メインコンテンツにスキップ
Razer Naga Trinity Scroll Wheel Housing Replacement
必要な工具と部品
  1. Razer Naga Trinity Scroll Wheel Housing Replacement, Razer Naga Trinity Disassembly: 手順 1、 2の画像 1 Razer Naga Trinity Scroll Wheel Housing Replacement, Razer Naga Trinity Disassembly: 手順 1、 2の画像 2
    • Remove the interchangeable side plate.
  2. Razer Naga Trinity Scroll Wheel Housing Replacement: 手順 2、 2の画像 1 Razer Naga Trinity Scroll Wheel Housing Replacement: 手順 2、 2の画像 2
    • Remove the mouse's feet using the opening pick.
    Be aware that it’s possible to peel the feet from the glue layer.
    SteepPoppy0 - 返信
  3. Razer Naga Trinity Scroll Wheel Housing Replacement: 手順 3、 1の画像 1
    • Remove the four 6mm screws by using a JIS #1 screwdriver.
  4. Razer Naga Trinity Scroll Wheel Housing Replacement: 手順 4、 2の画像 1 Razer Naga Trinity Scroll Wheel Housing Replacement: 手順 4、 2の画像 2
    • Separate the top mouse housing from the bottom mouse housing using the opening pick.
    • Be careful not to tug too hard on the ribbon connector.
  5. Razer Naga Trinity Scroll Wheel Housing Replacement: 手順 5、 1の画像 1
    • Unlock the ribbon connector that is held down by the main board clips using the spudger's pointed end.
  6. Razer Naga Trinity Scroll Wheel Housing Replacement: 手順 6、 1の画像 1
    • Remove the side housing using the opening pick.
  7. Razer Naga Trinity Scroll Wheel Housing Replacement: 手順 7、 2の画像 1 Razer Naga Trinity Scroll Wheel Housing Replacement: 手順 7、 2の画像 2
    • Remove the top housing LED 3-Pin connector that is near the main board.
  8. Razer Naga Trinity Scroll Wheel Housing Replacement, Scroll Wheel Housing: 手順 8、 2の画像 1 Razer Naga Trinity Scroll Wheel Housing Replacement, Scroll Wheel Housing: 手順 8、 2の画像 2
    • Remove one 4mm black Phillips #000 screw from the left side of the mouse holding the scroll wheel LED controller board.
    • Then pull the LED controller board upwards and out.
  9. Razer Naga Trinity Scroll Wheel Housing Replacement: 手順 9、 1の画像 1
    この手順で使用する道具:
    Halberd Spudger
    $2.99
    • Pry and remove the scroll wheel feedback bar from its hold-down clips using the hook end of a halberd spudger.
  10. Razer Naga Trinity Scroll Wheel Housing Replacement: 手順 10、 1の画像 1
    この手順で使用する道具:
    $3.99
    • Remove the scroll wheel feedback bar from the scroll wheel by holding down the spring and using angled tweezers to remove it from its placement.
  11. Razer Naga Trinity Scroll Wheel Housing Replacement: 手順 11、 2の画像 1 Razer Naga Trinity Scroll Wheel Housing Replacement: 手順 11、 2の画像 2
    • Remove the scroll wheel optical encoder 3-pin connector from the main board by wiggling the connector upwards.
  12. Razer Naga Trinity Scroll Wheel Housing Replacement: 手順 12、 3の画像 1 Razer Naga Trinity Scroll Wheel Housing Replacement: 手順 12、 3の画像 2 Razer Naga Trinity Scroll Wheel Housing Replacement: 手順 12、 3の画像 3
    • Using the opening tool, pry the black bracket holding the scroll wheel in place backwards until the scroll wheel housing pops out.
    You don't have to remove that part, if you're careful you can leave the mouse wheel attatched to the mainboard because it's pretty fiddly to get the feather inside again.
    Andreas - 返信
終わりに
2 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Kristen Gismondi
メンバー登録日: 11/12/14
92,508 ポイント
241のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
118 メンバー
19,623のガイドは作成済み
2 Guide Comments
can you give a link for a replacement scroll wheel if possible?
joe - 返信
nice guide but i sadly didn’t found any housing wheel replacement part ><
Zzz Zzz - 返信
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 15
過去 30 日: 73
今までの合計 4,963
