メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
この翻訳は、ソースガイドの最新の更新を反映していない可能性があります。 翻訳の更新に協力してください。 または ソースガイドを参照してください
Repair electronics
    • Seen from below, the handpiece is oval-shaped. Wrap with a cloth, with a pair of pliers, a nutcracker or similar. start where the feet are and put the oval in a circle. At the same time, press the handpiece upside down, ie with the metal shank in front, onto a wooden base, whereby the inner life is expelled.
    FixBotに聞いてみる
    コメントを追加
  1. Repair electronics, Remove handpiece base: 手順 2、 1の画像 1
    • Remove the underside of the handpiece by carefully lifting the tabs at the two farthest vertexes of the oval with a small screwdriver.
    FixBotに聞いてみる
    コメントを追加
  2. Repair electronics, Remove the rubber pad from the motherboard: 手順 3、 1の画像 1
    • Remove the rubber pad from the motherboard
    FixBotに聞いてみる
    コメントを追加
  3. Repair electronics, Remove plastic cap from metal shaft: 手順 4、 1の画像 1
    • Use a puller to remove the plastic cap from the metal shaft to expose the defective rubber boot.
    FixBotに聞いてみる
    コメントを追加
    • Thoroughly clean all housing parts with water and cloth.
    • Thoroughly clean the electronics and mechanics with isopropyl alcohol and a fine brush.
    • Also completely rid the metal shaft of any residue.
    FixBotに聞いてみる
    コメントを追加
  4. Repair electronics, Repair electronics: 手順 6、 1の画像 1
    • Place the inner workings of the handpiece without housing parts in a container in such a way that the main board points downwards and the battery points upwards.
    • Now fill the container with isopropyl alcohol just enough so that the liquid level reaches the circuit board.
    • Leave to stand for 1-2 hours under supervision, then remove the device from the liquid bath and allow to dry.
    FixBotに聞いてみる
    コメントを追加
  5. Repair electronics, Replace rubber sleeve: 手順 7、 1の画像 1
    • The defective rubber sleeve on the metal shaft must be replaced. A spare part is available for less than € 4 on eBay under the following designation: "Philips electric toothbrush Waterproof sealing parts for HX6730 HX6930 HX9340».
    FixBotに聞いてみる
    コメントを追加
終わりに
Repeat the steps in order to reassemble your device.
キャンセル: このガイドを終了できませんでした。
ある他の人がこのガイドを完成しました。
以下の翻訳者の皆さんにお礼を申し上げます:
de en
94%
irlandaさんは世界中で修理する私たちを助けてくれています! あなたも貢献してみませんか?
翻訳を始める ›
作成者
2人の作成者と共同で作成されました。
Gerd Conzetti
メンバー登録日: 11/12/17
319 ポイント
2のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 9
過去 30 日: 66
今までの合計 1,766
