メインコンテンツにスキップ
Razer Naga Epic Chroma Battery Replacement
必要な工具と部品
  1. Razer Naga Epic Chroma Battery Replacement, Razer Naga Epic Chroma Disassembly: 手順 1、 1の画像 1
    • Using a spudger, remove the teflon tape on the bottom of the mouse to reveal four screws.
  2. Razer Naga Epic Chroma Battery Replacement: 手順 2、 1の画像 1
    • Use a Phillips #00 screwdriver to remove the four screws.
  3. Razer Naga Epic Chroma Battery Replacement: 手順 3、 1の画像 1
    • Gently pull on the top plastic plate of the device and carefully unplug the white cord from the circuit board.
    • When removing the chassis, carefully unplug the cord connecting to the top mouse buttons.
  4. Razer Naga Epic Chroma Battery Replacement: 手順 4、 1の画像 1
    • Gently pull up on the right plate on the mouse; separating it.
    • Carefully repeat this step for the left side.
    • Be wary of the cable connecting to the twelve mouse buttons located on the left plate. This can be disconnected if needed.
  5. Razer Naga Epic Chroma Battery Replacement, Battery: 手順 5、 1の画像 1
    • Take your nylon spudger to gently pry the battery pack from the device.
    • Remove the foam on the battery shell for your new battery.
  6. Razer Naga Epic Chroma Battery Replacement: 手順 6、 1の画像 1
    • Unplug the power cord from the circuit board in the mouse.
  7. Razer Naga Epic Chroma Battery Replacement: 手順 7、 1の画像 1
    • Plug the cord of the new battery into the socket found in the bottom right of the circuit board.
    • Insert the new battery into the battery socket.
    • Place the foam on the surface of the new battery (reference Step 5).
終わりに
7 の人々がこのガイドを完成させました。
作成者
7人の作成者と共同で作成されました。
Jordan Morgan
メンバー登録日: 01/19/17
895 ポイント
6のガイドは作成済み
チーム
Arkansas State University, Team 1-4, Chamberlain Spring 2017 Arkansas State University, Team 1-4, Chamberlain Spring 2017人のメンバー
ARSU-CHAMBERLAIN-S17S1G4
4 メンバー
6のガイドは作成済み
13 件のコメント
Do you have battery for sell?
BcTwenty9 - 返信
You can purchase the battery from Amazon. I used the recommendation from ak48disk below, switching the battery leads: https://www.amazon.com/gp/product/B0767K...
Dan Mergens -
Anyone know where to buy a new battery?
Antony Lynch - 返信
Showing how to remove the old battery but not showing or writing what kind of battery one must have (type, where to buy, …) to replace the old one is somewhat stupid - really stupid!
Gooly - 返信
that battery appears to be very swollen………
Levi Coffey - 返信
コメントを追加
統計データ:
過去 24時間: 12
過去 7 日: 26
過去 30 日: 102
今までの合計 14,439
