メインコンテンツにスキップ
Razer Naga Trinity LK-E5 Optical Encoder Replacement
必要な工具と部品
  1. Razer Naga Trinity LK-E5 Optical Encoder Replacement, Razer Naga Trinity Disassembly: 手順 1、 2の画像 1 Razer Naga Trinity LK-E5 Optical Encoder Replacement, Razer Naga Trinity Disassembly: 手順 1、 2の画像 2
    • Remove the interchangeable side plate.
  2. Razer Naga Trinity LK-E5 Optical Encoder Replacement: 手順 2、 2の画像 1 Razer Naga Trinity LK-E5 Optical Encoder Replacement: 手順 2、 2の画像 2
    • Remove the mouse's feet using the opening pick.
  3. Razer Naga Trinity LK-E5 Optical Encoder Replacement: 手順 3、 1の画像 1
    • Remove the four 6mm screws by using a JIS #1 screwdriver.
  4. Razer Naga Trinity LK-E5 Optical Encoder Replacement: 手順 4、 2の画像 1 Razer Naga Trinity LK-E5 Optical Encoder Replacement: 手順 4、 2の画像 2
    • Separate the top mouse housing from the bottom mouse housing using the opening pick.
    • Be careful not to tug too hard on the ribbon connector.
  5. Razer Naga Trinity LK-E5 Optical Encoder Replacement: 手順 5、 1の画像 1
    • Unlock the ribbon connector that is held down by the main board clips using the spudger's pointed end.
  6. Razer Naga Trinity LK-E5 Optical Encoder Replacement: 手順 6、 1の画像 1
    • Remove the side housing using the opening pick.
  7. Razer Naga Trinity LK-E5 Optical Encoder Replacement: 手順 7、 2の画像 1 Razer Naga Trinity LK-E5 Optical Encoder Replacement: 手順 7、 2の画像 2
    • Remove the top housing LED 3-Pin connector that is near the main board.
  8. Razer Naga Trinity LK-E5 Optical Encoder Replacement, Scroll Wheel Housing: 手順 8、 2の画像 1 Razer Naga Trinity LK-E5 Optical Encoder Replacement, Scroll Wheel Housing: 手順 8、 2の画像 2
    • Remove one 4mm black Phillips #000 screw from the left side of the mouse holding the scroll wheel LED controller board.
    • Then pull the LED controller board upwards and out.
  9. Razer Naga Trinity LK-E5 Optical Encoder Replacement: 手順 9、 1の画像 1
    この手順で使用する道具:
    Halberd Spudger
    $2.99
    • Pry and remove the scroll wheel feedback bar from its hold-down clips using the hook end of a halberd spudger.
  10. Razer Naga Trinity LK-E5 Optical Encoder Replacement: 手順 10、 1の画像 1
    この手順で使用する道具:
    $3.99
    • Remove the scroll wheel feedback bar from the scroll wheel by holding down the spring and using angled tweezers to remove it from its placement.
  11. Razer Naga Trinity LK-E5 Optical Encoder Replacement: 手順 11、 2の画像 1 Razer Naga Trinity LK-E5 Optical Encoder Replacement: 手順 11、 2の画像 2
    • Remove the scroll wheel optical encoder 3-pin connector from the main board by wiggling the connector upwards.
  12. Razer Naga Trinity LK-E5 Optical Encoder Replacement: 手順 12、 3の画像 1 Razer Naga Trinity LK-E5 Optical Encoder Replacement: 手順 12、 3の画像 2 Razer Naga Trinity LK-E5 Optical Encoder Replacement: 手順 12、 3の画像 3
    • Using the opening tool, pry the black bracket holding the scroll wheel in place backwards until the scroll wheel housing pops out.
  13. Razer Naga Trinity LK-E5 Optical Encoder Replacement, LK-E5 Optical Encoder: 手順 13、 2の画像 1 Razer Naga Trinity LK-E5 Optical Encoder Replacement, LK-E5 Optical Encoder: 手順 13、 2の画像 2
    • Remove the scroll wheel from the scroll wheel housing using the opening tool.
  14. Razer Naga Trinity LK-E5 Optical Encoder Replacement: 手順 14、 2の画像 1 Razer Naga Trinity LK-E5 Optical Encoder Replacement: 手順 14、 2の画像 2
    • Remove the scroll wheel optical encoder from the scroll wheel.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Alexandros Andreou
メンバー登録日: 09/16/19
712 ポイント
3のガイドは作成済み
チーム
コメント 1 件
Where can we buy a replacement from?
Daniel - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 59
今までの合計 2,591
