メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Replacing Creative Zen X-Fi Speaker
必要な工具と部品
  1. Replacing Creative Zen X-Fi Speaker, Detaching Front Case: 手順 1、 3の画像 1 Replacing Creative Zen X-Fi Speaker, Detaching Front Case: 手順 1、 3の画像 2 Replacing Creative Zen X-Fi Speaker, Detaching Front Case: 手順 1、 3の画像 3
    • Using a spudger, wedge the tip between the front and back case to pry them apart.
    • Be careful to not apply excessive force since there are six fasteners on the screen's side that holds the cases firmly together.
    FixBotに聞いてみる
    コメントを追加
  2. Replacing Creative Zen X-Fi Speaker, Rubber Button Cover: 手順 2、 1の画像 1
    • The black rubber button pad can be removed by simply picking it up.
    FixBotに聞いてみる
    コメントを追加
  3. Replacing Creative Zen X-Fi Speaker, Button Input Chip Part 1: 手順 3、 1の画像 1
    • Flip the LCD screen off the midsection plate to gain access to the space around the input button chip.
    FixBotに聞いてみる
    コメントを追加
  4. Replacing Creative Zen X-Fi Speaker, Button Input Chip: 手順 4、 1の画像 1
    • Using a spudger, pry off the button input chip from the mid-section of the device. To gain best leverage, start at the bottom right corner and level your way up the side of the chip.
    • Be aware that the button input chip is glued to the mid-section, so some extra force may be required.
    FixBotに聞いてみる
    コメントを追加
  5. Replacing Creative Zen X-Fi Speaker, Access Midsection Plate: 手順 5、 1の画像 1
    • Lift open the LCD screen and button input chip to access the entire midsection plate.
    FixBotに聞いてみる
    コメントを追加
  6. Replacing Creative Zen X-Fi Speaker, Unscrew below Button Chip: 手順 6、 1の画像 1
    • Use a Phillips Head screwdriver to unscrew the three 3/16 inch screws that were underneath the button input chip.
    FixBotに聞いてみる
    コメントを追加
  7. Replacing Creative Zen X-Fi Speaker, Unscrew below LCD Screen: 手順 7、 1の画像 1
    • Use a Phillips Head screwdriver to unscrew the three 3/16 inch screws that were underneath the LCD screen.
    FixBotに聞いてみる
    コメントを追加
  8. Replacing Creative Zen X-Fi Speaker, Unscrew Speaker's Cover: 手順 8、 2の画像 1 Replacing Creative Zen X-Fi Speaker, Unscrew Speaker's Cover: 手順 8、 2の画像 2
    • Use a Phillips Head screwdriver to unscrew the 3/16 inch screw that attaches the speaker's cover the the back case.
    • Once unscrewed, pick up the case and put it to the side.
    FixBotに聞いてみる
    コメントを追加
  9. Replacing Creative Zen X-Fi Speaker, Removing the Speaker: 手順 9、 1の画像 1
    この手順で使用する道具:
    • With the speaker exposed, use a pair of tweezers to lift the speaker out of the slot.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Westley Courchene
メンバー登録日: 01/13/15
3,410 ポイント
14のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 42
今までの合計 727
