メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Remove RAM
必要な工具と部品
特集記事
  1. Remove RAM, Remove screws from bottom of laptop.: 手順 1、 2の画像 1 Remove RAM, Remove screws from bottom of laptop.: 手順 1、 2の画像 2
    • Flip the computer over to access the screws on the bottom.
    • Remove 8 black, 7mm PH0 screws (M2 x L7).
    • Note: Virtually all the other screws for this computer are PH1 screws which may get stripped when using a smaller screwdriver, but these screws require a Philips PH0 driver.
    FixBotに聞いてみる
    コメントを追加
    • Pry up the clips/latches and then remove the lower case. Start at the front (four clips), then sides (three clips each side) and back (four clips) - there is also one clip in the middle of the case.
    FixBotに聞いてみる
    コメントを追加
  2. Remove RAM, Disconnect battery cable: 手順 3、 1の画像 1
    • Almost anything that is done with a computer is safer if the battery is disconnected, so it is good to do that now.
    • Disconnect the battery pack cable from the system board using fingernails or a pry bar. Use your fingernails to pull the connector to unplug it. Do not pull the cable. It can be very tight. I used a 3.5 mm flathead screwdriver to carefully push the side plastic edges down towards the battery. Do not knock any of the components on the board.
    FixBotに聞いてみる
    コメントを追加
  3. Remove RAM, Remove battery screws: 手順 4、 1の画像 1
    • Remove 6 black 4mm PH1 screws (M2 x L4). The lower right screw is close to a magnet that may pull it from where you want it to go - tweezers may be necessary. The Hardware Maintenance Manual does not show the bottom middle screw.
    • Note: Virtually all the screws for this computer are PH1 screws which may get stripped if you use a smaller screwdriver.
    FixBotに聞いてみる
    コメントを追加
    • Lift out the battery.
    FixBotに聞いてみる
    コメントを追加
  4. Remove RAM, Remove the system board mylar: 手順 6、 2の画像 1 Remove RAM, Remove the system board mylar: 手順 6、 2の画像 2
    • Remove the system board mylar.
    • Note: Retain the system board mylar and reuse it when reassembling the computer. Replace the system board mylar only if it is damaged.
    FixBotに聞いてみる
    コメントを追加
  5. Remove RAM, Remove the solid-state drive (SSD) shielding: 手順 7、 1の画像 1
    • Remove 4 black PH1 screws (M2 x L4) and then remove the SSD shielding.
    FixBotに聞いてみる
    コメントを追加
  6. Remove RAM, Unscrew Solid-State Drives (SSD): 手順 8、 1の画像 1
    • Remove 2 silver 2mm PH1 screws (M2 x L2), one for each SSD.
    FixBotに聞いてみる
    コメントを追加
    • Remove each SSD by pulling it away from the slot.
    • Note: it may be important to replace the SSDs into the same slot, so label them in some manner - perhaps "T" for the top one and "B" for the bottom one.
    FixBotに聞いてみる
    コメントを追加
  7. Remove RAM, Remove the Wi-Fi card: 手順 10、 1の画像 1
    • Detach the main and auxiliary antenna cable connectors. Note which colour cable is connected to each post - the photographed board has a grey cable connected to the top post (marked as "#1 Aux" with a white triangle on the Wi-Fi card) and a black cable connected to the bottom post (marked as "#2 Main" with a black triangle on the Wi-Fi card).
    • Remove 1 silver 2mm PH1 screw (M2 x L2).
    • Remove the Wi-Fi card by pulling it away from the slot.
    FixBotに聞いてみる
    コメントを追加
  8. Remove RAM, Disconnect tape and cables: 手順 11、 1の画像 1
    • (1) Peel off the thermal DIMM plate tape from the system board.
    • (2-3) Lift flap and disconnect the I/O board cable from the system board.
    • (2-3) Lift flap and disconnect the audio FPC cable from the system board.
    • (2-3) Lift flap and disconnect the hinge cap lightingbar cable from the system board.
    • Note: my machine did not have the DIMM plate tape or the cable in the upper right.
    FixBotに聞いてみる
    コメントを追加
  9. Remove RAM, Disconnect the fan cables: 手順 12、 1の画像 1
    • Disconnect the three fan cables from the system board by lifting away from board.
    FixBotに聞いてみる
    コメントを追加
  10. Remove RAM, Remove screws and fans: 手順 13、 1の画像 1
    • Remove 7 black 6mm PH1 screws (M2 x L6) holding the fans.
    • Remove tape from fans - possibly using gentle heat
    • Remove the fans - be careful of Wi-Fi antenna cables around top left fan and speaker cable around small bottom right fan.
    FixBotに聞いてみる
    コメントを追加
  11. Remove RAM, Disconnect cables: 手順 14、 1の画像 1
    • Disconnect 9 cables connected to the system board.
    FixBotに聞いてみる
    コメントを追加
  12. Remove RAM, Disconnect more cables: 手順 15、 1の画像 1
    • Disconnect five more cables from the system board
    FixBotに聞いてみる
    コメントを追加
    • Remove 3 black 4mm PH1 screws (M2 x L4) screws
    • Remove 2 black 6mm PH1 screws (M2 x L4) screws
    • Remove the flaps of tape holding the antenna wires to the board.
    • Remove the system board module carefully.
    FixBotに聞いてみる
    コメントを追加
    • Position the board over so that the heat sink tubes are on the top
    • Remove the sheet over the RAM modules.
    • Release the latches on both edges of the each socket at the same time to remove each memory module.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
作成者
1人の作成者と共同作成されました。
johann beda
メンバー登録日: 09/13/10
3,428 ポイント
15のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 20
今までの合計 97
