メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Repairing Internet Explorer Crashes
    1. Repairing Internet Explorer Crashes, Restore Advanced Application Settings: 手順 1、 1の画像 1
      • Restore the advanced application settings including the ActiveX Filtering and dialog Pop-Up box settings. You’ll be prompted to remove the personal configurations as well. Check-up that box in order to successfully restore all the settings.
      • Close all other applications and open Internet Explorer.
      • Click Tools -> Internet Options.
      • Click Reset button after checking-up the “Delete personal settings” checkbox.
      FixBotに聞いてみる
      コメントを追加
    2. Repairing Internet Explorer Crashes, Filter Malfunctioning Extensions: 手順 2、 1の画像 1
      • Filter the malfunctioning extensions. Disable all the extensions which are not functioning properly. The list of all extensions is displayed in a dialog box after performing the steps given below:
      • First show the menu bar by pressing the Alt key of your keyboard.
      • Click Tools -> Manage Add-Ons.
      • Set Show -> All add-ons.
      • Filter unwanted extensions including those not working properly.
      FixBotに聞いてみる
      コメントを追加
    3. Repairing Internet Explorer Crashes, Check Internet DNS Configs: 手順 3、 1の画像 1
      • The Internet DNS Configurations might have been changed. Incorrect DNS configurations are one of the reasons behind this issue.
      • Press the Windows Key and X keys simultaneously, and then select the Command Prompt (Admin).
      • Type below commands one by one and press ENTER at the end of each command: • ipconfig /flushdns • ipconfig /registerdns • ipconfig /release
      • Exit Command Prompt and then reboot your PC.
      FixBotに聞いてみる
      コメントを追加
      • A Troubleshooter tool automatically detects and repairs the Internet Explorer crashes problem. All you’ve to do is-
      • Download the tool called ZombieSoftFix.
      • Install the program on your PC.
      • Follow the on-screen instructions until your problem is completely fixed.
      FixBotに聞いてみる
      コメントを追加
    4. Repairing Internet Explorer Crashes, Uninstall & Reinstall it again: 手順 5、 1の画像 1
      • Some IE files can be corrupt. Uninstalling and reinstalling the same will fix the issue.
      • Insert the Windows OS disc.
      • Press Windows Key and X simultaneously.
      • Click Programs and Features -> Turn Windows features on or off.
      • Uninstall IE and reinstall it again. A system reboot requires.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
10 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
VikasMedhekar
メンバー登録日: 12/10/14
962 ポイント
1ガイドが承認済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 11
過去 30 日: 50
今までの合計 2,723
