メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Remote shutter mod (wired)
必要な工具と部品
    • I will hopefully add more details in the future.
    FixBotに聞いてみる
    コメントを追加
  1. Remote shutter mod (wired), Solder a wire onto a main board: 手順 2、 3の画像 1 Remote shutter mod (wired), Solder a wire onto a main board: 手順 2、 3の画像 2 Remote shutter mod (wired), Solder a wire onto a main board: 手順 2、 3の画像 3
    • Use thin short piece of wire and decide where to put it so it will not be in interference with other components inside assembled camera. The wire will be connected to both sides of the main board.
    • Cut required length of the wire and cut the insulation on its ends.
    • Optional: use some electrical adhesive tape (not very sticky) to hold the wire on the right place while soldering. Watch where are you putting it - not over any small sensitive components
    • Solder the wire to the pins as on the pictures
    FixBotに聞いてみる
    コメントを追加
    • Insert the modified mainboard, put everything to its place and close the camera. Simply reverse the disassembly procedure
    FixBotに聞いてみる
    コメントを追加
  2. Remote shutter mod (wired), Create your custom shutter connector: 手順 4、 3の画像 1 Remote shutter mod (wired), Create your custom shutter connector: 手順 4、 3の画像 2 Remote shutter mod (wired), Create your custom shutter connector: 手順 4、 3の画像 3
    • Use some standard micro USB male connector/cable
    • You can connect some remote shutter to it, or just a button which allows the lines to connect.
    • Pinout as is on the picture
    • sorry for the drawing of microUSB, it looks like half female (because of the inside) and half male. It's supposed to be male connector. But the positions of the pins are correct.
    FixBotに聞いてみる
    コメントを追加
終わりに
I am not author of the mod, but I will definitely try it in the future.
Pictures are taken from here:
http://przewodnicy.zakopane.pl/rozne/RX1...
Short demonstration is visible here:
https://www.youtube.com/watch?v=3m_yFcxR...
Unfortunately I don't have an option to use any soldering iron or my small tools at the moment, so I will not try it during this year (2017). But it's good to have this guide here.
キャンセル: このガイドを終了できませんでした。
作成者
1人の作成者と共同作成されました。
Matej Cermak
メンバー登録日: 10/22/17
109 ポイント
1ガイドが承認済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 57
今までの合計 3,613
