メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Remove Outer Case
必要な工具と部品
  1. Remove Outer Case, Prepare the Printer.: 手順 1、 2の画像 1 Remove Outer Case, Prepare the Printer.: 手順 1、 2の画像 2
    • Remove the printer from the optional second paper tray.
    • Pull out the paper tray from the front, and the duplexer from the rear.
    • Removing the print head (see the HP user guide) may also reduce the chance of ink leakage while working on the printer.
    FixBotに聞いてみる
    コメントを追加
  2. Remove Outer Case, Control Panel: 手順 2、 2の画像 1 Remove Outer Case, Control Panel: 手順 2、 2の画像 2
    • Hold up the control panel with one hand, reach underneath it with the other, and pull firmly downward on the curved support to detach it from the display
    • Lifting the display further up, reach behind the brown plastic cover, and pull it forwards to release it
    FixBotに聞いてみる
    コメントを追加
  3. Remove Outer Case, Control Panel: 手順 3、 3の画像 1 Remove Outer Case, Control Panel: 手順 3、 3の画像 2 Remove Outer Case, Control Panel: 手順 3、 3の画像 3
    • Rest the machine on it's rear panel, so you can access the cable.
    • Lift up the brown clamp, and pull out the cable
    • Using a T-10 Torx screwdriver, undo the two screws beneath the display (pictured)
    • The display remains attached to the scanner assembly for now. If you need to detach it from the scanner - for instance, to operate the printer while it is open - you can detach it once the scanner assembly is removed.
    FixBotに聞いてみる
    コメントを追加
  4. Remove Outer Case, Left Side (Controller Board) Panel: 手順 4、 3の画像 1 Remove Outer Case, Left Side (Controller Board) Panel: 手順 4、 3の画像 2 Remove Outer Case, Left Side (Controller Board) Panel: 手順 4、 3の画像 3
    • On the back of the printer, remove the two screws on the right hand side (left-hand when viewed from the front.
    • Open the door on the front of the computer, and remove the one screw on the lower left-hand side.
    • Using a spudger lever firmly outwards on the lower rear side of the panel.
    • With your other hand, push the panel backwards, It will slide half a centimeter backwards and come free.
    • Could you help me? It would be useful if you could take an image of the rear of the printer, add it to this guide, so the locations of various screws can be marked.
    FixBotに聞いてみる
    コメントを追加
  5. Remove Outer Case, Disconnect Cables: 手順 5、 1の画像 1
    • Disconnect the scanner flatfex, sheet feeder and LED cables (marked in red).
    • Remove the earth strap (marked in yellow).
    • No other cables need to be removed at this time.
    FixBotに聞いてみる
    コメントを追加
  6. Remove Outer Case, Remove the scanner assembly: 手順 6、 2の画像 1 Remove Outer Case, Remove the scanner assembly: 手順 6、 2の画像 2
    • Remove the remaining screws around the top of the printer.
    • Lift the scanner assembly away from the printer.
    • If you need to detach the display, lay the scanner assembly upside down, lower the display assembly, push it to the right, and then adjust the angle of the display until it drops away from the scanner. Reconnect it to the flat-flex cable, and clip the support back into the rear to hold it. The printer will operate normally without the scanner.
    FixBotに聞いてみる
    コメントを追加
  7. Remove Outer Case, Remove the output tray: 手順 7、 3の画像 1 Remove Outer Case, Remove the output tray: 手順 7、 3の画像 2 Remove Outer Case, Remove the output tray: 手順 7、 3の画像 3
    • Depress the two clips at the rear of the output tray, and pull the tray forward.
    • Rest the printer on its rear panel, depress the two clips under the tray, and slide the white support clear of the tray.
    • Pull the output tray clear.
    FixBotに聞いてみる
    コメントを追加
  8. Remove Outer Case, Remove the right hand side panel.: 手順 8、 1の画像 1
    • Remove the single silver screw (pictured)
    • Remove the two screws from the rear left-hand side (right hand when viewed from the front)
    FixBotに聞いてみる
    コメントを追加
  9. Remove Outer Case, Remove the Right-Hand Side Panel (cont.): 手順 9、 3の画像 1 Remove Outer Case, Remove the Right-Hand Side Panel (cont.): 手順 9、 3の画像 2 Remove Outer Case, Remove the Right-Hand Side Panel (cont.): 手順 9、 3の画像 3
    • Release the one clip on the inside front of the panel.
    • Release the two clips on the underside of the printer.
    FixBotに聞いてみる
    コメントを追加
  10. Remove Outer Case, Remove the Right-Hand Side Panel (cont): 手順 10、 2の画像 1 Remove Outer Case, Remove the Right-Hand Side Panel (cont): 手順 10、 2の画像 2
    • Pull outwards on the front to release a hidden clip.
    • Rotate the panel outwards until the clips on the rear of the panel detach.
    • If the panel doesn't detach easily, it may help to remove the screws securing the back panel first.
    FixBotに聞いてみる
    コメントを追加
  11. Remove Outer Case, Remove the rear panel: 手順 11、 1の画像 1
    • Remove the remaining screws on the rear of the printer.
    • Detach the rear panel.
    FixBotに聞いてみる
    コメントを追加
  12. Remove Outer Case, Remove the power button cover: 手順 12、 3の画像 1 Remove Outer Case, Remove the power button cover: 手順 12、 3の画像 2 Remove Outer Case, Remove the power button cover: 手順 12、 3の画像 3
    • Using multple tools and considerable force, unclip the power button cover from the bottom.
    • Concentrate on the points marked with arrows. This is the location of the clips. Forcing a plastic spudger in at these points should release this cover.
    FixBotに聞いてみる
    コメントを追加
    • Release trims in the left-hadn quater panel
    • There are clips on the side, underneath, and two from the top.
    FixBotに聞いてみる
    コメントを追加
  13. Remove Outer Case, Detach the front door.: 手順 14、 2の画像 1 Remove Outer Case, Detach the front door.: 手順 14、 2の画像 2
    • Detach the NFC connector from the circuitboard, (Socket location marked in red) and pull the cable free from its restraints.
    • Bend the flexible flap attached to the front door upwards, then pull the studs free from the guides.
    • Pull the three hinges out of their clamps, and remove the front door.
    FixBotに聞いてみる
    コメントを追加
  14. Remove Outer Case, Remove the Front Panel: 手順 15、 3の画像 1 Remove Outer Case, Remove the Front Panel: 手順 15、 3の画像 2 Remove Outer Case, Remove the Front Panel: 手順 15、 3の画像 3
    • Remove the power button, door sensor, and USB cables from the circuit board.
    • Slide back the catch on the Ctrl Panel socket, and remove the flat-flex.
    • Many repairs may not require this panel to be fully removed, so these cables may be left attached, if care is taken not to damage them.
    • Remove the 2 screws on the front left, and the one on the front right.
    • Release the clips in the paper output area
    • Pull the front panel free.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Robert Backhaus
メンバー登録日: 11/10/12
1,030 ポイント
5のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 11
過去 30 日: 50
今までの合計 1,813
