the ceiling.
    FixBotに聞いてみる
    コメントを追加
  5. Replacing an LED Light Fixture: 手順 5、 3の画像 1 Replacing an LED Light Fixture: 手順 5、 3の画像 2 Replacing an LED Light Fixture: 手順 5、 3の画像 3
    • Once enough screws are removed from the base of the light fixture, hold the center of the base with your free hand so it doesn't fall down on its own.
    FixBotに聞いてみる
    コメントを追加
  6. Replacing an LED Light Fixture: 手順 6、 2の画像 1 Replacing an LED Light Fixture: 手順 6、 2の画像 2
    • While still holding the base of the light fixture, check if the exposed wires are still unpowered with the voltage detector.
    • The voltage detector should remain green when placed near these exposed wires.
    FixBotに聞いてみる
    コメントを追加
  7. Replacing an LED Light Fixture: 手順 7、 2の画像 1 Replacing an LED Light Fixture: 手順 7、 2の画像 2
    • Unscrew the screw attached to the metal bracket by twisting the manual Phillips screwdriver until the screw falls off.
    FixBotに聞いてみる
    コメントを追加
  8. Replacing an LED Light Fixture: 手順 8、 3の画像 1 Replacing an LED Light Fixture: 手順 8、 3の画像 2 Replacing an LED Light Fixture: 手順 8、 3の画像 3
    • Unwrap the electrical tape from around both the black and white wires. These wires will be connected to the base of the light fixture with wire caps (which are yellow in this case).
    • You may want to rest the base of the light fixture on the top of your ladder, or have someone else hold it so that you can use both hands to unwrap the electrical tape.
    FixBotに聞いてみる
    コメントを追加
  9. Replacing an LED Light Fixture: 手順 9、 3の画像 1 Replacing an LED Light Fixture: 手順 9、 3の画像 2 Replacing an LED Light Fixture: 手順 9、 3の画像 3
    • Remove the wire caps from the black and white wires and place them aside.
    FixBotに聞いてみる
    コメントを追加
  10. Replacing an LED Light Fixture: 手順 10、 3の画像 1 Replacing an LED Light Fixture: 手順 10、 3の画像 2 Replacing an LED Light Fixture: 手順 10、 3の画像 3
    • Place a piece of electrical tape on the two black wires joined together by the yellow wire connector.
    • Wrap the electrical tape a few times around the wire until both wires are securely wrapped together.
    • Follow the same steps for the white wires.
    FixBotに聞いてみる
    コメントを追加
  11. Replacing an LED Light Fixture: 手順 11、 3の画像 1 Replacing an LED Light Fixture: 手順 11、 3の画像 2 Replacing an LED Light Fixture: 手順 11、 3の画像 3
    • Screw on the new metal bracket from the replacement light fixture by twisting the manual Phillips screwdriver until the screw is snuggly holding the bracket.
    • This bracket will be placed in the same location that the original bracket was in, so the screw will screw into the same place as the original screw.
    FixBotに聞いてみる
    コメントを追加
  12. Replacing an LED Light Fixture: 手順 12、 3の画像 1 Replacing an LED Light Fixture: 手順 12、 3の画像 2 Replacing an LED Light Fixture: 手順 12、 3の画像 3
    • Screw on the remaining screws into the metal bracket so that it is firmly attached to the ceiling.
    FixBotに聞いてみる
    コメントを追加
  13. Replacing an LED Light Fixture: 手順 13、 3の画像 1 Replacing an LED Light Fixture: 手順 13、 3の画像 2 Replacing an LED Light Fixture: 手順 13、 3の画像 3
    • While holding the base of the new light fixture, tuck the black and white wires into the electrical box so that there is very little slack in the wires.
    FixBotに聞いてみる
    コメントを追加
  14. Replacing an LED Light Fixture: 手順 14、 2の画像 1 Replacing an LED Light Fixture: 手順 14、 2の画像 2
    • Screw the base of the new light fixture into place.
    FixBotに聞いてみる
    コメントを追加
  15. Replacing an LED Light Fixture: 手順 15、 3の画像 1 Replacing an LED Light Fixture: 手順 15、 3の画像 2 Replacing an LED Light Fixture: 手順 15、 3の画像 3
    • Position the light cover of the new light fixture onto the base.
    • Tighten the thumb screws which hold the light cover so that the cover is tightly secured to to the base.
    FixBotに聞いてみる
    コメントを追加
  16. Replacing an LED Light Fixture: 手順 16、 3の画像 1 Replacing an LED Light Fixture: 手順 16、 3の画像 2 Replacing an LED Light Fixture: 手順 16、 3の画像 3
    • Flip the switch on the breaker back to the left to turn on the power to the light fixture.
    FixBotに聞いてみる
    コメントを追加
  17. Replacing an LED Light Fixture: 手順 17、 1の画像 1
    • Test to ensure that the light fixture is working properly.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
作成者
3人の作成者と共同で作成されました。
Elijah Esmeralda
メンバー登録日: 04/15/24
273 ポイント
1ガイドが承認済み
チーム
UC Davis, Team 1-3, Morris Spring 2024 UC Davis, Team 1-3, Morris Spring 2024人のメンバー
UCD-MORRIS-S24S1G3
3 メンバー
2のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 61
過去 7 日: 98
過去 30 日: 244
今までの合計 2,551
