はじめに
From creating macros to mapping controls, the Redragon Impact M908's programmable side buttons are a core feature of the mouse. Malfunctioning side buttons can be a critical issue, especially when performing time-sensitive tasks, such as playing online video games, leading to frustration during use. This replacement guide will walk you through the steps to replace the Redragon Impact M908's programmable side buttons.
Additionally, we use a metal spudger; however, any flat object with a pointed edge will work. Before beginning, ensure your mouse is unplugged from all devices.
必要な工具と部品
Pick up your mouse and flip it over.
Reposition the mouse so that the four feet pads are facing you.
Unscrew the right 3mm screw using a Phillips #000 screwdriver.
Unscrew the remaining four 4mm screws using a Phillips #00 screwdriver.
ある他の人がこのガイドを完成しました。
