メインコンテンツにスキップ
Razer Blade 15" (2018) Speakers Replacement
必要な工具と部品
  1. Razer Blade 15" (2018) Speakers Replacement, Prepare your laptop for disassembly: 手順 1、 2の画像 1 Razer Blade 15" (2018) Speakers Replacement, Prepare your laptop for disassembly: 手順 1、 2の画像 2
    • Allow your laptop's battery to drain below 25% before starting this repair—a charged battery may catch fire if damaged.
    • Unplug all cables, fully shut down your laptop, and close the lid.
  2. Razer Blade 15" (2018) Speakers Replacement, Unfasten the back cover: 手順 2、 1の画像 1
    • Rotate your laptop so the screen hinge is farthest from you.
    • Use a Torx T5 driver to remove the ten 3.8 mm-long screws securing the back cover.
  3. Razer Blade 15" (2018) Speakers Replacement, Insert an opening pick: 手順 3、 3の画像 1 Razer Blade 15" (2018) Speakers Replacement, Insert an opening pick: 手順 3、 3の画像 2 Razer Blade 15" (2018) Speakers Replacement, Insert an opening pick: 手順 3、 3の画像 3
    • Depending on the age and condition of your laptop, the back cover may come off sooner than this guide instructs. If the cover feels loose, remove it at any time.
    • Apply a suction handle to the right edge of the back cover, between the middle screws and the screws closest to you.
    • Pull up on the suction handle to create a small gap between the back cover and the frame.
    • Insert an opening pick into the gap.
  4. Razer Blade 15" (2018) Speakers Replacement, Angle the opening pick: 手順 4、 3の画像 1 Razer Blade 15" (2018) Speakers Replacement, Angle the opening pick: 手順 4、 3の画像 2 Razer Blade 15" (2018) Speakers Replacement, Angle the opening pick: 手順 4、 3の画像 3
    • Angle your opening pick upward, away from the frame. Keep it angled upward as long as it's between the back cover and the frame.
    • Insert your pick up to 10 mm (0.4 in) deep.
  5. Razer Blade 15" (2018) Speakers Replacement, Free the bottom right corner: 手順 5、 3の画像 1 Razer Blade 15" (2018) Speakers Replacement, Free the bottom right corner: 手順 5、 3の画像 2 Razer Blade 15" (2018) Speakers Replacement, Free the bottom right corner: 手順 5、 3の画像 3
    • Slide your opening pick around the bottom right corner of the back cover to free it from the frame.
  6. Razer Blade 15" (2018) Speakers Replacement, Free the front edge: 手順 6、 3の画像 1 Razer Blade 15" (2018) Speakers Replacement, Free the front edge: 手順 6、 3の画像 2 Razer Blade 15" (2018) Speakers Replacement, Free the front edge: 手順 6、 3の画像 3
    • Slide your opening pick along the front edge and around the front left corner of the back cover to free it from the frame.
  7. Razer Blade 15" (2018) Speakers Replacement, Remove the back cover: 手順 7、 3の画像 1 Razer Blade 15" (2018) Speakers Replacement, Remove the back cover: 手順 7、 3の画像 2 Razer Blade 15" (2018) Speakers Replacement, Remove the back cover: 手順 7、 3の画像 3
    • Remove the back cover.
    • Lay the back cover down on its rubber feet to avoid damaging the gray thermal pads on its underside.
  8. Razer Blade 15" (2018) Speakers Replacement, Soften the battery cable tape adhesive: 手順 8、 2の画像 1 Razer Blade 15" (2018) Speakers Replacement, Soften the battery cable tape adhesive: 手順 8、 2の画像 2
    • Apply a heated iOpener to the battery cable tape for one minute.
    • You can also use a hair dryer—but be careful, as overheating the battery may damage it or create a fire hazard.
  9. Razer Blade 15" (2018) Speakers Replacement, Peel up the battery cable tape: 手順 9、 3の画像 1 Razer Blade 15" (2018) Speakers Replacement, Peel up the battery cable tape: 手順 9、 3の画像 2 Razer Blade 15" (2018) Speakers Replacement, Peel up the battery cable tape: 手順 9、 3の画像 3
    この手順で使用する道具:
    • Be careful not to damage the battery with your tool.
    • Use blunt nose tweezers or your fingers to peel the battery cable tape away from the cable.
  10. Razer Blade 15" (2018) Speakers Replacement, Disconnect the battery: 手順 10、 3の画像 1 Razer Blade 15" (2018) Speakers Replacement, Disconnect the battery: 手順 10、 3の画像 2 Razer Blade 15" (2018) Speakers Replacement, Disconnect the battery: 手順 10、 3の画像 3
    • Use the point of a spudger to press on alternating sides of the battery connector and walk it out of its socket.
  11. Razer Blade 15" (2018) Speakers Replacement, Disconnect the left speaker: 手順 11、 3の画像 1 Razer Blade 15" (2018) Speakers Replacement, Disconnect the left speaker: 手順 11、 3の画像 2 Razer Blade 15" (2018) Speakers Replacement, Disconnect the left speaker: 手順 11、 3の画像 3
    • If you're only replacing the right speaker, skip the next three steps.
    • Use the point of a spudger to push on alternating sides of the left speaker connector to "walk" it out of its socket.
  12. Razer Blade 15" (2018) Speakers Replacement, Unfasten the left speaker: 手順 12、 1の画像 1
    • Use a Phillips screwdriver to remove the two 7.6 mm screws securing the left speaker.
    • Rubber grommets hold these screws in place. If the screws don't come out, just fully loosen them.
  13. Razer Blade 15" (2018) Speakers Replacement, Remove the left speaker: 手順 13、 2の画像 1 Razer Blade 15" (2018) Speakers Replacement, Remove the left speaker: 手順 13、 2の画像 2
    • Remove the left speaker.
  14. Razer Blade 15" (2018) Speakers Replacement, Disconnect the right speaker: 手順 14、 3の画像 1 Razer Blade 15" (2018) Speakers Replacement, Disconnect the right speaker: 手順 14、 3の画像 2 Razer Blade 15" (2018) Speakers Replacement, Disconnect the right speaker: 手順 14、 3の画像 3
    • If you only needed to replace the left speaker, skip the next three steps.
    • Use the point of your spudger to push on alternating sides of the right speaker connector to "walk" it out of its socket.
  15. Razer Blade 15" (2018) Speakers Replacement, Unfasten the right speaker: 手順 15、 1の画像 1
    • Use a Phillips screwdriver to remove the two 7.6 mm screws securing the right speaker.
  16. Razer Blade 15" (2018) Speakers Replacement, Remove the right speaker: 手順 16、 2の画像 1 Razer Blade 15" (2018) Speakers Replacement, Remove the right speaker: 手順 16、 2の画像 2
    • Remove the right speaker.
  17. Razer Blade 15" (2018) Speakers Replacement, Reassembly information: 手順 17、 2の画像 1 Razer Blade 15" (2018) Speakers Replacement, Reassembly information: 手順 17、 2の画像 2
    • During reassembly, make sure the rubber grommets are in place at each screw cutout.
終わりに
Clay Eickemeyer
メンバー登録日: 09/19/22
82,264 ポイント
455のガイドは作成済み
チーム
Guide Team Guide Team人のメンバー
Staff
9 メンバー
11,491のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 7
今までの合計 349
