メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Razer Deathadder V3 Pro Battery Replacement
必要な工具と部品
  1. Razer Deathadder V3 Pro Battery Replacement, Battery: 手順 1、 1の画像 1
    • Use an opening tool to remove the bottom skate from the mouse.
    • If you plan on reusing this skate, avoid touching the adhesive.
  2. Razer Deathadder V3 Pro Battery Replacement: 手順 2、 1の画像 1
    • Use a T6 Torx screwdriver to remove three 6.2mm screws along the bottom of the mouse.
  3. Razer Deathadder V3 Pro Battery Replacement: 手順 3、 3の画像 1 Razer Deathadder V3 Pro Battery Replacement: 手順 3、 3の画像 2 Razer Deathadder V3 Pro Battery Replacement: 手順 3、 3の画像 3
    • Use the opening tool to release the clips on the left and right sides of the mouse.
    • A fragile ribbon cable at the front of the mouse connects the top and bottom of the case.
    • Lift the back side of the top case, keeping the front edge of the case close to the base like an imaginary hinge.
  4. Razer Deathadder V3 Pro Battery Replacement: 手順 4、 1の画像 1
    • Lay the top case above the base and angled to the right, keeping the ribbon cable as loose as possible.
    • Carefully remove the ribbon cable from its connection. You may want to use tweezers for this step.
    • To avoid ribbon cable damage, only make contact with the stiff part of the cable closest to the connection.
  5. Razer Deathadder V3 Pro Battery Replacement: 手順 5、 2の画像 1 Razer Deathadder V3 Pro Battery Replacement: 手順 5、 2の画像 2
    • Inspect the battery connector before disconnecting. If the battery connection is loose but the battery itself is not swollen and appears to be in like-new condition, it is likely still functional and can usually be reconnected to restore normal operation.
    • Unplug the battery connector.
    • To avoid battery cable damage, pull from the white plastic connection, and do not pull from the wires.
  6. Razer Deathadder V3 Pro Battery Replacement: 手順 6、 1の画像 1
    • Use the opening tool to gently pry the battery from the base.
    • The battery is attached using adhesive/double-sided tape. Avoid touching the adhesive with your hands.
    • Caution: Puncturing a lithium polymer battery can lead to severe safety hazards. If your battery is swollen, refer to the Swollen Battery Guide.
  7. Razer Deathadder V3 Pro Battery Replacement: 手順 7、 2の画像 1 Razer Deathadder V3 Pro Battery Replacement: 手順 7、 2の画像 2
    • Install your new battery in the compartment. If the existing tape does not stick, remove the tape and use double sided tape to secure the battery in place.
終わりに
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
作成者
2人の作成者と共同で作成されました。
Nelson L
メンバー登録日: 10/27/25
145 ポイント
1ガイドが承認済み
チーム
Austin Community College, Team 64-8, Kapoor Fall 2025 Austin Community College, Team 64-8, Kapoor Fall 2025人のメンバー
AUSTINCC-KAPOOR-F25S64G8
1 メンバー
1のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 19
過去 30 日: 142
今までの合計 519
