メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Repairing Quasar Microwave Sparking Inside
必要な工具と部品
  1. Repairing Quasar Microwave Sparking Inside, Disassembling Quasar Microwave Outer Cover: 手順 1、 1の画像 1
    • Disconnect the power supply cord from the outlet.
    FixBotに聞いてみる
    コメントを追加
  2. Repairing Quasar Microwave Sparking Inside: 手順 2、 2の画像 1 Repairing Quasar Microwave Sparking Inside: 手順 2、 2の画像 2
    • Remove the eight screws holding the wood-patterned cover to the microwave frame.
    • The first four screws are located on either side of the microwave front.
    FixBotに聞いてみる
    コメントを追加
  3. Repairing Quasar Microwave Sparking Inside: 手順 3、 2の画像 1 Repairing Quasar Microwave Sparking Inside: 手順 3、 2の画像 2
    • Remove the additional four screws securing the wood-paneled case to the microwave frame.
    FixBotに聞いてみる
    コメントを追加
  4. Repairing Quasar Microwave Sparking Inside: 手順 4、 3の画像 1 Repairing Quasar Microwave Sparking Inside: 手順 4、 3の画像 2 Repairing Quasar Microwave Sparking Inside: 手順 4、 3の画像 3
    • Placing your hands on either side of the case, slide the case back gently until you feel it completely separate from the microwave frame.
    • Lift the case upward slowly until the case is free of the microwave.
    FixBotに聞いてみる
    コメントを追加
  5. Repairing Quasar Microwave Sparking Inside, Sparking: 手順 5、 1の画像 1
    • First check to see if the interior of the microwave is dirty. Food or tin foil could be the reason that the microwave is sparking.
    • If the interior of the microwave is dirty, clean it. A spotless interior is recommended. The interior should look like the example in the picture.
    FixBotに聞いてみる
    コメントを追加
  6. Repairing Quasar Microwave Sparking Inside: 手順 6、 1の画像 1
    • If the microwave continues to spark after the interior has been cleaned, that could indicate that the diode may be broken. The diode is what attaches the capacitor to the back of the microwave.
    • A multimeter can be used to measure the resistance of the diode. The multimeter must be on the resistance setting or the diode check setting. If the diode reads zero in both directions, then it is broken.
    FixBotに聞いてみる
    コメントを追加
  7. Repairing Quasar Microwave Sparking Inside: 手順 7、 1の画像 1
    • Sparking inside of the microwave may also be the result of a broken or misaligned magnetron. If this is the case, it is recommended to take the microwave to a qualified professional or completely discarding the unit and purchasing a new one.
    • Fixing the magnetron without the aid of a qualified professional is NOT recommended. The magnetron is an emitter of microwave radiation and tampering with it may lead to serious injury or death.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
7 の人々がこのガイドを完成させました。
作成者
8人の作成者と共同で作成されました。
Michael
メンバー登録日: 09/26/12
237 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 2-12, Propen Fall 2012 Cal Poly, Team 2-12, Propen Fall 2012人のメンバー
CPSU-PROPEN-F12S2G12
3 メンバー
18のガイドは作成済み
2件のガイドコメント
Is the magnetron the failing component if you have this microwave or perhaps a 1983-1985 model quasar brand and the microwave doesn’t turn on after hitting “start”, a timer goes but no microwave heating is engaged?
Eric Ouyang - 返信 共有
This might be:
- A broken diode
- A faulty capacitor
- Or something else like a severed wire between the transformer and magnetron, a failing transformer or a failing magnetron.
Always be extra careful when opening a microwave oven as the capacitor may contain a deadly electric charge.
Unplug the microwave for at least 24 hours before opening it to reduce risks and use insulated tools and gloves.
Brendan - 返信 共有
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 9
過去 30 日: 46
今までの合計 5,344
