メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Replacing Creative Zen X-Fi Battery
必要な工具と部品
  1. Replacing Creative Zen X-Fi Battery, Detaching Front Case: 手順 1、 3の画像 1 Replacing Creative Zen X-Fi Battery, Detaching Front Case: 手順 1、 3の画像 2 Replacing Creative Zen X-Fi Battery, Detaching Front Case: 手順 1、 3の画像 3
    • Using a spudger, wedge the tip between the front and back case to pry them apart.
    • Be careful to not apply excessive force since there are six fasteners on the screen's side that holds the cases firmly together.
    FixBotに聞いてみる
    コメントを追加
  2. Replacing Creative Zen X-Fi Battery, Rubber Button Cover: 手順 2、 1の画像 1
    • The black rubber button pad can be removed by simply picking it up.
    FixBotに聞いてみる
    コメントを追加
  3. Replacing Creative Zen X-Fi Battery, Button Input Chip Part 1: 手順 3、 1の画像 1
    • Flip the LCD screen off the midsection plate to gain access to the space around the input button chip.
    FixBotに聞いてみる
    コメントを追加
  4. Replacing Creative Zen X-Fi Battery, Button Input Chip: 手順 4、 1の画像 1
    • Using a spudger, pry off the button input chip from the mid-section of the device. To gain best leverage, start at the bottom right corner and level your way up the side of the chip.
    • Be aware that the button input chip is glued to the mid-section, so some extra force may be required.
    FixBotに聞いてみる
    コメントを追加
  5. Replacing Creative Zen X-Fi Battery, Access Midsection Plate: 手順 5、 1の画像 1
    • Lift open the LCD screen and button input chip to access the entire midsection plate.
    FixBotに聞いてみる
    コメントを追加
  6. Replacing Creative Zen X-Fi Battery, Unscrew below Button Chip: 手順 6、 1の画像 1
    • Use a Phillips Head screwdriver to unscrew the three 3/16 inch screws that were underneath the button input chip.
    FixBotに聞いてみる
    コメントを追加
  7. Replacing Creative Zen X-Fi Battery, Unscrew below LCD Screen: 手順 7、 1の画像 1
    • Use a Phillips Head screwdriver to unscrew the three 3/16 inch screws that were underneath the LCD screen.
    FixBotに聞いてみる
    コメントを追加
  8. Replacing Creative Zen X-Fi Battery, Separating the Battery: 手順 8、 1の画像 1
    • Use a spudger to pry the battery from the midsection plate.
    • There is adhesive glue underneath the battery, so additional force might be required to separate the battery.
    FixBotに聞いてみる
    コメントを追加
  9. Replacing Creative Zen X-Fi Battery, Disconnecting Power Supply: 手順 9、 2の画像 1 Replacing Creative Zen X-Fi Battery, Disconnecting Power Supply: 手順 9、 2の画像 2
    • Locate the soldering joint connecting the battery wires to the power supply, marked by the letters "PS" on the motherboard.
    • Hold the battery wires in place so that access to the soldering joints is not blocked.
    • When using a soldering iron, keep your hands and fingers as far as possible from the iron's tip to avoid burning your skin.
    • Using a soldering iron, melt the solder connecting the red wire to the motherboard. Do the same action to the black wire.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
5 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Westley Courchene
メンバー登録日: 01/13/15
3,410 ポイント
14のガイドは作成済み
2件のガイドコメント
very clear pictures!
John - 返信 共有
разбирать нужно со стороны противоположной гнезда наушников!!! поломал так же как и на фото все защелки со стороны кнопок(
Cooper21 - 返信 共有
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 23
過去 30 日: 88
今までの合計 8,763
