メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Remove Solid-State Drive (SSD)
必要な工具と部品
  1. Remove Solid-State Drive (SSD), Remove screws from bottom of laptop.: 手順 1、 2の画像 1 Remove Solid-State Drive (SSD), Remove screws from bottom of laptop.: 手順 1、 2の画像 2
    • Flip the computer over to access the screws on the bottom.
    • Remove 8 black, 7mm PH0 screws (M2 x L7).
    • Note: Virtually all the other screws for this computer are PH1 screws which may get stripped when using a smaller screwdriver, but these screws require a Philips PH0 driver.
    FixBotに聞いてみる
    コメントを追加
    • Pry up the clips/latches and then remove the lower case. Start at the front (four clips), then sides (three clips each side) and back (four clips) - there is also one clip in the middle of the case.
    FixBotに聞いてみる
    コメントを追加
  2. Remove Solid-State Drive (SSD), Disconnect battery cable: 手順 3、 1の画像 1
    • Almost anything that is done with a computer is safer if the battery is disconnected, so it is good to do that now.
    • Disconnect the battery pack cable from the system board using fingernails or a pry bar. Use your fingernails to pull the connector to unplug it. Do not pull the cable. It can be very tight. I used a 3.5 mm flathead screwdriver to carefully push the side plastic edges down towards the battery. Do not knock any of the components on the board.
    FixBotに聞いてみる
    コメントを追加
  3. Remove Solid-State Drive (SSD), Remove the system board mylar: 手順 4、 2の画像 1 Remove Solid-State Drive (SSD), Remove the system board mylar: 手順 4、 2の画像 2
    • Remove the system board mylar.
    • Note: Retain the system board mylar and reuse it when reassembling the computer. Replace the system board mylar only if it is damaged.
    FixBotに聞いてみる
    コメントを追加
  4. Remove Solid-State Drive (SSD), Remove the solid-state drive (SSD) shielding: 手順 5、 1の画像 1
    • Remove 4 black PH1 screws (M2 x L4) and then remove the SSD shielding.
    • Note: Virtually all the screws for this computer are PH1 screws which may get stripped if you use a smaller screwdriver.
    FixBotに聞いてみる
    コメントを追加
  5. Remove Solid-State Drive (SSD), Unscrew Solid-State Drives (SSD): 手順 6、 1の画像 1
    • Remove 2 silver 2mm PH1 screws (M2 x L2), one for each SSD.
    FixBotに聞いてみる
    コメントを追加
    • Remove each SSD by pulling it away from the slot.
    • Note: it may be important to replace the SSDs into the same slot, so label them in some manner - perhaps "T" for the top one and "B" for the bottom one.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
作成者
1人の作成者と共同作成されました。
johann beda
メンバー登録日: 09/13/10
3,428 ポイント
15のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 30
今までの合計 141
